who has toytec ultimate lift with 2" AAL
Discussion in '1st Gen. Tacomas (1995-2004)' started by socal19, Mar 9, 2010.
  1. Mar 9, 2010 at 10:11 PM
    socal19
    socal19 [OP] TACOMA03
    California
    03 tacoma pre runner
    2.5" Front spacers, 16inch wheelers steel wheels on 265-75-R16 BFG All Terrain, N-FAB prerunner bar, Flowmaster Exhaust
    Hey I wanted to know the people with the ultimate lift with the 2"AAL's in the rear I got a question.....if you have the coilovers adjusted to 3" and with the 2"aal in the rear will the back sit higher than the front??? Just wanted to know cause I'm going to get the ultimate lift with the 2"aal so I wanted my front higher that the rear thanks for your help
  2. Mar 10, 2010 at 5:52 AM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    uhhhh....does the truck sit level now?? (yes) then if you raise the front 3 inches and rear only 2 inches which end of the truck will sit higher????
    Answer: the front
  3. Mar 10, 2010 at 7:36 AM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    well the truck comes with the rear about 1" higher then the front. But If you have been hauling alot of weight over the years and your springs have sagged then you might be more level.
    So that being said, If your rear is still higher then your front the 2" AAL will level out your truck with the front at 3" lift. I through in a 1" block to get my rear a little bit higher, its about 3/4" higher or so. Bc the AAL has settled. hope that helps ya!
