Who does this
Discussion in '1st Gen. Tacomas (1995-2004)' started by Motormat, Jan 25, 2024.
  1. Jan 25, 2024 at 3:40 PM
    Motormat
    Motormat [OP] Member
    Mathew
    2001 Tacoma 4x4
    Why why why why.... he said he cut the headers to make it easier to remove the engine from his 4runner...... paid 100$ for it going to try to make a turbo manifold out of what's left....
    Driverside is all there the flang from the crossover pipe / driverside Is still there. Driverside is well not there lol. But why ?
  2. Jan 25, 2024 at 3:44 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The reason it was done was because of time.
    I'd suspect laziness played a big part in it too.
    Now, tell me about this turbo build. I need to know more. :D
  3. Jan 25, 2024 at 4:31 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Agreed ^^^^
    Motormat
    I saw a Roadkill episode while back
    They bought cheap eBay header
    Not to mount, but to cut apart and fab turbo piping
    Worth more for fab parts/bends than the actual crappy header
    I would of never thought of doing that
    Maximumdarkside likes this.
  4. Jan 25, 2024 at 4:41 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    OP. What’s the backstory? How did you get involved? What is the plan going forward?
  5. Jan 25, 2024 at 4:51 PM
    ChargedSHOTaco
    ChargedSHOTaco Well-Known Member
    What a moron.
  6. Jan 25, 2024 at 5:10 PM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    Ever been to a you-pull junkyard? Folks will cut anything to make pulling a part faster. I regularly see perfectly good drive shafts cut rather than removing four bolts, tie rods cut rather than popping a ball joint, and entire front ends cut off rather than dealing with motor mounts. I've even seen shocks cut in half to get a rear axle off.
    I'd guess that whoever did that didn't know they were "nice" headers.
    Wulf and ControlCar like this.
  7. Jan 25, 2024 at 6:34 PM
    Motormat
    Mathew
    2001 Tacoma 4x4
    found it on facebook marketplace. i got the entire thing for 100$ with a 4runner harness. The guy bought a 4runner previous owner had started to do a waterpump/timing belt and valve cover gaskets. got in over there head and sold to this guy. He i would assume did not want to deal with trying to figure out where all the bolts and what not were to finish the job so he threw in a junkyard motor and called it good. He said he cut them to make it easier to pull the engine..... plan going forward is i bought an 03 prerunner from a buddy for 800 with 2 engines that need rebuilt. so im going to hopefully refresh this engine assuming it compression tests fine. Slowly rebuild another 5vzfe. I would like to slowly work my way into a turbo setup. honestly im not sure what to do with the prerunner once done id like to keep it however i would like something i can lower as i have an 02 4wd so no real need for a prerunner. but everything is still up in the air at this point lol
    ControlCar likes this.
  8. Jan 25, 2024 at 7:12 PM
    mlcc
    mlcc Well-Known Member
    Oregon
    2002 DC TRD/ 1995 4runner
    Mid travel, armour all around
    Because meth.
  9. Jan 25, 2024 at 7:16 PM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    For $100 who gives a shit.
    grizzlypath, Wulf and Bivouac like this.
  10. Jan 25, 2024 at 7:24 PM
    Bishop84
    Bishop84 Well-Known Member
    When working wreckers you dont mess around. If a bolt starts to round, you cut it and move on.
    I once pulled and engine out of a chevy express van and we basically unbolted the mounts/bell housing, then starting pulling on it while cutting EVERYTHING.
    Giterdun.
    Wulf, Bivouac and MadNachos like this.
  11. Jan 25, 2024 at 7:30 PM
    ControlCar
    Steven
    Sugar Land TX
