Who did I just do a pull with.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Brianawd, Sep 24, 2015.
Thread Status:
Not open for further replies.
  1. Sep 24, 2015 at 10:22 PM
    Brianawd
    Brianawd [OP] Well-Known Member
    Brian
    Portland OR,
    2015 Tacoma dclb
    Billstein 5100s set at 2.5 in the front,2in AAL in the rear with 5100s
    Ok who did I just do a pull with that also just installed there SC. This was on 99E between Oregon city and Gladstone. In Oregon.
  2. Sep 25, 2015 at 12:27 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    You pulled him and didn't get his name?
    because_wumbo-truck likes this.
  3. Sep 25, 2015 at 6:21 AM
    Pigpen
    Dan
    Northwest Montana
    It was a courtesy tug, I'm sure
  4. Sep 25, 2015 at 6:25 AM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    or a nudge
  5. Sep 25, 2015 at 6:39 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Street racing is not allowed. Read the Code of Conduct.
Thread Status:
