Who has good ears and a good idea
Discussion in 'Suspension' started by Mitch, Apr 15, 2014.
  1. Apr 15, 2014 at 7:33 PM
    Mitch
    Mitch [OP] Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    This is an awful sound that I have coming from the front of my 2007 Tacoma Access Cab V6 4x4.
    I've got Icon 2.5 coil overs with 650# coils and Light Racing Upper Control Arms. Everything is aligned and tightened.
    Tell me what this sound is
    http://youtu.be/pjV65dmqArk
  2. Apr 15, 2014 at 7:45 PM
    MrGrimm
    MrGrimm Mall Crawler
    Dean
    Wisconsin
    2006 Toyota Tacoma 4WD w/TRD Sport Package
    See build page
    How much thread is showing on your coils?
  3. Apr 15, 2014 at 7:52 PM
    Mitch
    Mitch
    Spokane, WA
  4. Apr 15, 2014 at 8:09 PM
    DPC08
    DPC08 Well-Known Member
    FL
    09 DCSB
    Getting there...
    I have the same coilovers but uniballs. Mine made a noise like that, but went mostly away after lubing the uniballs. I think there might be some coming from my leaf pack as well. Do you have aftermarket leafs/AAL?
  5. Apr 15, 2014 at 9:02 PM
    Mitch
    Mitch
    Spokane, WA
    I have the Icon AAL. My sounds is 100% coming from the front
  6. Apr 15, 2014 at 10:17 PM
    splitbolt
    splitbolt Well-Known Member
    Ozarks
    2016 TRD OFFROAD DCSB MGM
    Is this a new install?
  7. Apr 15, 2014 at 10:47 PM
    Mitch
    Mitch
    Spokane, WA
    Negative. About 10 months ago.
  8. Apr 15, 2014 at 10:59 PM
    splitbolt
    Ozarks
    Have you checked the LR UCA bushings for binding?
  9. Apr 15, 2014 at 11:31 PM
    Mitch
    Mitch
    Spokane, WA
    Please explain.
  10. Apr 16, 2014 at 5:53 AM
    splitbolt
    Ozarks
  11. Apr 16, 2014 at 8:58 AM
    Hawksdenn2
    Hawksdenn2 Well-Known Member
    Fort Lauderdale
    Lifted 10' SR5 4x4
    3" ultimate lift kit, diff drop, total chaos uca's, 1.5 aal, 5100 rear shocks, cmc, 2" fender and flare chop, roof rack, 2-10's, kenwood touch screen, antenna-x, wet okole, de-badged, ARE topper, 60" hi-lift, off road base and recovery kit. 315/70/17 nitto trail grapplers, XD addicts 17" BHLM, rear diff breather mod.
    Mine makes the exact same sound but only sometimes, no clue
  12. Apr 16, 2014 at 11:29 AM
    Mitch
    Mitch
    Spokane, WA
    I just checked. I've got no play in the UCA or the ball joint. The bolt are tight and not over tightened. I'm wondering if I have enough grease in the ball joint itself.
  13. Apr 18, 2014 at 5:20 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    06 DC 4x4 TRD Off-Road
    I had a similar noise. It was my LR UCAs. I had to remove the old bushings and install the "spec ride" bushings.
    Newer LR UCAs already come with those bushings installed.
  14. Apr 18, 2014 at 6:11 PM
    Mitch
    Mitch
    Spokane, WA
    I've got the Spec Ride bushings. I'm worried its my shock. I greased the lower mount today and that helped when going over bumps at slow speeds. But when I hit a speed bump above 30mph I get this sound.
  15. Apr 18, 2014 at 9:44 PM
    LTDSC
    LTDSC Trophy Van
    Sam
    NorCal
    you say you're cranked just a little but are any of the coils possibly rubbing on eachother? What about the top hat bushing have you greased that? It might pivot like the lower one when moving.
  16. Apr 19, 2014 at 9:26 AM
    TacoDeLaPlaya
    TacoDeLaPlaya Total Automotive Performance Sleeper Cell
    Bobby
    Del Mar, CA
    06 Silver Access cab
    Custom sotoshi deep dish grill 6112 front 5100 rear Leer 100xl
  17. Apr 19, 2014 at 4:36 PM
    Navar
    Navar Well-Known Member
    Corona CA
    07 Tacoma TRD Sport 4x4
    Washed it, Icon suspension, Icon UCA
    Lube the uniballs on the UCA with WD40 or Triflo something like that
  18. Apr 19, 2014 at 4:49 PM
    ndcmack
    ndcmack Well-Known Member
    NICK
    Western Washington
    BSP 4x4 TRD Sport DCSB
    Not enough
    it's not a Uniball, he's got ball joints.
    Mitch I've listened to it a few times now and my thought has been lower ball joint every time I've watch it... Maybe get the needle fitting for your grease gun and add grease:notsure:
  19. Apr 19, 2014 at 5:21 PM
    Navar
    Corona CA
    I am referring to the uniballs if he has aftermarket UCA's
  20. Apr 19, 2014 at 5:23 PM
    Navar
    Corona CA
    Do you have stock or aftermarket UCA?
