Who has an AK (and variants)?
Discussion in 'Guns & Hunting' started by Sleipnir, Oct 4, 2012.
  1. Aug 5, 2024 at 5:36 AM
    #1441
    Barsoom
    Barsoom Well-Known Member
    NW GA OTP
    Agree. I have several Tapco mags, and they were cheap enough that I do not feel bad about beating on them, and they work fine. Just need to watch the rear lug (i.e. do not fall on the ground with the magazine sticking out and absorbing your fall.)
    I had 2 bad AK mags.
    1st was Romy surplus. Body was dented pretty bad. I can usually straighten out 99.9% of mag bodies and they function 100%. This one would hang up after 15 rounds. Swapping a nylon follower from a WBP mag fixed the issue permanently.
    2nd was the above mentioned WBP Polish plastic mag. The front locking lug on it cracked after a couple of uses. It made a good donor for the Romy above.
    Had a PTR32 with a mag release that was too long. Only Magpul AK mags would fit it. Surplus mags would get stuck and be VERY difficult to remove. Tried Polish, Hungarian, DDR, Romy, 2 or 3 generations of Bulgarians, Russians. Same result.
    Casper66 likes this.
  2. Aug 5, 2024 at 5:40 AM
    #1442
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    I noticed Zastava had a 10 pack of Serbian mags with last round bolt hold open in the blem section for $125 kinda tempted but idk if the lbh is really anything to worry about or not I guess just used to ar’s
  3. Aug 5, 2024 at 6:00 AM
    #1443
    Barsoom
    NW GA OTP
    BHO (Bolt Hold Open) feature is particular to Yugo and Serbian mags. They have a differently shaped follower that catches the bolt after the last round.
    AKMs does not have a bolt catch in the receiver, so, once the mag is removed, bolt will go into battery. Unless the safety lever match is notched to hold the charging handle, and you move lever into Safe position to keep the bolt back after mag is removed.
    Long way to say, Serbian mags will work fine, but they will be different from other AK mags.
  4. Aug 5, 2024 at 6:16 AM
    #1444
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    Serbian rifle so I was just thinking it might work well
    Barsoom[QUOTED] likes this.
  5. Aug 5, 2024 at 4:49 PM
    #1445
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    I got this optic mount for the rifle I’m not sure about it. It fits fine but is kinda tall I’m looking at the Swampfox Raider with a low mount for it so it may be perfect
    Overmyhead2021 and Barsoom like this.
  6. Aug 6, 2024 at 1:44 AM
    #1446
    Overmyhead2021
    Overmyhead2021 Active Member
    Chicago area
    2021 Tacoma cement
    bumper , light bars , ditch lights interior lights brake light , A/C drain , winch fog lights
    I replaced the front sight pin on mine and
    the rear was replaced with a krebs .
    Accuracy on that one was outstanding to 200yds . Then I sold it .
    Barsoom and Casper66[QUOTED] like this.
  7. Aug 18, 2024 at 5:43 AM
    #1447
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    Zastava has their own optic mount
    https://zastavaarmsusa.com/product/zastava-m70-scope-mount/
    I’m only looking at mounting a small prism optic. Y’all know way more about this than I do I’m welcome to suggestions understanding we all have our own opinions on what we like. I’m not stuck on a side mount either but do like the idea of a QD mount for this rifle.
    Barsoom likes this.
  8. Aug 18, 2024 at 5:51 AM
    #1448
    babylon5
    babylon5 Well-Known Member
    David
    2015 Tacoma Double Cab TRD Sport
    Being in Canada my son has a both a russian SKS and a chinese SKS and just recently bought a chinese type 81. In the middle of the SKS's is a Keltec RDB bullpup. Think our first SKS was about $300 but prices have gone up a lot since then
  9. Aug 18, 2024 at 4:43 PM
    #1449
    Barsoom
    NW GA OTP
    Side rail on AKM/RPK based rifle is designed to be QD and side rail mounted optics will keep its zero.
    If AK has a solid factory Pic rail, I will use that, like on a Beryl, Galil or Zenitco, otherwise I use side rail. I have used everything from Mepro M21 sights, to Russian POSP 4x scopes to Russian red dots to Holosuns to Vortex small prisms. They all work, depending rifle's purpose.
    I never use gas tube mounted sights. They do not keep zero, overheat and too far away from the eye to be usefull on my experience.
    Casper66[QUOTED] likes this.
  10. Aug 18, 2024 at 5:51 PM
    #1450
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    As you and I discussed previously I bought one which mounts properly but it sits about an inch above the rear cover and worse, to me, it’s pretty off center with the barell and sights. Zastava sells one other than that about all I know to look at is Midwest industries or RS Regulate
  11. Aug 19, 2024 at 10:06 AM
    #1451
    Barsoom
    NW GA OTP
    That's a traditional position of the AK mount. Russian POSP scopes sit about an inch above the cover and to the left of the center bore. The best I can tell, it was to allow use of iron sights and to keep the optics out the way of ejected empty cases. Some AKs eject to 1 o'clock. Was it necessary? No, but some mounts are still made that way. RS and MI are good options for mounts. Description will say if they are centered over the bore.
    Modern Russian AKs have adjustable cheek rests on the stocks, in addition to having a centered Pic rail on a rigid top cover. Modern Russian red dot sights are centered over the bore now also.
  12. Aug 26, 2024 at 4:59 AM
    #1452
    Epitoma-rei-militaris
    Epitoma-rei-militaris Member
    2022 mgm Tacoma SR5 DCSB 4x4
    SoftTopper, 255/85R16s
    KIMG0477.jpg KIMG0476.jpgPoverty State Armory AK with Slavic inspired paint job.
  13. Aug 26, 2024 at 8:44 AM
    #1453
    BlackPearl
    BlackPearl Well-Known Member
    Alex
    Toyota Tacoma TRD
    3” lift. Sway a ways 2.5 on 285 75 16 and much more
    What's the meaning behind гофман?
  14. Sep 8, 2024 at 7:34 AM
    #1454
    NWBoon
    NWBoon Well-Known Member
    Puget Sound, WA
    2019 TRD OR DCSB Cement
    Palmetto State Armory and old Norinco with US parts.
  15. Sep 8, 2024 at 8:45 AM
    #1455
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    I’d love to find one of those Norincos that was affordable even as a MAK90. I just wish I wouldn’t have had my head in the sand back in the 80’s and 90’s
    Barsoom, 308savage and NWBoon[QUOTED] like this.
  16. Sep 8, 2024 at 3:48 PM
    #1456
    NWBoon
    Puget Sound, WA
    I bought the Norinco MAK90 brand new in 1993 for $156 when I was in college. The gun store had a stack of them in their boxes, maybe 15 - 20, and the sale was advertised in the local newspaper. Believe it or not, this was in Sacramento, CA.
    szidls, 308savage and Overmyhead2021 like this.
  17. Sep 8, 2024 at 4:43 PM
    #1457
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    :spy:
  18. Sep 9, 2024 at 9:27 AM
    #1458
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    Shot some Saturday and more impressed with the rifle. Shot out to 120 with open sights not much problem lots of fun. 9x12 steel target ring a ding ding
    NWBoon, szidls, Barsoom and 1 other person like this.
  19. Oct 24, 2024 at 8:52 PM
    #1459
    TRD-Troll
    TRD-Troll Smoked Orc 75% off
    NV
    2019 TRDOR DCSB AT
  20. Oct 25, 2024 at 7:27 AM
    #1460
    Barsoom
    NW GA OTP
    They are not ((10)) Kazanlak Arsenal JSCo/Arsenal AD. They ISD mags. Which is not a bad thing. I have not used ISD's 5.56 mags, but 7.62x39 variety run great, do not break and are cheaper than bakes.
    Rear lug is not milled, like in bakes, stamped steel, and strong enough. Front lug and lips are metal. Front lug does not extend as far down as in bakes, but I have dropped loaded mags on gravel and asphalt and they still functioned.
    History rabbit trail.
    ISD was a part of 3 state factories in socialist Bulgaria involved into AK production and armament in general (they were ((10)) or Arsenal AD today, ((25)) Optico Electron, and ((E)) or ISD today).
    ISD makes stamped AK rifles still (as well as artillery systems, artillery shells and coastal defense systems, in addition to civilian sporting goods, such as binocs, rifles, etc), and, at one point, ISD supplied Arsenal with stamped receivers for US exports. ((10)) makes milled AKs for Bulgarian army and military export. I believe they have gotten their own receiver stamping presses a while back, though.
    DrewZFoster, TRD-Troll and strider98 like this.
