who is the AXE expert here? sharpening an axe...
Discussion in 'Guns & Hunting' started by aficianado, Dec 3, 2012.
  1. Dec 3, 2012 at 2:39 PM
    aficianado
    aficianado [OP] Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    i have a GREAT axe. it is sharp enough i think i can prepare food with it. it will turn paper into ribbons.
    cleaning my garage, i found an old abandoned axe. a smaller hatchet. i bet it is my mother in laws. we used it to install sod at her house. (yes, and axe is the a great tool for shaping odd sod patches)..
    well, it is chipped, nicked..dull as a butter knife. i attacked it with a flat file. i am close, but it wont get paper slicing sharp. i am moving to finer and finer stones..but no luck. any tips?
  2. Dec 3, 2012 at 2:53 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Lots of patience. :cool:
    I'd say water wheel but I'm guessing you don't have one of those laying around... :rolleyes:
  3. Dec 3, 2012 at 3:17 PM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    It "may" be just cheap steel. Sounds like your going about the correct way. Keep us posted.
  4. Dec 3, 2012 at 3:21 PM
    ds46000
    ds46000 Well-Known Member
    07 PreRunner TRD Sport
    keep at it with the flat file. You need to reach the apex and form a good burr (which of course you will remove) with the coarse stone/file, before moving to finer stones. Otherwise, you aren't really doing anything by going to the finer stones...you're just making a dull edge a bit smoother.
    Keep filing both sides until you've got a good burr along the entire edge all the way from one end of the blade to the other...you should be able to feel it with your fingertip. If not, use a cotton ball or something to test for the burr. Then, a couple swipes with the coarse stone on each side to remove the burr (light pressure) and then continue to use your other stones to refine the edge.
    Just be patient and keep at it with the coarse file though first.
    Good luck, let us know how it turns out.
  5. Dec 4, 2012 at 9:32 AM
    aficianado
    back to bone stock.
    i just learned alot about flat files. i have been doing it wrong. and my file sucks.
    thanks.
  6. Dec 4, 2012 at 9:40 AM
    Pugga
    Massachusetts
    Uhoh... Were you using the flat file in both directions, in a sawing motion instead of one direction only?
  7. Dec 4, 2012 at 10:03 AM
    aficianado
    back to bone stock.
    yup ^^this. and i didnt have that brush to clean the file. i use them to flatten out my broadheads..i am positive the soft arrow-head material is clogging the file.
    and my file is junk to begin with.
  8. Dec 4, 2012 at 10:04 AM
    aficianado
    back to bone stock.
    i cant believe it never dawned on me..heck my cheese grater is one direction only. hahah
  9. Dec 4, 2012 at 10:10 AM
    Jon850FL
    Jon850FL is Lurkin'
    Jon
    DFS, FL
    Axe smells so good in the shower!
  10. Dec 4, 2012 at 10:29 AM
    aficianado
    back to bone stock.
    not if you're over 30 years old....:)
  11. Dec 4, 2012 at 10:57 AM
    TacoDaTugBoat
    TacoDaTugBoat Well-Known Member
    Goshen, Ct
    13 DCLB TRD Sport
    Just pointing out that you don't need an ax to be sharp enough to slice paper. It is meant to split one piece of wood into 2. The first couple swings into a piece of wood and you will dull it down quite a bit. They actually recommend steeper angles for ax's than knives.
  12. Dec 4, 2012 at 11:00 AM
    Pugga
    Massachusetts
    Depends on what you're using it for. If you want it as a cutter, sharp is good. For splitting, sharp doesn't matter at all, it's just got to be a wide wedge and heavy helps.
  13. Dec 4, 2012 at 11:05 AM
    aficianado
    back to bone stock.
    dont assume i am only using it to split wood :D
    there is plenty of debate on this. some argue that a razor sharp axe will cut easier with less effort and be safer to use. same argument for a knife.
    i got an axe to use as a multipurpose tool. splitting wood will be only one use. the strength of an axe edge is the round bevel. i will use mine to butcher animals truck-side. sharp is an advantage. skinning an animal..a big animal. an axe rocks!
  14. Dec 4, 2012 at 11:06 AM
    aficianado
    back to bone stock.
    for splitting..a splitting maul is the better tool.
  15. Dec 4, 2012 at 11:08 AM
    TacoDaTugBoat
    Goshen, Ct
    13 DCLB TRD Sport
    Understood, I would have thought cutting and such would be more of a job for a hatchet. I keep my hatchet real sharp. But If your cutting big enough stuff, and I do hope you are getting some nice big animals to butcher, an ax would be better than a hatchet.
  16. Dec 4, 2012 at 11:15 AM
    aficianado
    back to bone stock.
    Great point. My axe is very compact.
  17. Dec 4, 2012 at 12:23 PM
    Taco Dan
    Taco Dan Well-Known Member
    Dan
    Tuscaloosa, AL
    07 FJ Cruiser auto 4X4
    Snorkel, Cooper ST Maxx 255/80/17, diff breather relocate, Cobra ultra III cb radio set up Warrior Products front bumper
    Mauls are ideal for chopping wood. im not a big fan of double headed axes
  18. Dec 4, 2012 at 12:25 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    100% this ^^
    Mauls are for splitting wood , axes are for chopping down trees / de-limbing
  19. Jul 19, 2014 at 11:04 PM
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    Reviving this thread since it's where the experts be. Found myself REALLY enjoying splitting the wood I cut down this week, but realized the need for a good maul and wedge set. Anyone have experience with Gränsfors Bruk stuff?
    http://grandforest.shptron.com/p/splitting-maul?pp=12
  20. Jul 21, 2014 at 8:59 AM
    aficianado
    back to bone stock.
    Oh. Buy it.
    My axe is a gransfor. . One of them. Amazing tool.
