Who has been told they've voided their warranty? What mod did it
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Badgtho, Dec 23, 2012.
  1. Dec 23, 2012 at 4:37 AM
    Badgtho
    Badgtho [OP] Well-Known Member
    Ben
    CT
    '13 TRD sport 6spd
    TRD exhaust, TRD beadlock wheels, moto xtender
    Just curious.
    Has anyone been told by a dealer they've voided their warranty?
    If so; was it due to tire size? Lift? Other?
  2. Dec 23, 2012 at 4:42 AM
    fur pig
    fur pig Well-Known Member
    I worked for Ford previously in my career and now work for another OEM and an automotive manufacturer CAN NOT deny a warranty claim unless they can prove beyond a reasonable doubt that the failure is directly attributable to the modification. It is VERY rare that a warranty claim falls into this category and always keep in mind that the threat of litigation is very persuasive.
  3. Dec 23, 2012 at 4:45 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    You can't do anything to blanket void your warranty...if you make a modification and it can be linked to the failure you are looking to get covered they might give you a hard time or might not cover it, but that is the risk you run changing stuff from factory parts.
  4. Dec 23, 2012 at 5:55 AM
    Badgtho
    Ben
    CT
    '13 TRD sport 6spd
    Good info. Thanks guys.
    I have a friend who works at a yota dealer and he said he has not seen much get denied.
  5. Dec 23, 2012 at 6:14 AM
    WarDamn
    WarDamn Well-Known Member
    Davenport, IA
    07 Tacoma
    your dealer can try to deny you for some BS reason... all it takes is a couple phone calls up the ladder and you will be getting your warranty work. I had a clutch go out on a lexus at 40K.. dealer said no way. I called the regional rep.. he said no problem. Dont let dealers jerk you around.
  6. Dec 23, 2012 at 6:34 AM
    DR Da_da
    DR Da_da Infrequent Member
    Alabama
    '06 4x4 V6 TRD Offroad auto access cab
    ToyTec ultimate lift, LR UCAs, TRD gen 1 CAI, TRD cat-back, bull bar, anytime fog lights, lighted 4x4 switch, factory SS step tubes, factory interior lighting package, factory VIP 3200 alarm, FJ TRD center caps, rear diff breather relocate, tint, bug deflector, Weather Tech liners
    Absolutely. The Magnuson-Moss Act backs this up.
  7. Dec 23, 2012 at 7:12 AM
    Weou09
    Weou09 Well-Known Member
    Larry
    B'ham, Al
    '12 SR5 4X4
    deleted secondary air filter
    I could see them voiding/trying to void a drive train warranty for a lift or different tire size easy. Also all this "they can't" is wrong. A manufacturer will do whatever they want if you change out parts that could, or even pertaining, to a warranty covered problem you have they can and probably will void the given warranty section for the problem. If you think I am crazy ask a new 5.0 owner with a blown number 8 or a 5th gen camaro that has had the transmission issues.
  8. Dec 23, 2012 at 7:15 AM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    For some weird reason they voided the powertrain portion of my warrantee after I installed an aftermarket Supercharger.
  9. Dec 23, 2012 at 7:58 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    It's not wrong at all. If you let them steamroll you, they will because it's cheaper. But it's on the dealership to prove the issue. I get my transmission replaced after I put my lift and bigger tires on because the failure wasn't due to the extra parts.
    I have no idea what the details on those problems are - care to explain a bit insted of just dropping some obscure reference and acting like it proves you right??
  10. Dec 23, 2012 at 8:11 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I can see how that would be possible.
  11. Dec 23, 2012 at 8:59 AM
    Badgtho
    Ben
    CT
    '13 TRD sport 6spd
    X2
    And thus the wonderment of the Internet. I asked "has anyone voided theirs" and what the circumstances were.
    I get random babble about a 5th gen camaro.
    Stellar.
  12. Dec 23, 2012 at 10:16 PM
    Teeps1206
    Teeps1206 Well-Known Member
    Omaha, NE
    '12 DCSB MGM Off Road 4x4
    Roof Rack Rear step (not my choice)
    :ohsnap:
  13. Dec 24, 2012 at 4:34 AM
    Weou09
    Larry
    B'ham, Al
    '12 SR5 4X4
    Yes I'll explain. Simple bolt ons and tunes equals melted number 8 piston for quite a few 5.0 owners with no number 8 piston failures from boosted 5.0s. Some think its a timing issue, I think it's a cooling problem like the 4 valve Cobra had. Ford has been very strict in saying no to any claims even though most tunes had very conservative timing and fat fuel mixtures. After the first few Ford began voiding power train warranties if the computer had been tuned at all. Same thing with the camaros that had problems. Tranny that is in the Vette, and similar to the one in the Gt500, failing and if signs of burnouts and or track use were found warranties were voided. Even though most cases did not show signs of either forms of abuse and the failures were identical.
    I was not randomly talking I was voicing my opinion to the people that were saying Toyota could not void warranties for aftermarket parts. I had a 03 Tacoma dbl cab with 40k and 285/65/16(a small change in tire size compared to stock) I had a ball joint issue that Toyota claimed to be a cause of the tire. They did not void my warranty but would not pay for the fix. Before some one says I did not try hard enough I was without being able to drive the truck for 2 months fighting them on the issue.
  14. Dec 24, 2012 at 4:50 AM
    Badgtho
    Ben
    CT
    '13 TRD sport 6spd
    Well something like that out can always put smaller tires on and go to another dealer
  15. Dec 24, 2012 at 6:23 AM
    Weou09
    Larry
    B'ham, Al
    '12 SR5 4X4
    Yea I tried that. Apparently they had put notes in with my vin so the other dealer knew what was up. I had just had the tires put on maybe 1k miles before the issue so I knew it wasn't likely the tires caused it but it is what it is. If you are worried about your warranty OP then keep it to appearance mods. Because one person's experience with modding and warranty claims will be different than yours and everyone else.
  16. Dec 24, 2012 at 9:23 AM
    jbrenn
    jbrenn Well-Known Member
    allen texas
    10 sr5
    If you total the car and buy it back that void the warranty. Even if it is just cosmetic like hail damage. That is possible but rare.
  17. Dec 24, 2012 at 9:44 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Totaling a car is not a mod.
  18. Dec 24, 2012 at 10:03 AM
    monsterkx2fiddy
    monsterkx2fiddy Well-Known Member
    Birthplace of Davy Crockett
    Extra money?!?! Lots of mods :D
  19. Dec 24, 2012 at 10:03 AM
    monsterkx2fiddy
  20. Dec 24, 2012 at 12:43 PM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    Had my lift installed at the dealership so it would be covered under warranty...a week later the front end starting squeaking so i took it to another dealership to get it looked at and they said if its due to the lift it wouldnt be covered because toyota doesnt install lifts :confused:
