Who has done aftermarket dash and cluster lights?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2004TacomaSR5, Dec 4, 2014.
  1. Dec 4, 2014 at 10:09 PM
    2004TacomaSR5
    2004TacomaSR5 [OP] Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    In short, I hate the orange cluster and stereo/climate control backlights. Some are burnt out in the cluster so I have an excuse to change them. Has anyone here put a different color light back in instead of the OEM orange? I am thinking either blue, green, or blacklight if I can get it. Let me see what you all have.
  2. Dec 4, 2014 at 10:25 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
  3. Dec 4, 2014 at 10:26 PM
    Drew5387
    Drew5387 You can't fix stupid
    Drew
    Kansas
    03 PreRunner SR5 DC Black
    Raptor Style Grill, KC Highlight Spot Beams, 2.5% Window Tint, Kenwood Touchscreen Head Unit, Train Horn, Tinted Tail Lights, Retrofit Source Projectors with Halos, BHLM, LED Fog Lights, 40" LED Light Bar, 33" Cooper STT Tires, Herculined Rocker Panels, 175+ hp in stickers
  4. Dec 4, 2014 at 11:01 PM
    2004TacomaSR5
    Jon
    Montana
    Love it, where can I find lights like that?
    Rldanie likes this.
  5. Dec 4, 2014 at 11:02 PM
    2004TacomaSR5
    Jon
    Montana
  6. Dec 4, 2014 at 11:04 PM
    TashcomerTexas
    He has all kinds of lights interior and exterior. Ask him whatever you need
  7. Dec 4, 2014 at 11:45 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    I replaced the 4 main bulbs in the instrument cluster with red LEDs. Matches close enough to the rest of the truck.
    So, for what you want to do, just pick the color your want for the instrument cluster. As for the other bulbs, have fun - it's about $1 per LED and there is probably a few dozen if you actually take the stereo apart...
    These little guys:
  8. Dec 5, 2014 at 6:34 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    cluster bulbs are #194. I believe the hvac bulbs are a NEO4x. The little lights for the auto shifter and misc are a 74.
    I need to take other pics but this was during the install. I had to adjust the #3 metal contact plate cause it was loose (that's why light is out).
  9. Dec 5, 2014 at 6:35 AM
    JustinL
    JustinL Well-Known Member
    Justin
    Berlin, CT
    2009 TRD OffRoad DCSB Pyrite Mica
    2012 Conversion
    Jerez on here has done dash lights as well
  10. Dec 5, 2014 at 8:50 AM
    stikle
    stikle Well-Known Member
    Seth
    The Sovereign State of Eastern Oregon
    1997 LX Xtracab 4x4 V6 3.4L
    Eh, see my Build Thread sig link. Too many mods to list.
  11. Dec 5, 2014 at 9:58 AM
    2004TacomaSR5
    Jon
    Montana
    White looks pretty damn good also.
    That's really bright! Wow what an improvement.
  12. Dec 5, 2014 at 10:56 AM
    mwrohde
    mwrohde Well-Known Member
    Sugar Hill, GA
    2003 Tacoma 4x4 5-speed 3.4 TRD SR5
    Are they dimmable?
  13. Dec 5, 2014 at 11:00 AM
    JasonLee
    15 TRD OffRoad
    The LEDs I bought from Superbrightleds.com dim no problem. They even fully turn off like the original bulbs did when you turn the knob all the way.
  14. Dec 5, 2014 at 11:51 AM
    stikle
    Seth
    ^^this
    How bad? There is no effort at all....after you pull your dash apart and get the cluster out. Swapping the bulbs takes seconds after that.
    Test before you put everything back together. If an LED doesn't light up, turn it around.
  15. Dec 5, 2014 at 2:48 PM
    2004TacomaSR5
    Jon
    Montana
    Is there a thread for it somewhere?
  16. Dec 5, 2014 at 3:19 PM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
  17. Dec 8, 2014 at 9:11 AM
    BeaverYota
    BeaverYota Oregon State Edition
    Josh
    Lake St. Louis, MO
    Sold...
    Without checking the other linked thread really quick, when you say pull the dash does that include the stereo or just the dash above the steering wheel? I'd be interested in changing my bulbs, but I have pulled out my stereo so many times doing wiring and whatnot that I get tired of having to pull it out and put it back together....
  18. Dec 8, 2014 at 9:22 AM
    Mrogers33
    Mrogers33 The way is open, the time is now
    Columbus, OH
    03 doublecab 4x4 grocery getter
    I just recently replaced the 4 main cluster bulbs behind the speedo/etc. Disassembly of the dash, following two separate walkthroughs, was unclear at best but fairly simple, only needing a couple different screwdrivers & 10mm socket. All of the securing bolts are pretty spread out, so if something wont budge, its probly still screwed in. Just start at the radio and work your way down and out. I only broke the two push in clips on the sides of the cover piece way below the ash tray, and somehow still had a screw leftover when put back together. Took me about 1-1.5 hours to disassemble going pretty slow and trying not to break anything.
  19. Dec 8, 2014 at 9:24 AM
    2004TacomaSR5
    Jon
    Montana
    Think it depends what you want to do. If you want to do both, then yes you will have to take apart both. This is my case and I want to do both but am not sure how much different the process is on 2nd gens to first gens.
  20. Dec 8, 2014 at 10:34 AM
    BeaverYota
    Josh
    Lake St. Louis, MO
    Sold...
    Probably would just be the dash behind the speedometer. So if I didn't have to remove the stereo to do that it would be awesome
