Who does your oil changes?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ydoow, Aug 19, 2009.
Best place to get your oil changed at ?
  1. The dealership
    21.4%
  2. Jiff Lube type place
    6.8%
  3. Your self
    71.8%
  1. Mar 18, 2013 at 9:23 PM
    #661
    rawdog
    rawdog Well-Known Member
    Kelowna B.C.
    2016 TRD Sport Upgrade PKG DCSB
    Whats an oil change?
  2. Mar 18, 2013 at 9:25 PM
    #662
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
  3. Apr 28, 2013 at 4:24 PM
    #663
    elsenordave
    elsenordave HaoleBilt
    Dave Smith
    Blown 2013 NBM DCSB Sport
    AFE CAI TRD Exhaust TRD Supercharger 3" Cornfed Spacer 2" Toytec AAL
    The dealer...why because I work there
  4. Apr 28, 2013 at 4:28 PM
    #664
    scottg918514
    scottg918514 Well-Known Member
    2013 DC, TRD 6-spd Manual, 4wd
    Do it myself, 3 vehicles and 1 boat. Many good reasons, but IMO, the best is you see other potential problems when u actually root around your vehicle.
  5. Apr 28, 2013 at 4:45 PM
    #665
    Osugoose
    Osugoose Well-Known Member
    Sean
    Tulsa, OK
    2011 Sport DCLB 4x4
    885x w/ nitro sports,Dakars w/ 182,Katskinz two tone leather
    Dealership offers a lifetime engine warranty if they change my oil every time, so they change my oil, but I do everything else myself.
  6. Apr 28, 2013 at 4:58 PM
    #666
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    I hope you have that in writing, because that warranty is only good at that dealership, is only good for the duration of that dealer's ownership.....
    ...and unless they are doing oil changes for free, they are in violation of Magnusson Moss.
  7. Apr 28, 2013 at 5:11 PM
    #667
    Osugoose
    Sean
    Tulsa, OK
    2011 Sport DCLB 4x4
    The dealership has been around forever, but the terms are crappy. Example, the fine print says the replacement motor doesn't have to be a new crate motor or even rebuilt, it can be salvage. Yes I checked it against Magnusson Moss, and the fine print doesn't say they have to do the oil changes, the service managers will tell you they do and if that day ever comes, I don't want to fight that fight. I used to work there and I know most of the managers, I get discounts, and I get to talk to friends, so its whatev.
  8. Apr 28, 2013 at 6:42 PM
    #668
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    I do my own unless I have a coupon for dealer.
  9. Apr 28, 2013 at 6:51 PM
    #669
    WPDAWG11
    WPDAWG11 Well-Known Member
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    Fixing to do my first taco oil change. I am converting from regular oil to mobile 1. I always changed my oil on my blazer any tricks to a taco?
  10. Apr 28, 2013 at 7:10 PM
    #670
    elsenordave
    Dave Smith
    Don't drain your transmission fluid(it happens more often then you would think) & get a catch can for below the filter housing...
  11. Apr 28, 2013 at 7:14 PM
    #671
    WPDAWG11
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    Really? I have been around many different vehicle. Is the oil pan plug and tranny that close?
  12. Apr 28, 2013 at 7:17 PM
    #672
    elsenordave
    Dave Smith
    On the 4.0 they are close enough that it can be mistaken...
  13. Apr 28, 2013 at 10:17 PM
    #673
    Zilla
    Zilla Well-Known Member
    snah
    los osos ca
    Red Tacoma SR5 4X4 6speed
    Myself
  14. Apr 30, 2013 at 5:30 AM
    #674
    SpacemanSpiff
    SpacemanSpiff Well-Known Member
    James
    08 TRD Off-road
    I do it myself... I know that everything has been changed, at the correct levels, and the drain bolt has been properly torqued...
  15. Apr 30, 2013 at 8:42 AM
    #675
    esse10
    esse10 Well-Known Member
    Texas
    05prerunner SR5 DBLCAB
    I wouldn't deny myself of that PLEASURE, of course I do it myself. Save money, know it's done right, torqued correctly, filled up to the correct mark. That's the first thing I did when I brought my truck home after purchasing it used, change the oil that same day.
  16. Apr 30, 2013 at 8:52 AM
    #676
    Mad Man Marty
    Mad Man Marty Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
    Do all cars and trucks myself.
    Ive had 2 bad experiences at 2 dealerships at 2 different brands (not toyota).
    I use shell rotella t6 full synthetic and fram xtra or tough guard every 5K.
  17. May 2, 2013 at 6:05 AM
    #677
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    If it is the very first oil change, you may have trouble getting the old filter off - apparently no one lubes the filter gasket at the factory when the engine is built. Have had no problem on 8 oil changes since - hand tight with filter gasket oiled.
  18. May 2, 2013 at 8:42 PM
    #678
    demontacoma
    demontacoma Friends dont let friends drive stock
    Esteban
    Fresno, CA
    2012 Tacoma Off Road
    Debadged except for TRD Off Road N-Fab Nerf bars (black) 3" lift Aries Bull Bar black with brushed steel protector G2 series Backflip Bed cover T-Rex Billet grill w grenade insert
    the dealership only because i have a 2012 with 75,000 free maintenance plan. once that is done will do myself. only 50,000+ miles to go
  19. May 5, 2013 at 7:16 PM
    #679
    68vert
    68vert Well-Known Member
    AZ
    DCSB 4X
    ditto. had some bad experiences with the the dealer service.
  20. May 5, 2013 at 7:27 PM
    #680
    mullet
    mullet Member
    2013 PreRunner TRD
    I do it myself. Not a big fan of picking my truck up and having grease/oil on the steering wheel and door handle.
