Who can explain the "Power ETC" button to me?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Cheap Bastard, Dec 29, 2015.
  1. Dec 29, 2015 at 8:16 PM
    Cheap Bastard
    Cheap Bastard [OP] New Member
    2016 TRD Off Road w/ tech
    stock
    Manual is vague at best. What exactly is the button doing? Is it a re-map (or secondary map) of the FI system?
  2. Dec 29, 2015 at 8:18 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Growing hair under the wheel wells. Shit, I don't know.
    Cheap Bastard[OP] likes this.
  3. Dec 29, 2015 at 8:23 PM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    I know in the older Toyotas, like my 97 4Runner, ETC Power is like a "shift kit" and changes the shift points for the tranny (higher rpm before changing gears). Not really sure about the new trucks though
    Boot879 likes this.
  4. Dec 29, 2015 at 8:27 PM
    unixadm
    unixadm Well-Known Member
    Super White 2015 DCSB 4x4 Off Road
    Here's what it's doing.
    1. It's adjusting the throttle map for the "throttle by wire". The sensitivity is increased, so it takes less throttle movement to actuate the throttle blade in the throttle body.
    2. It's adjusting the shift points of the transmissions to higher levels, and it prevents the transmissions from going into 5th until 52-53 MPH. This keeps the revs up a bit, which for a 3.5L is a GOOD thing in a truck.
    3. It makes the MPG misers upset.
    So what is ECT? Extremely Cool Technology in my opinion. It takes a turd of a stock 2016 Tacoma and makes it bearable. When I jump in my first gen, it feels FAST compared to the 2016 without ECT. That should never happen, since we all know a 1st Gen 3.4 Automatic can hardly get out of it's own way.
    Flhighby, g4b0r, ppfd and 4 others like this.
  5. Dec 29, 2015 at 8:32 PM
    tacobell007
    Drew
    Western MA
    My stock 3.4 auto feels quick compared to my 2TR 5spd with 33s and armor lol
    Tacoma2GR likes this.
  6. Dec 29, 2015 at 9:08 PM
    Cheap Bastard
    stock
    Thank you Unixadm
  7. Dec 29, 2015 at 9:17 PM
    mustangwilly
    mustangwilly Well-Known Member
    2017 DCSB OR Quicksand MT
    So does anybody know the MPG loss if you run with the PCT on all the the time?
  8. Dec 29, 2015 at 9:30 PM
    tacitos
    tacitos Tah-Key-Toes
    16 TRDORDCLBJBL
    I had drive-by-wire in my Yamaha motorcycle remapped a while back. It made a huge difference, made the throttle input smoother and more predictable. The remap involved re-flashing the ECU, I wouldn't be surprised if the same can be done for the Tacoma since most manufacturers source their ECU's from a handful of suppliers. If there is enough interest, I could ask the programmer what it would take / cost to develop a program to re-flash Tacoma ECU's.
  9. Dec 29, 2015 at 9:31 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Oh, do. DO!
    tacowillyoma likes this.
  10. Dec 29, 2015 at 9:35 PM
    tacitos
    16 TRDORDCLBJBL
    I should mention the current process involves you either purchasing the software / harness kit and remapping the ECU yourself or sending your ECU in.
    I'll hit him up after I pick up my Taco.
    Edit: Does anyone know where the ECU is located in the 2016 Tacoma?
  11. Dec 30, 2015 at 3:49 AM
    Upstate NY
    Upstate NY Well-Known Member
    Rob
    Hudson Falls
    2018 TRD Access Cab
    LT265/75 R16 Goodyear Wrangler Duratracs WeatherTech hood guard WeatherTech side window deflectors Toyota bed mat Alabama Crimson Tide hitch cover
    Aren't you concerned about voiding the warranty?
  12. Dec 30, 2015 at 5:08 AM
    moe2o4
    moe2o4 Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
    My ECT mode in my manual 5 speed is to shift at 5k rpm!!! And away we go!!!:burnrubber:
    WSC 2016 TRD off road likes this.
  13. Dec 30, 2015 at 5:54 AM
    FOXY 367
    FOXY 367 " PAIN IS LIFE'S GREATEST TEACHER "
    2016 Tacoma DC Long Bed TRD Sport 4 X 4
    None
    The ECT ( Electronic Transmission Control) only function is to allow the engine to rev up an extra 500 RPM,s before shifting if the throttle is matted. All it does is change the shift points. In the OFF mode the Trans will shift sooner,
  14. Dec 30, 2015 at 6:41 AM
    baron55
    baron55 Well-Known Member
    2025 Tacoma TRD Sport 4X4
    Like others have said, Shift points and throttle sensitivity. Since the throttle is not directly controlling fuel. It simply tells the ECU what you want, and it is up to the ECU to deliver. The ECU to save fuel won't add a lot of fuel (power) in the normal mode (OFF), This the complaints of the sluggish engine response.
    If Toyota reverse the function of the switch, and had it setup with ECT as default on, and pushing the ECT button for economy mode, most would not be complaining, because the truck would seem to respond as it should. And pushing ECT would engage the gutless economy mode. For a end user this would make much more sense. But it would pass the EPA MPG requirements as the default setting.
  15. Dec 30, 2015 at 6:59 AM
    Kentuckytaco2006
    Kentuckytaco2006 Well-Known Member
    Mark
    2006 Red Prerunner Doublecab
    Correct me if I'm wrong...but I was under the impression that the "ECT" button is NOT supposed to be used under normal conditions...but ONLY when ur stuck and or are towing something that u need a little extra power boost ...Not to use just when ur driving to work or the store etc...
    At least that's what I was led to believe from the dealership
  16. Dec 30, 2015 at 7:02 AM
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    Can I set it to be on all the time so I don't always have to push the button?
    Cheap Bastard[OP] and moe2o4 like this.
  17. Dec 30, 2015 at 7:05 AM
    gottaToy
    JJ
    1985 Moped
    because you know, on my VW I can buy VCDS and change the coding to do stuff like that
  18. Dec 30, 2015 at 7:06 AM
    gottaToy
    JJ
    1985 Moped
  19. Dec 30, 2015 at 7:11 AM
    gottaToy
    JJ
    1985 Moped
    Flhighby and nv529 like this.
  20. Dec 30, 2015 at 7:16 AM
    gottaToy
    JJ
    1985 Moped
    You mean they don't make programmers for Toyota? I was really wanting to mess with the programming on my ECU so I can make hundreds of extra horsepower with my performance air filter. I hear programming the ECU is really simple and anyone can be a tuner
