Who Can Sleep in their Truck the Most while Spending the Least while Doing It Contest!
Discussion in 'Tonneau Covers, Caps and Shells' started by tcBob, Aug 27, 2018.
  1. Aug 27, 2018 at 7:42 PM
    tcBob
    tcBob [OP] Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    As the title says, this contest is devoted to determining who can sleep in their truck the most while spending the least amount of money while doing it.
    All that's required is a Tacoma, and sleep occurring inside the cab or bed - that's it.
    Photos are not required, but are welcome. The cost of photography will not be included in the contest total, as photography is not integral to sleeping inside a Tacoma.
  2. Aug 27, 2018 at 8:03 PM
    YOTA 4X4
    YOTA 4X4 Well-Known Member
    2017 Double Cab Off-Road
    OME HD Lift all around, SCS SR8 Rims, 255 85 R16 Cooper ST Maxx, Decked Drawers, 30" Rigid Pro Light bar above bumper on Rago Mounts, Rigid Dually Side Shooters on Rago ditch brackets, Hondo Garage Un-Holey Phone Mount X2, Hondo Radio Knobs AR Bolt Face, Garmin InReach SE GPS synch'ed to Iphone for GPS only mapping, Wet Okole Seat Covers, Husky Liner Contour floor mats, 63 QT ARB Fridge on Alu-Cab tilting slide. GoFastCamper (#41), ARB 2500 Awning with Full Room, Mobtown Off-road Sliders and Full Aluminum Skids.
    I lose...
    Though if you came up with a good enough prize I’d find a 6 ft bed off an old 1st Gen move it to my bedroom cut some foam to fit and start counting the years. Be like that race car bed I always wanted as a kid.
  3. Aug 27, 2018 at 8:45 PM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    I've slept under my truck before, though it wasn't a Tacoma then.
  4. Aug 28, 2018 at 3:17 PM
    smelly621
    smelly621 Well-Known Member
    SF Bay Area
    2011 AC TRDOR 6MT
    It's DLX son!
    Is it total # of nights or do naps count toward a total count of hours?
    Do we get (door)dinged for spending money on truck mods that are not related to glamping comfort (i.e. rear view mirror riser bracket, seat covers, wheels/tires, spark plugs, floor mats)? Or is it only #ExPo gear that we should be adding up?
    DoorDing and ace7196 like this.
  5. Aug 29, 2018 at 1:38 AM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Sadly, my AHS time is limited.
    DoorDing likes this.
  6. Aug 29, 2018 at 1:52 AM
    snowtank
    snowtank Where the fuck did my beer go!
    Andrew
    Arizona
    11 txpro dcsb 08 trd sprt dcsb
    Some stuff here and there....
    I do a hour a day sleeping in the cab cause night shift. (Lunch break) technically save money cause I'm not buying food to consume. When camping I now sleep in the cab and not in the rtt anymore.
  7. Aug 29, 2018 at 10:47 AM
    eggs
    eggs Well-Known Member
    Beersconsin
    2017 TRD O/R
    Slept here a few nights this past summer in the black hills. $60 in wood and an hour to cut/install the platform (not counting the truck and topper).
    Trock and Jeremy4x4 like this.
  8. Aug 29, 2018 at 6:49 PM
    eggs
    Beersconsin
    2017 TRD O/R
    Indeed, the total cost for sleeping in these cramped quarters is about $10,000 per night so far.
  9. Sep 26, 2018 at 4:10 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    If you are looking for an accountant, I'm your huckleberry. I've got the tacoma based spreadsheets to prove it...
    MuddyJackson and DoorDing like this.
  10. Sep 26, 2018 at 10:33 PM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Guess I'm still not doing it right.
  11. Sep 26, 2018 at 10:44 PM
    Lost In The Woods
    Lost In The Woods 4 out of the 5 voices in my head say go for it!
    Eric
    Buckley, WA
    21 Gladiator Rubicon Diesel
    An unusually high amount of pinstriping.
    I'm somewhere around 14 hours over two nights in the front passenger seat. This is due to being kicked out of the tent by my daughter for snoring to loud and keeping her up. The third night I didn't even try and just set up the hammock.
    VE7OSR and DoorDing like this.
  12. Sep 28, 2018 at 4:04 PM
    Mtn Mike
    Mtn Mike Well-Known Member
    Spokane, WA
    2017 TRD OR AC
    If the cost of the truck and canopy didn't count, I'd be doing pretty well here! I've slept in the back of this truck four nights (~28 AHS). I didn't want to lose the headroom that a platform would sacrifice, so I just threw in some gym mats and foam pads. Sometimes I use my backpacking mattress, sometimes not. I did invest about $40 in LED lighting, and another $40 for the Action Packers and shelf you see here (I have since swapped these out with an older tool box). In fact, most of the junk I take camping, I've had for many years. So we'd need to depreciate those things to get a true figure.
    eggs and (deleted member) like this.
  13. Sep 28, 2018 at 6:59 PM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    I'd say the $40 LED lighting in the canopy is overkill luxury. What do you need light for? Your eyes are closed while sleeping!
  14. Sep 28, 2018 at 7:02 PM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    A tarp with bungy cords and a few 1x2 verticals could replace the canopy, and be an upgrade from the fridge box. Or perhaps a mattress bag instead of the tarp.
  15. Sep 28, 2018 at 8:16 PM
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    I'm into my Tacoma maybe 11 grand including all vehicle mods, used camper shell and hand-me-down camping gear. I'm 6' tall and sleep partially curled on a thick foam pad, so I sleep as comfortable in my 6' truck bed as I do at home (short beds suck). I've had my current setup for 3 years and I go camping 3-5 times a year for 3-6 days. I sleep 7.5 hours a night with or without an alarm clock, and I always take a 1-2 hr. nap every full day away from home. The day I drive out and the day I drive back I don't usually have time for a nap.
    Averaged Total:
    4 trips X 3 years X 4.5 nights= 54 nights
    54 nights X 7.5 hours = 405 hours
    Every trip has 2 days I don't usually nap:
    4 trips X 3 years X 2.5 days X 1.5 hours = 45 nap hours
    405 full night of sleep hours + 15 nap hours = 450 hours of truck bed sleep.
    Instagram's worst nightmare; hand-me-down foam pad and sleeping bag, the same pillow I use on my bed at home, Goodwill-sourced rubbermaid dry container, half-broken RTV-repaired 15 year old Mall-Wart cooler.
  16. Sep 28, 2018 at 8:48 PM
    DJB1
    Dave
    SLC, UT
    eggs, VE7OSR and (deleted member) like this.
  17. Sep 28, 2018 at 8:52 PM
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    All I have is a '08 with 295,460 miles on it, and a bed rack I traded work for. But, I haven't even napped in it since the contest started.
  18. Sep 28, 2018 at 9:08 PM
    willie64
    willie64 Willie64
    willie64
    BEND OR
    (slowly becoming less than) Stock '03 3.4L 4x4 TRD SR5
    144 watt led lights on front 36 watts x2 led on the back, cb, Kenwood ham, icon 3" lift, 285/75/16 Fierce Attitude tires, JoeZilla sliders, 4x innovation rear bumper, ARB front bumper. Snorkel. On the workbench: more stuff I can't afford.
    When ever possible! I camp in mine about 3 weeks a year on average. The tent only gets put out when the kid goes with me.
  19. Sep 28, 2018 at 9:12 PM
    Bluetruckbryan
    Bluetruckbryan Active Member
    Bryan
    The desert
    SR5 4x4 3.5L DCLB
    4" rough country lift with skid. 33x12.5 with 18" rims. Blacked out handles& rear Tacoma in tailgate. K&N Cai
    6ft bed tent.
  20. Sep 28, 2018 at 10:53 PM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    You dipshit, a bag from a brand new mattress; any old mattress that gets bagged is probably because someone died on it. Do I have to teach you everything! Have you never been cheap or homeless?
    MuddyJackson, DJB1 and DoorDing like this.
