Who can figure out the origins of these UCA's? Chinesium
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Koolbreeze7, Feb 8, 2024.
  1. Feb 8, 2024 at 5:20 PM
    Koolbreeze7
    Koolbreeze7 [OP] GRILL MAN
    Jon
    Jersey
    2017 TRD Sport 4x4 DCLB Black, Trail Limo. RIP- 2009, 2000, 91,89,87 trucks
    Rigid pod fogs, SpartanX stealth grill and hood LED's, 17" SEMA's on 275/70/17 Falken Wildpeak AT3W's, Fox 2.0 on all corners , TRD CAI, LEER 100XQ Blacked out, w/ Thule racks, and Cargo slider Flow master American Thunder "dual" exhaust, remote start, tint, TRD Pro grill and TRD shadow graphics, Alcan custom 8 leaf Spring Pack
    AusBerg likes this.
  2. Feb 8, 2024 at 5:43 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Is it worth the savings to have them fail and cause an accident?
  3. Feb 8, 2024 at 5:45 PM
    AmateurTaco1313
    AmateurTaco1313 Next truck will be a Hilux
    ROK
    2018 TRD Sport 4WD DCSB
    Enough for now
  4. Feb 8, 2024 at 5:46 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    There are a few billet aluminum UCA's with heim frame connections, but you're right, it appears to most closely copy Icon.
    https://www.iconvehicledynamics.com/accessory/14635/icon-accessories-05-up-tacoma-billet-uca-dj-kit/
    But there's also:
    https://www.kibbetech.com/collectio...e-4wd-05-19-upper-arms?variant=18896169762873
    https://camburg.com/shop/kinetik/up...05-kinetik-billet-uniball-upper-control-arms/
    I personally wouldn't trust the heims or the ball joint on those eBay UCA's. They probably wouldn't fail catastrophically, but I bet they'd wear out in short order and you'd spend the initial savings on replacement parts.
    Also, that red anodizing will probably turn pink and wear off quickly.
    Put it this way... there's a reason you're paying significantly less...
  5. Feb 8, 2024 at 5:51 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Really puts the sus and suspense in suspension.
    Found a bunch of similar stuff on Alibaba
  6. Feb 8, 2024 at 5:52 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    A copied design means the geometry would be fine. And likely the machined aluminum isn't the worst thing in the world. Likely the corners/price was cut with the moving components. Instead of actual rod ends, they have a bushing and sleeve. Bet that polyurethane(ish) bushing deteriorates in less than a year and you can't get replacements. And instead of a heim at the end, they have a ball joint. And probably the lowest of low end ball joints. Assuming the frame side of the arms don't use a funky size thread, you could easily get some nice rod ends, and presumably find a decent replacement ball joint once you had the arms to take measurements. You'd probably still come in under the price of icons that way, but not by much, so you might as well get the good stuff without the hassle at that point.
    Koolbreeze7[OP] likes this.
  7. Feb 8, 2024 at 6:03 PM
    Koolbreeze7
    Jon
    Jersey
  8. Feb 8, 2024 at 6:05 PM
    Koolbreeze7
    Jon
    Jersey
    I am a gambler, so the safety factor is worth a roll.. having my UCA's turn pink may be a bridge too far. There is the heim joint store... https://www.heimjoints.net/collections/3-4-750-heims
  9. Feb 8, 2024 at 6:15 PM
    0xDEADBEEF
    Or, it could be the safe exact thing from the same factory, built after hours with different labels.
    Ricardo13x likes this.
  10. Feb 8, 2024 at 6:19 PM
    Koolbreeze7
    Jon
    Jersey
    That is my thinking "Hey we ran the 5000 that Icon ordered and we have all this extra material and time.....?"
  11. Feb 8, 2024 at 6:43 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Except that Icon doesn't use bushings and ball joints. Which supports what i initially said......aluminum arm is likely fine. Moving parts are very different.
    0xDEADBEEF[QUOTED] likes this.
  12. Feb 8, 2024 at 7:17 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Wise man say:
    "there's no honor among thieves"
  13. Feb 8, 2024 at 7:37 PM
    SunRunner
    SunRunner Rub some dirt on it!
    Scott
    PA
    2019 Off Road Looooooooong Bed
    The uniball design would have me steering clear of these with unknown origin.
  14. Feb 8, 2024 at 8:35 PM
    dezert.taco
    dezert.taco Well-Known Member
    Nate
    Northern Nevada
    2018 Tacoma
    They look like they're the same UCA's from a company called thrashedoffroad who sells them for nearly double, that ebay seller is probably the manufacturer selling direct lol but I've seen good things about them, however the ball joints look a little different in the pictures.
  15. Feb 8, 2024 at 9:06 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Chinese companies make a lot of good stuff. No reason these aren’t a great product for a good price. My made-in-USA SPC arms are on their third set of ball joints in three years. Total crap quality. Might have been better with made-in-China myself.
  16. Feb 8, 2024 at 10:15 PM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    Ouffff. it seems to be a common trend with spc’s.
    Stocklocker[QUOTED] likes this.
