Who has an AK (and variants)?
Discussion in 'Guns & Hunting' started by Sleipnir, Oct 4, 2012.
  1. Jul 2, 2013 at 11:34 AM
    #141
    Alderleet
    Alderleet Ace of Spades
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    You wont gain a damn thing going with a double over a single.
    I had this exact discussion with Jim Fuller at rifle dynamics.
    in every example, the tolerances get stacked and the second hook gets nullified fairly quickly.
    Example:
    How perpendicular are the trigger group holes, to the receiver? If they are the slightest bit off, that adds slight cant. (most notable in a stamped receiver)
    How precise is the grind on the sear engagement face, on the hammer? Are they perfectly parallel?
    How parallel is the grind on the trigger hooks themselves?
    If the world was 100% perfect, the engagement would be equal between both hooks. Since the world likes to piss on our plans, more often things arent perfect.
    If the drill bit walked slightly, if the hammer face isnt parallel, if the trigger hooks arent perfectly parallel, if the holes egged slightly, if the pivot pin sleeve was drilled ever so slightly off center, ect. The 2nd hook wont make a damn bit of difference.
    Its the same reason people never use adapters when attaching suppressors to weapons. the tolerances are so extremely close, that adding more tolerance to the existing tolerances, sometimes ends with a baffle strike.
    In this case, you'd spend money on a double hook, and still be effectively engaging with only 1 of the hooks. the 2nd would be for show...
    86250rrippin likes this.
  2. Jul 2, 2013 at 7:27 PM
    #142
    45longcolt
    45longcolt Well-Known Member
    DFW Area
    2020 Off Road
    Wrap that stock with paracord, sure makes the cheek feel better to touch paracord than scalding or freezing metal. Follow the link then scroll down to "make a Paracord cheek rest".
    http://home.roadrunner.com/~m70AK3/M70.htm
  3. Jul 3, 2013 at 1:29 PM
    #143
    Sleeper362
    Sleeper362 One Convenient Locations ......In Africa
    Corporal
    K-Vegas NC
    06 SR5 4X4 DC Shortbed
    Already wrapped it, this is an old picture of her. I am looking at this and realizing that I haven't shot her in a while, I think its time to fix that. I will try to get some more recent pictures of it up in a bit.
  4. Jul 3, 2013 at 1:46 PM
    #144
    ColoradoTaco
    ColoradoTaco Well-Known Member
    Boulder
    2013 DCSB OFFROAD
    Romanian SAR - 1 ....don't understand all the hype on the AR platform so you can put crap on it....most that crap requires batteries.....
  5. Jul 3, 2013 at 1:49 PM
    #145
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    You can put all that crap on an ak as well.
  6. Jul 3, 2013 at 5:30 PM
    #146
    Rmodel65
    Rmodel65 Yukon Cornelius
    Jawja
    1996 Yota 4x4
    Viper Red paint
    im itching bad for a saiga prices are returning to normal the first one in 7.62x39 for like 399$ ill be buying it
  7. Jul 3, 2013 at 6:07 PM
    #147
    WhatThePho?
    Andre
    HCMC, VN
    2006 STi
    I'm right there with you on that.
  8. Jul 3, 2013 at 6:13 PM
    #148
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    Don't know if you're interested in shipping one, but I can run up to the shop I bought my converted from and see his prices. Dec 2012 I got a converted one for $550, unconverted was either 400 or 450.
  9. Jul 3, 2013 at 7:31 PM
    #149
    Rmodel65
    Jawja
    1996 Yota 4x4
    Viper Red paint
    where in PA is the shop??? i might be going to Philly this summer ive got my LTCF i wonder if being out of state it still exempts me from doing the instant background check??
  10. Jul 3, 2013 at 7:47 PM
    #150
    pittim
    Pennsyltucky
    Boujee Prius
    It's in Home, PA. Having a LTCF doesn't exempt you from going thru PICS (PA Instant check system) so you'd have to have it sent to a FFL near you.
  11. Oct 1, 2013 at 8:45 PM
    #151
    AzogSS
    AzogSS Well-Known Member
    Andy
    Soda City, SC
    2008 Tacoma / 2011 FJC
    New build thanks to Innovative Arms, SC.
    Class III tax stamp in hand.
  12. Oct 2, 2013 at 12:08 AM
    #152
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    ^ thats freakin hot! I want the same thing but with an integrated front site post gas block
  13. Dec 6, 2013 at 8:33 PM
    #153
    JRFugitt
    JRFugitt Well-Known Member
    Justin
    Texas
    '13 PreRunner V6
    Can someone post a link for a drilling template? Every search I do is a dead end. Thanks
  14. Jan 13, 2014 at 6:03 AM
    #154
    shotgunshooter3
    shotgunshooter3 Well-Known Member
    Somewhere in the Southwest
    2025 DCLB TRD OR, Blue Crush Metallic
    Mud flaps
    Waffen Werks AK-74
  15. Jul 27, 2014 at 11:30 AM
    #155
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Looking at 2 AK style weapons.
    Century Arms M70 AB2 Underfolder 7.62x39mm
    and
    Century International Arms VZ2008 Sporter Rifle 7.62x39
    I know the sporter uses proprietary mags, does the m70 use standard AK mags?
  16. Jul 27, 2014 at 12:00 PM
    #156
    45longcolt
    DFW Area
    2020 Off Road
    Yes the M70 uses standard mags but the Yugo mags actually had a different type of follower that stopped the bolt from closing after the last round was fired. They then notched the safety lever to hold the bolt open so a fresh mag could be inserted. Slide the safety lever down to load a round. It is a neat bolt hold open procedure even if it is a little manual with the safety lever notch. But any AK magazine works in them. That M70 was one of the best designed AK's ever made. Check my link out;
  17. Jul 27, 2014 at 12:14 PM
    #157
    Sleeper362
    Corporal
    K-Vegas NC
    The M70 uses standard mags. If its an M70 built on an RPK receiver its actually one of the best AKs on the market. Century paid DC Industries to build their M70 under folders. The usually are not chrome lined and are built on 1.6 mil RPK receivers. These rifles are friggin Cadillacs. Not typical century stuff. The VZ is a good rifle but I do not believe its an AK as it is striker fired. Still a decent design. Not sure on century quality on these. A friend of mine had one that had issues.
  18. Jul 27, 2014 at 12:51 PM
    #158
    95 taco
    95 taco Battle Born
    Thanks guys, My Dad is looking for AK style rifles and we were wondering if the M70 was worth the $100 more (If it used standard mags)
  19. Jul 27, 2014 at 1:13 PM
    #159
    WhatThePho?
    Andre
    HCMC, VN
    2006 STi
    Get a saiga if you can find one... is he looking for a 74 or 47?
  20. Jul 27, 2014 at 1:32 PM
    #160
    95 taco
    95 taco Battle Born
    47 is 7.62x39 correct?
    he wants a 7.62x39
