Who has done aftermarket dash and cluster lights?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2004TacomaSR5, Dec 4, 2014.
  1. May 2, 2016 at 1:54 PM
    #541
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    She got filled up the next day lol
  2. May 2, 2016 at 2:05 PM
    #542
    Scoobarooo
    Scoobarooo Well-Known Member
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    3" OME/Bilstein, Retrofits, Custom Bed rack/Toolbox, Amsoil Everything, tons of others.
    Bahaha. I did the same as you. White. But I bought cheap LEDs and they're not as bright anymore. So lesson learned
  3. May 2, 2016 at 2:29 PM
    #543
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    I paid $60 for 6 bulbs. I definitely didn't cheap out on this lol
    alphabravo likes this.
  4. May 2, 2016 at 2:30 PM
    #544
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    Oh, you see... I paid $6 for 10 bulbs.
    Tomji likes this.
  5. May 2, 2016 at 2:36 PM
    #545
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    Damn
  6. May 2, 2016 at 2:37 PM
    #546
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    Yeah, go Amazon. I'll have to buy those from Chris when I go to replace them.
  7. May 2, 2016 at 3:28 PM
    #547
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Dont care what bulbs they were thats overpriced big time.
  8. May 2, 2016 at 4:17 PM
    #548
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    Sorry I don't like to cheap out on some things.
  9. May 2, 2016 at 5:49 PM
    #549
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    It's worth spending the extra buck on LED bulbs when you have to pull half of your dash apart or take your HVAC area apart just to have a bulb burn out cause you went cheap! I've never had a problem and bought all my LED bulbs from...
    I agree. It's worth spending money on LED bulbs that are of quality not quantity unless you like tearing apart your dash and HVAC area numerous times because of a cheap burnt out bulb. I got all my LED bulbs from...
    jnossoff likes this.
  10. May 2, 2016 at 5:49 PM
    #550
    Sicyota04
    Morgan
    California
    04 DC 4x4
    Never let me down yet
  11. May 2, 2016 at 6:00 PM
    #551
    devinzz1
    devin
    2023 aclb trd or mt
    Takes like 5mins to pull dash and you can Change all but one without removing it. Spent maybe $2 on a pack if 10 thats been in almost a year now. I keep them dimmed cause their too bright most of time.
  12. May 2, 2016 at 6:05 PM
    #552
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    What do you mean by this? Changing bulbs without removing the cluster?
  13. May 2, 2016 at 6:06 PM
    #553
    devinzz1
    devin
    2023 aclb trd or mt
    Just remove cupholds and 90 degree ducting elbow. Its on with 1 screw
  14. May 2, 2016 at 6:14 PM
    #554
    FirstGen Jer
    Jeromey
    Sorry still don't know what your talking about. To replace my bulbs I had to remove the radio bezel, steering colum cover, plastic cover under the steering wheel, and unscrew the cluster from the dash.
  15. May 2, 2016 at 6:18 PM
    #555
    devinzz1
    devin
    2023 aclb trd or mt
    Remove radio bezel/trim/cupholers. Behind radio theres the ducting that goes to vents above radio, remove it. You can then reach your arm in and access most of the dash.
    Edit: this how youd reconnect the speedo in older models with a cable aswell cause they give you absolutely no slack.
    FirstGen Jer[QUOTED] likes this.
  16. May 2, 2016 at 6:53 PM
    #556
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    Your truck is a 96 mines an 02. Its completely different when it comes to dash layout and all. You can't change any without taking everything but the top of the dash off :laugh:
  17. May 2, 2016 at 6:55 PM
    #557
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    BTW I priced out the LEDs on superbright before buying these. Add in shipping, then having to wait for em. I just went ahead and spent an extra $10-$15 bucks and got the "super bright" ones from the parts house.
  18. May 25, 2016 at 7:54 AM
    #558
    KeptOnChooglin
    KeptOnChooglin Well-Known Member
    Phil
    Houston, TX
    2003 Crew Cab PreRunner L4 Auto
    One of my superbrights in the HVAC cluster has been starting to go off for periods of time. I have a couple options since I did order a 2002 4Runner HVAC for the plate, and it has green bulbs. I may just swap it out.
  19. May 26, 2016 at 7:09 AM
    #559
    cynicalrider
    cynicalrider #NFG
    Jersey
    I feel like it might just be loose, I seem to have the same issue but haven't fixed it yet.
  20. May 26, 2016 at 7:12 AM
    #560
    KeptOnChooglin
    Phil
    Houston, TX
    Probably, its had a habit of going on/off after a bump.
