Who has an AK (and variants)?
Discussion in 'Guns & Hunting' started by Sleipnir, Oct 4, 2012.
  1. Feb 8, 2022 at 10:17 AM
    #1061
    BlackPearl
    BlackPearl Well-Known Member
    Alex
    Toyota Tacoma TRD
    3” lift. Sway a ways 2.5 on 285 75 16 and much more
    Sleipnir[OP] likes this.
  2. Feb 8, 2022 at 2:47 PM
    #1062
    -Rorschach-
    -Rorschach- The Black Helicopters are coming…I gotta go!
    2019 Silver Sky Metallic Tacoma DCLB TRD OR 4x4
  3. Feb 9, 2022 at 7:59 AM
    #1063
    Dr. Doom Says
    Dr. Doom Says Well-Known Member
    SE TN
    2019 TRD OR
    Installed an Attero mount for a HS510, but Im not crazy about how high the optic was. So I ordered another Attero mount for a HS403 and should be happier this time around.
    Sleipnir[OP] and BulletToothTony like this.
  4. Feb 9, 2022 at 8:31 AM
    #1064
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    I’ve got one on my Ak74 and it’s great, I think I’ll be grabbing another one for my next build.
  5. Feb 9, 2022 at 8:38 AM
    #1065
    Dr. Doom Says
    SE TN
    2019 TRD OR
    Yeah I think its a nice option since I want to keep the side folder. Just didnt like high the HS510 sat on the rail mount version. They posted a HS510 mount they were working on back in October that removed the QR mount on the optic and brought the optic way down, but it hasnt been released.
  6. Feb 11, 2022 at 8:43 AM
    #1066
    BlackPearl
    Alex
    Toyota Tacoma TRD
    BeatnikFink and BulletToothTony like this.
  7. Feb 12, 2022 at 3:50 PM
    #1067
    BeatnikFink
    BeatnikFink Well-Known Member
    2021 TRD Off Road
    I finally got around to hogging out a pristine NOS Russian SKS stock to accept AK mags
    szidls, -Rorschach-, uurx and 6 others like this.
  8. Feb 14, 2022 at 8:12 AM
    #1068
    LMarshall73
    LMarshall73 Well-Known Member
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
    So, I think I've spent a little too much time playing Escape From Tarkov. I replaced the SLR handguard and Ultimak gas tube on my SBR with Zenitco furniture (B30M, B31S, and B33). I couldn't find my original gas tube (it's been wearing the Ultimak since 2007 or so) so I bought a full size gas tube and cut it down and rounded out the gas block end with a 3/8" extension. Much easier process than I anticipated. I also added an ALG recoil spring and CNC Warrior 4 piece brake. I did have to add a crush washer for the brake. It was too loose when relying on just the muzzle detent pin for me to be comfortable with it.
    [​IMG]Untitled by Lee, on Flickr
    I also happened to find a Bulgarian slab side mag in a box of 30 rounders that are still sealed in plastic. I have a Primary Arms GLx 2X inbound, but I'll have to wait until I get back from Arkansas to install it.
  9. Feb 14, 2022 at 8:48 AM
    #1069
    Sleipnir
    Sleipnir [OP] Still havent found that stupid snipe
    I'm a horse
    Asgard
    Furd Rangero Ecoboost
    Detents and muzzle devices are supposed to be loose. They're not holding a suppressor on and the detent prevents the threads from backing off.
    Otherwise looks good :thumbsup:
    BulletToothTony likes this.
  10. Feb 14, 2022 at 9:11 AM
    #1070
    LMarshall73
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
    I’m ok with a little wiggle side to side, but this one wiggled a little in all directions.
    Sleipnir[QUOTED][OP] likes this.
  11. Feb 14, 2022 at 9:14 AM
    #1071
    LMarshall73
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
    I forgot to mention, with the Draco gas block I had to trim about 1/2” off of the top rail and shave a little off the sides to fit around the front sight. Also had to cut the front two ears off for the brake to fit. I probably would have been better off with a B10/B19 combo (or just a B19 top rail), but I wanted the extra length out front.
  12. Feb 16, 2022 at 5:14 AM
    #1072
    jmd025
    jmd025 Well-Known Member
    Louisiana
    2010 TRD double cab 4x4
    Was this gun previously setup for ak mags and you just changed the stock?
  13. Feb 16, 2022 at 5:58 AM
    #1073
    BeatnikFink
    2021 TRD Off Road
    Yeah it's factory setup to take AK mags. I got it for free without a stock and gave up on finding an original so I went with the Russian one.
    jmd025[QUOTED] likes this.
  14. Feb 16, 2022 at 6:24 AM
    #1074
    1madmnky
    1madmnky Well-Known Member
    Tony
    Kansas via Fullerton 714
    2010 Tacoma 4X4 DCLB
    Hella Supertones
    My NPAP & Galil Ace
  15. Feb 19, 2022 at 3:20 PM
    #1075
    BeatnikFink
    2021 TRD Off Road
    This SLR106 is very quickly becoming my favorite rifle. Pictured along with my 9mm Tokarev.Screenshot_20220219-161834_Instagram.jpg
  16. Feb 19, 2022 at 3:24 PM
    #1076
    BulletToothTony
    Saw this earlier <.< might try to snag one up whenever they release them.
  17. Feb 19, 2022 at 3:31 PM
    #1077
    p1smo
    p1smo Well-Known Member
    2003 Tacoma TRD 4x4 3.4L 5MT
    Relentless Stealth front + Relentless standard rear plate bumpers w/ D2 cutouts, 2x Rigid D2 floods front + 2x Rigid flush D2 floods rear, BAMF behind-the-grille light bar mount w/ 2x Rigid 6" bar floods, KING coilovers/springs + rear adjuster shocks, Deaver leaf springs, Total Chaos UCAs, BAMF rock sliders, BAMF LCA skids, Relentless front skid, Low-Range Off-Road gas tank skid, Marlin differential plate cover, Marlin E-Locker motor guard, Hawke HD brake pads, Trail Gear steel brake line kit, Marlin HD full clutch assembly, deckplate intake mod + AFE high flow filter, ARB CKMA12, exhaust dumped over rear axle, 32/11.5r15 Cooper Discoverer AT3 XLT, American Racing Baja 15x8, Viper alarm + fuel cutoff switch, and more Toyota OEM parts + replacements than I care to list
    I've got an AK-302M but I've been trying to get my hands on one of those 301s for a long time now. I see them on auction all the time, but there's no way I'm paying $300 for one.
  18. Feb 19, 2022 at 3:44 PM
    #1078
    BulletToothTony
    p1smo[QUOTED] likes this.
  19. Feb 19, 2022 at 3:57 PM
    #1079
    p1smo
  20. Feb 19, 2022 at 4:15 PM
    #1080
    BulletToothTony
    Glad it worked out man!
