Who Here Still Uses Dealer Service?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ridgerunner, Jan 10, 2019.
  1. Jan 10, 2019 at 7:32 PM
    Ridgerunner
    Ridgerunner [OP] Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    I'm taking the old Tacoma in the morning for a full-on service. Everything I want done falls within a thing they call the "150,000 mile service" that's gonna cost $1200.
    I have to because I can't do stuff myself anymore like I used to. Wish I could.
    So this service includes
    oil change
    trans flush
    radiator flush
    rear diff service
    new plugs
    32 point inspection
    new air filter
    tires rotated
    and some other stuff I don't recall.
    I know that's a hell of a lot of money but I feel my truck's well worth it.
    Anyone else here still take it into Toyota for stuff?
    GQ7227 and Oldie2007 like this.
  2. Jan 10, 2019 at 7:33 PM
    4drtaco03
    4drtaco03 Well-Known Member
    BAY AREA
    2003 TRD/ 2004 / 2019 SR5 4x4… now awd sprinter
    Your in SF? Don’t go to dealer go to TOYSHOP they do way better job for the cheaper
    outlawtacoma and Oldie2007 like this.
  3. Jan 10, 2019 at 7:34 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    I never taken any of my vehicles to the dealer for service.
    Hamer95USA likes this.
  4. Jan 10, 2019 at 7:37 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    I've been wondering about that place for years. I saw they have some great reviews in Yelp.
  5. Jan 10, 2019 at 7:40 PM
    Oldie2007
    Oldie2007 Well-Known Member
    Kurt
    Lockhart, TX
    I've gotten a little old for some of those things, but 30% could still be DIY. Your local friend has a suggestion that is good, local places that do a good job for less - they don't have to support the dealer mark up. I like my records on my old used beast, so I am on Toyota.com for record support, and my old dealer service still treats me like a customer. Compromise on the price, not the service and records.
  6. Jan 10, 2019 at 7:41 PM
    jnossoff
    jnossoff 2000 Xcab Pre-Runner with Leer 122 shell
    Joel
    Albuquerque NM
    2000 PreRunner SR5 TRD Xcab V6 A/T
    Took my vehicle to the dealer for a common cold; they treated it for Cancer. Never Again.
    Exception: when my regular independent mechanic could not solve a faulty airbag/seatbelt alert in 2 tries, the dealer did it right the first time!
    Pervy likes this.
  7. Jan 10, 2019 at 7:41 PM
    4drtaco03
    BAY AREA
    There great always have landcruisers and Tacoma’s galory. They don’t always answer the phone so it’s great to just stop by. There are usually booked a couple weeks out but it’s well worth the weight.
  8. Jan 10, 2019 at 8:09 PM
    1997tacomav6
    Denver
    Dealer does all my oil changes, this way they check everything else while it’s on the rack,
    from alignment to battery, alternator, any leaks, brakes, rotor thickness, fluids, belts or anything they see that might need attention etc.
    And hard to do items like clutch, wheel bearings.
    Everything else I do.
    I have a specific master mechanic old school guy that does all the work and has for years now
    with a discount rate.
    Your quote sounds expensive
    Hamer95USA and DW85 like this.
  9. Jan 10, 2019 at 8:13 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Much of this could be knocked out at a local MOD Day. If you are unable to do the majority of the work anymore, most ppl at MOD Days (at least the ones I've been to) are happy to wrench on your truck. I can almost bet you could knock out the plugs, air filter, oil change and rotate the tires at one of them. Just bring eats and beer along with possibly a little something for the tip jar and I bet you could get this done.
    Have you followed routine maintenance on the trans fluid? If not, research those full flushes first. I have 160k some odd miles and one toyota dealer specifically suggested not to do the full flush. While my trans is fine and no issues (so far), I think iv'e only drained the pan 2x since owning it and had the fluid replaced. Never a full flush. So, I'm a bit on the fence with doing a full flush.
    The radiator flush isn't bad and certainly can be accomplished at home if you have garage access. I highly recommend this (makes the job much easier) -
    https://smile.amazon.com/gp/product/B00A6AS6LY
    I have found that Tim's videos (https://www.youtube.com/user/mtbtim65/videos?view=0&sort=dd&flow=grid) have been very helpful in tackling the job myself at home. Having a garage to work in certainly makes it easier - apartments or limited space (like San Francisco) would make it very difficult.
    You're right about one thing - the tacoma is worth it no matter who does the work. :thumbsup:
  10. Jan 10, 2019 at 8:23 PM
    1997tacomav6
    Denver
    Should be like this or so.
    oil change. 45.00
    trans flush. 200.00 maybe
    radiator flush. 95.00
    rear diff service. 125.00 per axle
    new plugs. 160.00 plugs are like 10.00 each
    32 point inspection 100.00 but should be free
    new air filter. 30.00 or so depending
    tires rotated. 30.00 or so
    So around 800.00 at the most.
    If you use the dealership you can find 10 percent discount coupon usually on the internet for Toyota service
  11. Jan 11, 2019 at 3:52 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    For some things, yes. Usually after Ive given up on a job beforehand. They do have the best deal on alignments though.
  12. Jan 11, 2019 at 4:22 AM
    hubcapsc
    hubcapsc Un-Known Stranger
    Upstate South Carolina
    2002 6cyl 4x4 manual
    I always take my 200,000 mile Mini Cooper to the dealer, they
    do a great job. When they do a X-thousand mile checkup, they
    occasionally find and tell me about other stuff that needs addressing,
    and I generally get them to go ahead and do it. It works great for
    me.
    I was at a near-by Toyota dealer yesterday, renting a Highlander
    for a family trip to a wedding the next state over... it seemed like
    a dealer I might want to take my Tacoma to, we'll see. It was the
    kind of dealer that has done many frame swaps, there was
    a Tacoma (not a gen1) there in the middle of a frame swap
    when I was there.
    My Honda Valkyries have each been to a dealer once or twice,
    I've learned there's no Honda dealers around here I'd want to take anything
    to, fortunately it is easy and fun to work on motorcycles.
    The Real Answer to the OP's question: it depends upon the dealer.
    -Mike
  13. Jan 11, 2019 at 6:24 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    To answer OP question(before I hijack thread), no I have never had service done at dealership. Mainly because I am able to do it. I think @97Tacomav6 prices seemed more reasonable.
    @hubcapsc
    I have never heard of a dealership renting cars. What state are you in and is this common?
  14. Jan 11, 2019 at 6:38 AM
    Ridgerunner
    Frank
    Rocklin, Ca.
    One of the bigger things I missed in the first post that deserves a mention is they're going to clean the throttle body. I figure that's a good thing that was never done to my truck. I'm headed there in an hour and thanks for all the suggestions.
    I'm doing this because I want that truck to remain top-notch even though it's semi-retired and sits a lot.
    Boerseun likes this.
  15. Jan 11, 2019 at 6:49 AM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    I take my vehicles to the dealer for oil changes and other work as needed. I don't have time to do my own work, even though I can do some of the basics. If I have to go buy oil and filter, then find time at home to do it, then go dispose of the old oil, it is cheaper and quicker to just drop it off at the dealer. They do their 12-point inspection while it is on the lift and do my tire rotations at the same time. I don't necessarily do all the services that they recommend, i.e. they will always come to me and say "you need a throttle body cleaning and transmission service and...." I use some common sense and know which of these items are needed or can be stretched out to longer intervals in between.
    I have also tried independent shops in the area and always had bad experience. At least the dealer techs are familiar with Toyotas as opposed to other guys that work on everything.
    Works for me.
    SilverBulletII likes this.
  16. Jan 11, 2019 at 8:12 AM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Mine does it. Its a way to get people into a newer vehicle. Let them drive it some, like it, then buy one. My family rents them for roadtrips all the time.
  17. Jan 11, 2019 at 8:40 AM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
  18. Jan 11, 2019 at 1:08 PM
    Luv my yota
    Luv my yota Well-Known Member
    00 turd lift 33's
    Kings,total chaos uppers, Deavers, JBA headers, Borla exhuast, engine mods, DC power 270 amp alt, 2k watts of sound, gps alarm.
    I agree with the above poster, you’ll gain huge piece of mind knowing you did your work and wallet will thank you. If you go the you tube route find and watch all videos pertaining to each job you do and spend your money on good quality oil and buy factory Denso parts, If you have to buy tools then you’ll have em forever. Then you’ll have the upper hand in a situation with your truck for the future.
  19. Jan 11, 2019 at 1:14 PM
    otis24
    Mark
    California
    Oh yeah, having an upper hand in a situation is a good point. I take my truck to remote areas like the desert or Baja every now and then. I'd really like to know how to fix it if it breaks.
  20. Jan 11, 2019 at 5:09 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    I got her home now. Idle's high. Usually around 850RPM, now about 1200RPM. Called them and they say the ECU will pick up on it and adjust itself. I like that cause it shows me they got in there and did the throttle body.
    Final price after 10% off was $1030 and I got a free filthy weenie Prius loaner for the day.
    Still a lot of money but i got:
    oil change/oil additive
    trans flush/trans additive
    radiator flush/coolant additive
    rear end fluid/LS additive
    throttle body cleaned/fuel additive
    new plugs
    new air filter
    new wiper fluid
    new blinker fluid :D
    cleaned battery terminals (I just did 'em two days ago)
    rotated tires
    41 point inspection
    $682 labor
    $472.87 parts.
    Luv my yota and Area51Runner like this.
