Who designed this CRAP!
Discussion in 'Lighting' started by Gregman, Jan 30, 2019.
  1. Jan 30, 2019 at 2:45 PM
    Gregman
    Gregman [OP] Well-Known Member
    Freddy Beach, NB
    05 DC LB 4x4 SR5
    Whoever designed the OEM 9003 headlight bulb retaining wire contraption needs a kick right in the privates! I just spent more than a half an hour in a dark cold snowing parking lot changing the passenger side bulb in my 2005. I still have the OEM headlight assemblies. There is very little space between the wiring harness plug for the bulb and the washer fluid tank. It's dificult to get the new bulb into place without touching the glass. You can't see where the bulb goes, you have to feel around to get the tabs aligned in the slots. Then there is that cursed wire contraption. It doesn't stay in place and is impossible to get seated back into place. In order to get access to even see it, I had to take out the washer fluid tank. Of course now the wiring harness plug that goes into the washer fluid tank has a broken tab as a result of my efforts.
    My head is going to explode.
    WPNZ, Too Stroked and crashnburn80 like this.
  2. Jan 30, 2019 at 2:48 PM
    medic2230
    Murph
    Bama! Roll Tide
  3. Jan 30, 2019 at 10:57 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Those wire retainer clips can be infuriating.
    @Too Stroked
  4. Jan 31, 2019 at 4:32 AM
    Troyken
    Troyken Well-Known Member
    NY
    2013 DCSB v6 off road 4x4 6 spd. MT
    As soon as you release the wire clip it can swing away from the bulb and drop out of sight somewhere... another three hands required in the space for one job. Being forewarned from experience, I clipped alligator clip leads on mine to leash them to the truck while working there. Those things are funny, they are hard to work with and then they go into place and you think "oh, that was easy, that's how they go", like some wiper blades, then you don't do it again for 3 years. I'm sure that clip is very fast to assemble...... off the truck,at the factory.
  5. Jan 31, 2019 at 5:38 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    I had the exact same experience while on vacation in Colorado this past Christmas. I asked my fiancé if she'd hold the flashlight since it would only take "5 minutes." Needless to say, she handed me the flashlight after a half hour or so and went back to the warm hotel room. Another half hour and I had the sucker back in. And I thought I could do bulb changes in my sleep!
    FYI: I'm working on a post sharing all of crashnburn80's and my tips and tricks as to how to make bulb changes a bit easier. I still need some pics and it's 2 degrees (F) outside right now. I'm going to wait until I can at least feel my fingertips if you don't mind.
    crashnburn80 likes this.
