Who has Wheelers Offroad 1st gen replacement leafs?
Discussion in '1st Gen. Tacomas (1995-2004)' started by scocar, Mar 16, 2010.
  1. Mar 16, 2010 at 10:22 PM
    scocar
    scocar [OP] Patron of the Farts
    A bunch of us are interested in hearing about your experience with a few particular Wheeler's Offroad products (all made by Alcan) for a possible group buy:
    95-2000 4-leaf replacement pack, stock ride height
    95-2000 5-leaf replacement pack, 1.5 lift
    2001-2004 4-leaf replacement pack, stock ride height
    2001-2004 5-leaf replacement pack, 1.5 lift
    I heard some complaints about breakage from 1 person on a few different sites, but that may have been related to rust-seized shackles or who knows what.
    I have already searched a lot and it seems TW members have bought some of these, or said they were going to, but they haven't specified exactly which product or shared results.
    And yes, before everyone starts swearing up and down about OMEs and Deavers, chill. We are looking for stock or close to stock ride height and weight capacity, and don't want to break the bank.
    A lot of us would really appreciate your firsthand accounts about these Wheeler's Offroad products:
    -Durability?
    -Ride quality?
    Help us make a good decision and save some money.
    And we really don't care how bad your farts smell or your what your sig looks like or if you got springs for a 2nd gen...
    Thanks!
  2. Mar 17, 2010 at 5:53 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    I am mainly looking for a alternative stock height replacement for my application. Tho I wouldn't mind something with ~1" lift since I have coilovers upfront.
  3. Mar 17, 2010 at 8:11 AM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    I didn't have the wheelers specific ones, but I had Alcans on mine that I ordered from Alcan itself and kept the height stock. They were on until I had my frame replacement done, and I ended up selling them, but I really liked them. Alcan makes a good quality spring, and I hauled some pretty heavy loads in it a few different times with no sagging, much less breaking.
  4. Mar 17, 2010 at 8:47 AM
    scocar
    Bumpity bumpity bump....:pccoffee:
  5. Mar 17, 2010 at 9:28 AM
    scocar
    Bumpalicious...:taco:
  6. Mar 17, 2010 at 9:33 AM
    IamJorgeEdward
    IamJorgeEdward Well-Known Member
    Jorge Edward
    Orlando, FL
    2015 Toyota Tacoma TRD Sport
    Completely stock
    sir bump-a-lot?
  7. Mar 17, 2010 at 2:32 PM
    scocar
    Uh, 2:31 bump...
    Bumpraham Lincoln.
    :boink:
  8. Mar 17, 2010 at 2:33 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i have their 5 pack leaves....coupled with some ome 881 coils. nice setup...ride is great.
  9. Mar 17, 2010 at 2:36 PM
    IamJorgeEdward
    Jorge Edward
    Orlando, FL
    Completely stock
    FINALLY AN ANSWER:bananadance::taco:
  10. Mar 17, 2010 at 2:38 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    :D
  11. Mar 17, 2010 at 2:41 PM
    da0023
    da0023 The One, The Only
    Drew
    Alabama
    99 PreRunner SR5
    none
    i got their stock replacement to try to rid my truck of the dreaded axle warp, but it did not resolve the problem. as far as ride, so-so.
  12. Mar 17, 2010 at 2:52 PM
    scocar
    Hmmm, axle wrap is a major reason for doing this...was that the 4 or 5-leaf pack?
  13. Mar 17, 2010 at 2:53 PM
    da0023
    Drew
    Alabama
    99 PreRunner SR5
    none
    4 my friend.
  14. Mar 17, 2010 at 2:56 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    my 5 pack got rid of a good amount of mine....but its still a good idea to grease the slip joint where the shaft comes outta the rear diff. i took mine apart from the diff there at the u joint....slid it apart,cleaned it real good...packed full of grease, reinstalled and then regreased......takes the axle wrap away pretty good. it needs to be done every so often. its a normal thing on the first gens.
  15. Mar 17, 2010 at 2:59 PM
    da0023
    Drew
    Alabama
    99 PreRunner SR5
    none
    so you actually unbolted your shaft and slid it out and greased it?
  16. Mar 17, 2010 at 3:01 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah.....it wasnt too hard to do. gotta mark where you take it apart tho...keep it lined up. i used a yellow paint pen. there was alot of old grease in there that was more or less like jello.........not doing its job. plus, part of my shaft was rusty, so i used a bit of sand paper and some anti seize on it.
  17. Mar 17, 2010 at 3:04 PM
    da0023
    Drew
    Alabama
    99 PreRunner SR5
    none
    i'll give it a shot
  18. Mar 17, 2010 at 3:09 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    cool....let us know how it goes. and a heads up...the shaft may turn some........put the truck in neutral and lock the parking brake if you have an auto to line it back up and bolt it back up.
  19. Mar 17, 2010 at 3:34 PM
    da0023
    Drew
    Alabama
    99 PreRunner SR5
    none
    thanks for the tip. i will try to do a write up on it.
  20. Mar 17, 2010 at 3:36 PM
    ST77
    ST77 Wandering doesn't mean you're lost
    Brian
    Sandy, Or
    2018 TRD OR DCSB
    Bone Stock
