who has the best prices on balljoints, tierods, etc?
Discussion in '1st Gen. Tacomas (1995-2004)' started by mystik cabs, Oct 13, 2015.
  1. Oct 15, 2015 at 2:14 PM
    chowwwww
    chowwwww Well-Known Member
    Orange County
    03 Doublecab 4x4
    Billys 5100/Eibach and Wheelers Progressive 1.5 AAL with overload in
    Decided to go online and check my trucks service history. Found this:
    SSC 30H 2001-MID 2003 TACOMA DOUBLE CAB-INSTALL FUEL HOSE PROTECTOR, 50J BALL JOINT,CK/ADJ WHL
    50J Ball Joint was the recall correct? This was done at 60k. My truck now has 150k. I jacked up the truck a few months ago and placed a pry bar between the arms to see if there was any movement around the LBJ, didn't see any or feel any movement. Should I just go ahead and replace the LBJ anyways?
  2. Oct 16, 2015 at 7:05 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    if there's no movement leave it alone. looks like yours was replaced with the better ones back in the day so should be good with only 90k on it.
  3. Oct 16, 2015 at 1:52 PM
    mystik cabs
    mystik cabs [OP] Well-Known Member
    Brian
    North Stonington, CT
    '04 TRD DBL Cab
    Is this the correct Toyota part # for an '04 SR5 DBCSB TRD 4x4? "LOWER BALL JOINT - 2004 Toyota Tacoma (4334039585)"
  4. Oct 17, 2015 at 10:21 PM
    Jacob
    Jacob Well-Known Member
    I'm in the middle of replacing mine. 185k miles on a 1999. Was doing suspension but decided to do ball joints, tie rods, everything. Went with the OEM ball joints and tie rod outers, and Moog for the tie rod inners (because they were way less than the OEM's). My LBJ's were seemingly fine (no torn boots, no movement, etc), but figured I'd replace them since I was doing all of the other work.
  5. Oct 18, 2015 at 6:26 PM
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    A member here cut up a couple different ball joints to show us the quality of the parts. I was already convinced on buying Toyota ball joints but his informative post reinforced that idea. For other stuff like outer and inner tie rods , bushings ,etc I will prob go aftermarket tho.
