Who does your oil changes?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ydoow, Aug 19, 2009.
Best place to get your oil changed at ?
  1. The dealership
    21.4%
  2. Jiff Lube type place
    6.8%
  3. Your self
    71.8%
  1. Jul 13, 2011 at 11:30 AM
    #361
    TeXian
    TeXian Shifting Member
    Christian
    Texas
    2010 Pyrite Mica TRD Sport DC 4X4 6spd
    bone stock
    <====== THIS GUY!
    I used to pay my mechanic to change the oil every 3k.
    Now that I'm using Mob1 Synth, I change it myself every 5k
    it's ALMOST too easy!
  2. Jul 13, 2011 at 2:13 PM
    #362
    MAPLENUTS
    MAPLENUTS Well-Known Member
    STEVEN
    East Coast, USA
    TRD SPORT TACOMA 4X4 L/B
    Stock
    I do it myself using Mobil1 'cause I don't trust the garage or commercial store to give me Mobil1 when I ask for it. Some will charge you for it and give you dino. So do it yourself and be sure. Allows you to spot any problems brewing underneath. Every 5K, and right before the winter, very easy and so much clearance.
  3. Jul 13, 2011 at 9:49 PM
    #363
    l1tech
    l1tech Well-Known Member
    mike
    bend,oregon
    2011 TRD Sport
    3" Redilift
    As a professional auto technician for 25 years, I've seen the damage and stupid mistakes the semi-trained monkeys at the quick lubes and the dealership do. It amazes me how they can screw up a basic oil & filter service ( cross threded, stripped drain plugs. Loose drain plugs. Filters finger tight and leaking or on so friggin tight you nearly twist them in half trying to get them off, not to mention nothing gets lubed or gear boxes checked). I commend my fellow taco owners that choose to do it yourself, you know its done right. My only advice to you is find a reputable independent shop to inspect your rig once a year ( or twice a year if your hard on it) to make sure there are no safety or mechanical issues that a professional eye can spot. Most reputable Independants will treat you right and not try to sell you a bill of goods that are not necessary.
    Just my two cents worth...........
  4. Jul 14, 2011 at 1:57 AM
    #364
    JoeRags27
    JoeRags27 Because I can
    Joe
    Pawleys Island, SC
    08' Tacoma 5-spd Blacked Out
    Aftermarket tires/all black aftermarket wheels/LED interior floor MOD/Cargo bed net/Interior LED Mod/Plasti dip Emblems Mod/Plasti Dip grill Black/Black Headlight Mod/AFE Pro Dry S Filter
    Who doesn't love lying on your back and looking up a Taco's skirt? Gotta do it yourself! Its the only guarantee I have anymore
  5. Jul 14, 2011 at 1:09 PM
    #365
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Cheaper, faster, and I know exactly what was done when I do it. I look for other problems while I'm in there too.
  6. Jul 15, 2011 at 11:43 AM
    #366
    JKD
    JKD Well-Known Member
    I do my own and enter all of my service info into ToyotaOwnersOnline.com, which puts it into the same database with the dealership service records.
  7. Jul 15, 2011 at 3:15 PM
    #367
    deerslayer75
    deerslayer75 Well-Known Member
    Tim
    jersey shore
    11 TRD sport Dblcab Lngbed
    pop-n-lock, mcgard tailgate lock, chrome tube steps, bed extender, chrome brush guard, Fold a cover (G-4) tonneau, weather tech floor mats and rain gaurds, sock monkey: TRD 3rd brake light and whitetail decals, LED bed lights, blue map & dome, 3rd brake light and license plate LED mod, illuminated 4x4 switch, fishing rod holder mod, scangauge II, Remote start & alarm, TW sticker, Flyzeye cupholder light mod
    I will be using the dealer until my 2 year toyota care runs dry. At that point I will be installing a futomo oil drain valve and doing it myself.
  8. Aug 8, 2011 at 11:28 AM
    #368
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Someone remind my why Toyota put the oil filter upside down on the top of the engine? My Grand Am had the filter on a 45 degree angle at the bottom of the engine, nearly impossible to make a mess with it. Same with the drain bolt. I could change the oil without a single drop hitting the ground. As soon as I loosen the bolt on the Taco, my hand is instantly covered in oil. And the oil comes out so fast that some oil pans can't take in the oil fast enough. The only nice thing is the truck is tall enough to get under it without jacking it up.
  9. Aug 8, 2011 at 11:31 AM
    #369
    jcgarvey
    jcgarvey Well-Known Member
    SFV, Los Angeles, CA
    V6 PreRunner 4x2 TRD Off Road
    Right now the Dealer because its new but I always do it myself to make sure its done right!
  10. Aug 8, 2011 at 2:01 PM
    #370
    n8dogg675
    n8dogg675 Well-Known Member
    Nate
    Houston, TX
    2019 SR5 Double Cab 4x4
    Myself, I'm the only person I trust to do it right.
  11. Aug 8, 2011 at 3:32 PM
    #371
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Attach a 5/16 hose with a hose clamp to the filter drain and run it down through the opening in the skid plate. I leave it attached and plug the end after draining...never had one drop on the driveway.
  12. Aug 8, 2011 at 5:14 PM
    #372
    agtaco
    agtaco Well-Known Member
    Canada, Montreal
    09 DC 4x4 trd
    I just change the oil myself but I all ways buy the filter at Toyota and why I do it is I know whats going in and I don't have to wait all day for my truck
  13. Aug 8, 2011 at 6:59 PM
    #373
    Tacolover443
    Tacolover443 Well-Known Member
    Kyle
    Haverford, PA
    07 TRD OR DCSB BSP
    Satoshi, color match grill, 2 Hella 500ff's, rear TSB, yellow "Taco", OEM all-weather floor mats, OEM TRD seat covers, Ultra-Gauge, bed linered rear bumper, Plasti-dipped rims, DuraTrac's,
    Do it my self because I know I know what I'm doing and I know what I'm putting in the truck.
  14. Aug 9, 2011 at 7:05 AM
    #374
    chris duby
    chris duby This is where I write something clever
    Lake Jackson, TX
    2020 TRD OR Premium
    6" Lift, 22x12 Xtreme Force XF8 wheels, 33x12.50 Nitto Trail Grapplers...
    Jiffy Lube does mine because I'm too lazy and it's been over 100 degrees here for weeks. And, they also give me $15 off since I've been going there for years.
  15. Aug 9, 2011 at 10:38 AM
    #375
    OffroadToy
  16. Aug 9, 2011 at 10:54 AM
    #376
    DP4x4
    DP4x4 Well-Known Member
    Daniel
    San Diego
    2011 White DC SB TRD Offroad 4x4
    AFE Stage II CAI, OME complete 3" lift w/ aal, 285/75/16 BFG AT TA KO, 55w 6000k headlights, 35w 3000k fog lights, Gibson Cat-Back System, Color matched grille, Grillcraft, Black lower valance, Black TRD skid plate
    For now I will be going through the dealership because of the toyota care, it's free for 2 years. After it's used up I will be doing it myself.
  17. Aug 9, 2011 at 11:00 AM
    #377
    neoflex
    neoflex Well-Known Member
    2 years free oil changes so until that runs out the dealer. When I need to pay for them it will be getting done in the garage.
  18. Aug 10, 2011 at 12:37 PM
    #378
    Bloom
    Bloom Well-Known Member
    NASCAR, North Carolina
    2011 BR DC TRD OR
    OME 885+Dakars, WeatherTech mats, EGR In Channel, PopNLock, Access LE, 3M tint and clear film paint protection, Sport grille, Amsoil, Zaino once in a while.
    I change my own oil and do all other maintenance and repairs if I have the tools to do it.
    Why? Partly a trust issue, you never know if the person doing the work knows what they're doing, but I enjoy doing it and like to know how things work.
    Plus, by doing the work myself, I often can spot problems before they become problems.
    Besides, nobody cares as much about my truck as I do.
  19. Aug 10, 2011 at 3:06 PM
    #379
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    I just put a cup under there (McDonalds, Whataburger, Sonic, etc.), fits right in with no spills, it wedges in just right so I don't have to hold it. I keep meaning to pick up a hose, but I only remember when I have already drained the oil and go to take out the filter.
  20. Aug 10, 2011 at 3:38 PM
    #380
    Nolazach
    Nolazach Well-Known Member
    New Orleans
    An ARE camper shell, a 1000w power inverter.
    DIY, Royal Purple twice a year...
    Filter change and top off ever 3,000 miles.
