Who has been told they've voided their warranty? What mod did it
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Badgtho, Dec 23, 2012.
  1. Dec 29, 2012 at 2:10 PM
    #41
    whahahajr
    whahahajr Lone Star Club
    jimbob
    New Braunfels, Tx
    07 Tacoma TRD
    Camburg Uniball UCA, ARB Front Bumper, TAG rear bumper, OME rear shocks, All Pro 3" leaf springs
    My guess was the light was on at time of purchase. If so I hope you got a we owe to get them fixed. They can't warranty what's not there. But if not I would just take it to a tire shop and get it fixed for a lot less
  2. Dec 29, 2012 at 3:43 PM
    #42
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    The manufacturer can not be held liable for warranty work on aftermarket parts and labor. That warranty would be through the supplier of those parts and labor.
    If Jiffy Lube strips your oil filter mount, Toyota won't warranty it.
    The manufacturer can not refuse warranty service on non-affected systems. They can't refuse to cover an issue with the brakes because you installed an FIPK.
    They MAY be able to refuse to cover an issue with brakes if you installed a lift kit, depending on the nature of the work.
    Stainless hoses = No coverage on the hoses or their attachments. Can they deny coverage for a failed caliper? If they open the failed caliper and find contamination consistent with having the system open, or particles from the new hose, then yes, it would be legally possible for them to deny coverage.
    They can't deny coverage on the ENTIRE powertrain (engine included) due to a lift. They could deny impacted systems such as the drive shaft, CVs, and the transmission if oversized tires are installed.
    Furthermore:
    A manufacturer can not require OEM parts and labor as a condition of maintaining the warranty(*) unless said parts and labor are provided at no charge. Harley dealers are real stinkers about this. If this statement is made, get it on tape and forward it to your state's AG office.
    Note: This applies in the US due to Magnusson-Moss
    It does not apply outside of the US unless your country has enacted a similar law.
    (*)Note 2: "Warranty" under Magnusson-Moss applies to the manufacturers base warranty... 3/36, 5/100 powertrain, etc...
    It does NOT apply to "extended warranties", "Toyotacare", or any other 3rd-party "warranty" that is paid for over and above the price of the vehicle (or provided by the dealer).
    These are not "warranties"... they are "Service Contracts" and you are bound by the terms and conditions listed in that contract.
    That contract can specify anything the author desires. I bought an extended warranty for my '03 Tundra from Crown Toyota in Ontario, and it was not a Toyota policy. It was a 3rd party policy, that actually required that ALL service be performed by a little hole in the wall shop in Santa Fe Springs (about 30 miles away).
    When I bought my wife's '04 Rav4, I made sure that Carson Toyota sold me a Toyota extended warranty (didn't need it, hasn't been in the shop since it lost an O2 sensor at 30k).
  3. Dec 29, 2012 at 3:50 PM
    #43
    Rich91710
    Rich
    Los Angeles
    08 Base
    The BAR might be interested.
    The TPMS is federally mandated and it is illegal for a dealer to disable the system. It is likely illegal for a dealer to sell a used vehicle with a non-functional TPMS system.
    Just saying "it's not that great of a feature" is bullshit.
    Sure... we went for a century without it, but it IS a great feature.
    Mine didn't work when I bought my '08.
    After about 6 months, I stopped in at Discount Tire and in 15 minutes, the tech got it working.
    Two days later, I was on the way home from work and the light came on.
    Suspecting it had just taken a dump again, I pulled over and restarted the engine to see if it flashed or simply came on.
    It simply came on. Hmmm....
    Got out and checked the air, one tire was exactly 10psi below the rest. Found a nail in the tire, marked it, and got it plugged.
    Had it not been for the TPMS, I would have come out at 5am the next day to find a flat tire, and my parking arrangement does not allow for access to the spare.
  4. Dec 29, 2012 at 3:51 PM
    #44
    Gotcha88
    Gotcha88 Well-Known Member
    CA
    2012 DCSB PreRunner TRD Sport
    Bilstein 5100s all around, Toytec Eibach coils, Toytec 1.5" AAL, Light Racing UCAs, 285/70r17 Nitto Terra Grapplers, 17x9 Eagle 185s, 20% tint all around, Magnaflow 11256, Cobra CB with 2' Firestik, De-Badged, BHLM, UltraGauge, K&N Drop-in, OEM Bed Mat, OEM All-Weather Mats.
    This is good to know.
  5. Jan 1, 2013 at 9:21 AM
    #45
    whahahajr
    jimbob
    New Braunfels, Tx
    07 Tacoma TRD
    This what I was trying to say. When I hear
    voided I'm thinking entire warranty. They're not responsible for aftermarket parts. I thought that was a given.
    Although if the part is not available through the manufacture then you may be allowed to use an aftermarket substitute. NPN parts.
  6. May 20, 2014 at 1:55 PM
    #46
    Memichal132Baron
    Memichal132Baron Member
    Minneapolis, MN
    2010 Tacoma TRD Sport
    TRD CAI, TRD Cat-Back Exhaust, TRD Retro Ball Style Shifter Knob, 6" Pro Comp Stage 1 Suspension Lift, Pro Comp 7089 flat black 18x9 wheels, 35"x12.5" Nitto Trail Grapplers, PL5300 Tailgate Handle, Access TonoSport cover, Hypertech In-line Speedometer Calibrator, Front windows tinted - 35%, Smittybilt 3" Black Nerf bars, Black Procomp skid plate.
    I just brought my taco in and the dealer wants to charge me $830 to replace the passenger side hub assembly because the hub bearing is bad and making noise/grinding. I have 35's and a 6" procomp stage 1. They told me that due to the tires going outside the wheel wells, that is the direct cause of the bearing going.
    Has anyone else had this issue? And have you had any luck fighting it? I am at 58K mileage (still inside my 5yr/100k warranty window). They said they cslled Toyota and they denied the claim. Any chance the MLM law can help me on this or am I basically screwed?
    Any help is appreciated. Thanks.
  7. May 20, 2014 at 2:12 PM
    #47
    numbah57
    numbah57 GIVE THE MALL A BREAK...WHEEL THAT SHIT
    kahai
    Maui, Hawaii
    09 tacoma 2.7 Beaten not Babied
    URD ARB G2 PELFREY BAMF LCE AFE
    My gears and lockers most likely killed my warranty
  8. May 20, 2014 at 2:14 PM
    #48
    numbah57
    kahai
    Maui, Hawaii
    Oh and my disappearing sway bar mod is probably a no no to the dealership too
  9. May 20, 2014 at 2:17 PM
    #49
    BamaToy1997
    Bill
    Navarre, FL
    Unfortunately Toyota has the advantage on that one. The lift itself was not the issue, but running oversized tires on wheels that may have an offset that is too high can be. Toyota can easily deny that repair. It unfortunately would be up to you, and hiring a lawyer, to sue Toyota for violating the M.M. Act.
  10. May 21, 2014 at 6:54 AM
    #50
    whahahajr
    jimbob
    New Braunfels, Tx
    07 Tacoma TRD
    I swear it just fell right off.:D
  11. May 21, 2014 at 7:59 AM
    #51
    Ken b
    Ken b Well-Known Member
    Ken
    Surprise, Az
    14 offroad 4x4
    ARE shell, bedrug, TRD wheels
    I am running the Toyota TRD Baja Rims on my truck with slightly taller tires 265/75-16 as opposed to stock 265/70-16. Next is a 3" lift and that will likly kill my drive train warranty. I don't plan to run any taller tires than presently installed so I might get away with it.
  12. May 21, 2014 at 8:53 AM
    #52
    lsutiger1
    lsutiger1 Well-Known Member
    Wilmington, NC
    2017 BLACK TRD OFF ROAD DCSB
    3inch lift,285/75/16 on method 301's
    Yea I called my Toyota dealership and asked them how much the would charge to install a lift in my 14 yota and at first they said 700 to install a leveling kit and all would be covered under warranty. Well when I called to schedule my appt.they said that they made a mistake and that couldn't install any kind of lift. I then asked them how come they sell lifted trucks and he said that they have to be lifted by the Regional dept before they make it to the dealership.
    I just don't want to be stuck with a huge mechanical problem thats not covered under warranty so I guess I have to live without a lift!!! And that SUCKS!!!
  13. May 21, 2014 at 9:34 AM
    #53
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    I could see them saying you were beyond mileage with larger tires and no odometer adjustment.
  14. May 21, 2014 at 9:41 AM
    #54
    SkimSTI
    SkimSTI Well-Known Member
    Orange County CA
    '14 MGM TRD dblcab & '16 Mercedes C450
    Magnaflow exhaust, AFE stage 2 intake, King 2.5" resi coilover/rear shocks, Pro Comp UCA's, Deaver 1.5" leaf pack, BPF raptor style grill
    this wasn't recent, but yearrrrs ago, when i owned a 2004 dblcab, i got a king coilover kit shortly after purchasing the truck..
    the brakes went out wayyy prematurely. i want to say about 8 thousand miles into it. took it to the dealer i purchased from and they told me my lift was causing a premature brake failure (i have had lifted trucks before, i have never heard of a lift causing premature brake wear)... so i argued. They kept denying me for warranty.
    i eventually argued enough that they replaced them, no charge, just to get me out of their hair..
    fast forward, to the new set of brakes, another 5-8k miles go by. the new set is shot.... go back again, same argument and them trying to deny my claim blaming the lift etc etc etc...
    called toyota corporate. shot a few emails. eventually i got another set of brakes. then it was good after the 2nd brake job..... what a nightmare that was. i hate dealerships.
  15. May 21, 2014 at 2:40 PM
    #55
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    Seems to me, you're on the hook for the sensors, if you bought and installed 20's without them.
    About 8 pages of good info on TPMS and Clone-able Sensors here:
    TPMS Options for Multiple Wheel Sets (I.e., Winter/Summer, Street/Off-Road, etc.)
    Schrader EZ-Sensor Programmable TPMS Available at Amazon for $50-$75 ea.
    You won't buy the TPMS Valves for Stock Tacoma Wheels, You'll have to research for proper sensors.
    Keep in mind that units that fit Steel Wheels are not interchangeable with Alloy Wheels.
    I like the system in my Tacoma, and have not had it light up once in 4 years.
    I do monitor my pressure frequently, for the purpose of tire wear and ride.
    So I know if I see the TPMS light, I've got a problem.
    CC
  16. May 21, 2014 at 2:54 PM
    #56
    TripleThreat
    TripleThreat Vance@freevancewriting.com
    They keep callin me cowboy but its not my name...
    Socal but I am still a southern Florida guy
    Toyota Tacoma 4x4 slightly modified
    nothing special.... wanna race?
    They noticed I rewired most of the truck including the stand alone ECU so they said my warrenty was voided cause they could'nt diagnose the truck but all they were doing was rotating my tires why should it matter if you can plug in the ecu or not? They gave me the coupon for free tire rotation and I thought they just wanted to check for warning lights and computer error codes so they get some free business and I told them that. I got my tire rotation in the end and they still won't work ony my truck I don't think an oil change needs an ECU either but I guess im not a mechanic but neither are they. They are technications.. :D
