Who is running a ScanGauge II?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chosenfew22, Dec 24, 2014.
  1. May 4, 2022 at 5:01 AM
    #61
    Raylo
    Raylo Well-Known Member
    MD, USA
    2023 Tundra SR5 OffRoad; (2009 Tacoma - sold)
    All stock, except for audio and convenience add-ons
    I have ScanGage 2s on my Tacoma and my 2016 Vette. I love being able to see important parameters you can't get on the instruments.
    Question about TPMS on Tacoma... with the SC2 show actual tire pressures? I need to check into that.
  2. May 4, 2022 at 5:05 AM
    #62
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Yes, but you need firmware 4.45 or newer (I think). Their website tells you the exact version you need and gives you IDs to program in
    I sent my SGII in a few months ago so they could update it. Now I can read TPMS which is handy. Id say the monitors are +/- 3 PSI most of the time
    Raylo[QUOTED] likes this.
  3. May 4, 2022 at 6:23 AM
    #63
    Raylo
    MD, USA
    I sent mine in for firmware about a year and a half ago so I could get TFT when I needed to repair a transmission leak and refill it. IIRC programming that was a bit of a PITA. I am on FW 4.53 so hopefully it will also do TPMS. I'll be checking this out. It is really a PITA that SG doesn't allow OTA FW updates. The one thing I dislike about them.
    TRDSport10 likes this.
  4. May 4, 2022 at 10:22 AM
    #64
    Raylo
    MD, USA
    So, I went and programmed the tire pressure Xgages and it worked perfectly with FW 4.53. I had to use the second set of codes in the "method 1" table for my 2009 CANSF.
    One question: does anyone know which tire is which? All it says is Tire Pressure 1, Tire Pressure 2, etc. I assume TP1 is either driver or passenger front, then which way do they go from there? If we know that we can go in and edit our XGages to make them LFP, RFP. LRP, RRP or similar. I suppose I could go release air from tires one at a time to figure this out. But why recreate the wheel if one of you has already done it?
  5. May 4, 2022 at 10:34 AM
    #65
    SR-71A
    Zack
    Southern Maine
    Dont think there is any way to know other than changing pressure one at a time.
    I thought about doing that, but it would just change every time you rotate the tires anyway. So not sure its worth it
  6. May 4, 2022 at 10:42 AM
    #66
    Raylo
    MD, USA
    Wouldn't be too hard to make renaming them part of the rotation maintenance. I don't do that very often. Or once you have done this you can simply write down the new mapping after rotation and keep it with your manual in the glovebox.
    The other thing I need to check to see is if my XTool bidirectional scanner can reprogram or rename the TPMS sensors.
  7. May 7, 2022 at 12:08 PM
    #67
    BlkDakDave
    BlkDakDave Well-Known Member
    David
    CC TX
    07 AC PreRunner TRD/Off Road
    Response from SGII on my question to them about 6 weeks ago about TPMS readings.
    Kylie Antrosiglio
    Toyota does not specify the exact location of each sensor just simply label them as 1-5. The best way to determine which sensor applies to each tire is to take the physical reading and compare to the reported values on the ScanGauge. If you have any questions, please let me know.
    Regards,
    Kylie Antrosiglio
    Customer Service and Repairs
    Linear Logic LLC
    1.888.433.5664
    Linear Logic LLC
    1.888.433.5664
    Otterstuff likes this.
  8. May 8, 2022 at 5:27 AM
    #68
    Raylo
    MD, USA
    Yes, that's how both the ScanGauge and my XTool scanner report the tire pressure sensors. I am going to physically lower the pressure one at a time to identify the locations, them rename the XGage functions to be PLF, PRF, PLR, PRR. Then when I rotate the tires, I can just go into the ScanGage rename them again. That process is easy and fast once you've done it a couple of times.
  9. Jun 28, 2022 at 12:26 AM
    #69
    Motofox
    Motofox Well known hermit
    Stephen
    Northern California
    2014 DCLB
    custom pin-striping and dirt
    Finally got my scangauge and entered all 4 trans temp codes from their website in (one labeled trans temps and the other trans temp alternates) all for the 2010+
    But only one of those monitors is giving me temps. I double checked all the numbers and have entered them in correctly. So im continuing my troubleshooting
    Any ideas anyone?
  10. Jun 28, 2022 at 3:02 AM
    #70
    Raylo
    MD, USA
    In my experience that is how they work. You have to try the recommended TFT codes to find the one that works. They won't all work and for some reason they can't tell you exactly which one you need.
  11. Jun 28, 2022 at 7:09 AM
    #71
    SR-71A
    Zack
    Southern Maine
    For your truck these codes should work
    Motofox[QUOTED] likes this.
  12. Jun 28, 2022 at 2:09 PM
    #72
    BlkDakDave
    David
    CC TX
    I've contacted Scan Gauge with questions and they responded pretty quick. You might want to give them a try.
