Who Is Right, Who Is Wrong? Theoretical Math Challenge!!
Discussion in 'Off-Topic Discussion' started by The Traveler, Mar 12, 2013.
  1. Mar 13, 2013 at 6:28 AM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    This. I have a gauge that measures injector pulse width. They never shut off completely when coasting in gear. They drop to about 1.9 ms when coasting in gear (measured in a 20ms pulse width, 20 meaning the injectors are firing 100% of the time and 0 meaning they're off). So they're on and pumping gas about 10% of the time when coasting. While coasting in neutral, they are about 2.0ms. Coasting in gear uses a tiny bit less fuel but you also get engine braking which reduces how far you can coast.
  2. Mar 13, 2013 at 6:32 AM
    TheHansen
    TheHansen Well-Known Member
    Mattapoisett, MA
    05 DC Sport
    dtrl mod Fog light mod Bed lights Under hood lights Rear window decals tint matched front windows Rear dif breather mod weathertech floor mats Bed mat Scan gauge 5100's and 885's lean spacer 1.5 in aal, 1" block and OME rear shocks Dynomax muffler (weld in) Truxedo lo pro qt bed cover Devil horn Emblem Plasti dip badges plasti dip radio plasti dip ac control all pro rear bumper with side pieces All pro front bumper All pro bolt on sliders illuminated 4x4 switch JBA long tube headers URD o2 Sim
    Think about what the energy losses are for each option.
    Friction (wind, road)
    Gravitational potential energy for the height
    I think going over hill will require more fuel than driving on flat ground because the hill is a longer distance traveled by the vehicle, thus more friction is experienced.
    For the second situation, i think the steeper hill will require less fuel than the less steep hill because the vehicle will incur less resistance due to friction of the whole distance traveled.
    In both situations gravitational potential change can be neglected because the net result will be equal for both vehicles.
    My results are assuming the engine is running at the same level of efficiency(not mpg, but fuel-> energy) regardless of the incline.
  3. Mar 13, 2013 at 6:40 AM
    Evil Monkey
    Robert
    Escondido, CA
  4. Mar 13, 2013 at 6:49 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    As far as I can tell, people who live in mountainous/hilly areas (up and down driving just as you're suggesting), get less mpg than those who live in flat lands. It's pretty self explanatory.
  5. Mar 13, 2013 at 7:03 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    for engines designed to turn off injectors...incorrect.
    you do not need fuel to keep engine turning and alternator providing power...
    in some specific circumstances...inertia and gravity provide the power
    some Hondas do this, and others...
    engine will be driven from the transmission keeping alternator turning and power on
    if engine speed is <>1200 rpm or higher and no throttle input
    some PZEV's turn off injectors 100% at specific speeds and conditions such
    as off ramps and downhills, and will restart fuel when rpm's drop.
  6. Mar 13, 2013 at 8:18 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Whats for lunch on this flight?
  7. Mar 13, 2013 at 8:20 AM
    SoCaltaco65
    btw, your injector shuts off on the other 3 cycles, Wink~
  8. Mar 13, 2013 at 11:05 AM
    The Traveler
    The Traveler [OP] Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    Looks like I need to move to Kansas.
  9. Mar 13, 2013 at 6:31 PM
    wileyC
    wileyC Well-Known Member
    Centerville, OH
    2012 PreRunner Double Cab TRD Sport
    ...i'd presume this analysis would need some further analysis on the "rules of the game"
    1) does the vehicle have to maintain a constant speed? a) over the flat route, and b) going up the hill?
    2) w/out knowing the answer to the previous question, ...what transmission is involved and what "gear" are we "in" and what "speed" are we going?
    3) does the vehicle going up hill have to stay above a minimum speed, or can it be allowed to slow down to a near stop at the crest, before being allowed to coast downhill? i.e. an uphill "coast" of sorts...
    4) what is the slope of the hill? this could determine what "gear" is needed, especially if the "uphill coast" notion is deemed not allowed..
    ...so in summary, i don't see a way to formulate an analytical solution to this w/out more boundary conditions and specific performance characteristics for the vehicle... if so it might make a good calculus problem... ;)
    ...depending on the slope of the hill, the intial speed, the characteristics of the vehicle, assume the flat route is taken at a constant initial speed, etc. ...the "uphill coast" method (i.e. start w/ initial speed at bottom of hill, and use just enough to make it to clear the crest, ...allowing speed to slowly fall off along the way..) might be feasible?...?...? but that is just my guess :D
  10. Mar 13, 2013 at 6:36 PM
    The Traveler
    SoCal
    LOLWUT.
    The title says "Theoretical"....lol I can't provide all the variables. Constant speed in both routes, gear would obviously change up hill.
  11. Mar 13, 2013 at 6:37 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    This is why you don't ask engineers 'theoretical' questions :D
  12. Mar 13, 2013 at 6:39 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Oh man , ain't that the truth , I can ask the PEng that does the structural / seismic work for me a yes or no question and get a minimum 10 minute answer
  13. Mar 13, 2013 at 6:41 PM
    Pugga
    Massachusetts
    We're good at those :D
    In his defense though, if you had given proper initial information and proper parameters, you would receive a simple yes or no answer :eek:
  14. Mar 13, 2013 at 6:45 PM
    The Traveler
    SoCal
  15. Mar 13, 2013 at 6:46 PM
    #35
    OZ-T
    Peter North
    British Columbia
    No no no , it's like this :
    " Do you want me to epoxy the rebar pins you've drawn on your plan into the existing concrete ? "
    Blah blah blah blah blah
  16. Mar 13, 2013 at 6:49 PM
    #36
    wileyC
    Centerville, OH
    that's right! ..."closed-form" solutions yield "definitive answers"... any analytical solution requires that there be at least as many equations as unknowns.. anything else kinda leaves ya guessing :D
  17. Mar 13, 2013 at 6:52 PM
    #37
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    In theory, the coasting you do downhill can be done on flat ground as well.
    In practical terms, you will not notice a difference because the distance driven on your home street should be a very small percentage of your overall driving. The difference may well be within the gas pump certification tolerance.
  18. Mar 14, 2013 at 8:02 PM
    #38
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    I was wrong.
    I was watching my Ultragauge more closely the last couple of days, and the only time it goes into open loop (once up to operating temperature) is under moderately firm braking.
    I'm assuming it's the decel that triggers it.
    And on a number of road trips I've monitored my trip-avg MPG and on longer grades I typically drop about 0.2 to 1 MPG by the time I hit bottom on the other side. There is certainly an increase on the way down, but not enough to offset the increase on the way up.
    In a perfect world with no wind or rolling resistance, only gravity, you could theoretically get a balance, but not in the real world.
  19. Mar 14, 2013 at 8:23 PM
    #39
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    I just think its funny you live on Broke Back Mountain!
    My bad, it says Brokebank Mountain.
  20. Mar 14, 2013 at 8:52 PM
    #40
    wmdpowell
    wmdpowell Well-Known Member
    Bill
    Essex county NY
    23 trd OR DCSB 4x4 silver
    a cross on my rearview Circle mirror Scotch guard seats
    Also consider the trip up up and over the hill is longer than the same trip on a flat (essentially the hill is two sides of a triangle vs the long side in the flat run)
