Who has installed the K&N 77-9039 KP Intake for the 3.5l Taco?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DreyeZ, Sep 15, 2016.
  1. Sep 15, 2016 at 9:55 AM
    DreyeZ
    DreyeZ [OP] New Member
    Juan Diego
    2016 Silver DCSB TRD Sport 4x2
    ECU mods, 77-9039 K&N CAI, LED Foglights and LED Lowbeam Headlights!
    I've just finished installing the mentioned CAI on my Taco, but i think it's too noisy at the cabin. Is it normal?
  2. Sep 15, 2016 at 9:58 AM
    elduder
    elduder Well-Known Member
    Van WA
    2019 Voodoo Blue Tundra TRD Pro
    Yes. Is the 77 the one with the metal intake arm? If so it'll be even louder than the plastic armed intake, which is already loud.
  3. Sep 15, 2016 at 10:00 AM
    DreyeZ
    Juan Diego
    Ouch! So do you mean it's mor comfortable the 63 series?
  4. Sep 15, 2016 at 10:03 AM
    elduder
    Van WA
    Comfortable?
    I had both the plastic and metal K&N intakes on my old FJ at one point. The metal one was much louder.
    DreyeZ[QUOTED][OP] likes this.
  5. Sep 15, 2016 at 10:04 AM
    timothom
    timothom Well-Known Member
    2014 Tacoma Access cab sr5
    Kenwood DMX7705S PrecisionPower Phantom 900.4 Alpine type-r 8" Image Dyanmics CXS64.2
    Did it make any noticable difference in power or mileage?
  6. Sep 15, 2016 at 10:06 AM
    Midknight
    Midknight Well-Known Member
    Western Canada
    2018 TRD Off-Road
    Out of curiosity, what is the purpose of an aftermarket CAI on these? Is there a tune out there that makes use of the additional air flow, or is this just for sound?
    I had an APR CAI on my gti, but without a tune there were no noticeable gains in performance.
  7. Sep 15, 2016 at 10:09 AM
    elduder
    Van WA
    I cant say for the 3.5l since I dont have an aftermarket intake on my truck. The old 4.0 felt like it had a bit more pull at the top end, but it also felt like it had a loss of low end power in the summer. Heat soak most likely.
  8. Sep 15, 2016 at 8:35 PM
    officialtlong
    officialtlong Active Member
    Travis
    Puyallup, WA
    2019 Pro Voodoo (Sold 2016 OR - Stolen 2014 Sport)
    I just pulled my K&N plastic model off due to the noise. It definitely added power but I am fairly certain your ECM will compensate for increased airflow with increased fuel so no there is no MPG increase with these, at least I did not notice any. Very fun to have when you are trying to enjoy the roar but when you are just trying to cruise and the truck has to downshift *cough* it gets old. I also have the Magnaflow exhaust and at more than 50% throttle the engine would drown out the exhaust!
  9. Sep 17, 2016 at 10:31 AM
    safari_shawn
    safari_shawn Well-Known Member
    SHAWN
    3rd Gen Tacoma DC TRD Off Road 4X4
    Currently stock
    Yeah, everything is proportionate in the intake. so unless you are cramming so much air in that your injectors cannot compensate (which will cause you too run lean and F-up your engine), you will not get amazing mileage benefits. the trick is to drive ultra-conservatively but that extra "growl" is going to keep you from doing that.
  10. Sep 17, 2016 at 10:37 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    There are two things CAIs do on naturally aspirated Tacomas:
    1. Delete the resonator in the OEM intake so the engine sounds louder.
    2. Some CAI models space out the MAF sensor a bit more.
    Basically, installing a CAI then complaining it's too loud is crazy talk :p
