Who is using a brake controller?
Discussion in 'Towing' started by maxpower29, Sep 2, 2012.
  1. Sep 2, 2012 at 4:40 PM
    maxpower29
    maxpower29 [OP] Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    How many of you use one? I just found out its the law here and had no clue but Im getting mine hooked up Thursday.
  2. Sep 2, 2012 at 5:43 PM
    Redneck92
    Redneck92 Well-Known Member
    Concord, NC
    02 Tacoma Limited TRD
    Just the norm skids, sliders, & 35's
    I do, it's dangerous if you don't. You can get away with no towing lightish loads with a 3/4 ton or 1 ton due to bigger brakes but the Tacoma's brakes are not meant to stop 6-9k lbs safely. Its a world of difference with one, still have to adjust how early you stop but depending on the load you won't have to as much.
  3. Sep 2, 2012 at 5:46 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    Im just towing my 1500lbs tent trailer but ya I figured it would be needed. Im just new to towing anything and had no clue
  4. Sep 2, 2012 at 8:52 PM
    Redneck92
    Concord, NC
    It wouldn't hurt to have one that way if you ever plan on towing larger loads you don't have to worry about it.
  5. Sep 2, 2012 at 9:12 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 Mid-Travel 4x4 DCSB 6spd
    Kings Mid Travel, BAMF bed rack, RTT, dual battery, OBA, ARB locker, 4.56 gears
    I have a Tekonsha Prodigy
    In some states (idk about Canada), if you run a trailer with electrical brakes (vs. surge brakes like boat trailers) then it is illegal to tow without one.
  6. Sep 3, 2012 at 4:17 AM
    maxpower29
    Jordan
    Nova Scotia, Canada
    That looks cool and not very big. I was worried about it being so massive
  7. Sep 3, 2012 at 5:14 AM
    MeAndMyRC
    MeAndMyRC Member
    Glen Rock, Pa.
    09 Tacoma, Red with Black trim
    Black GrillCraft grill,BF Goodrich All-Terrain T/A, LT265/75/16, stainless steprails, halo headlights.
    I wouldn't leave home without one! If adjusted correctly, braking HP for both truck and trailer will stop in case of an emergency, with room to spare.
  8. Sep 3, 2012 at 9:48 AM
    exploringcarolina
    exploringcarolina Well-Known Member
    Bill
    North Carolina
    2003 Tacoma
    Have trailer brakes on my LivinLite TT. Was towing the TT with my a 87 Toyota Pickup when a rear brake drum cylinder started leaking & I lost the truck brakes. Was able to use the TT brakes for stopping without the use of the pickup's emergency brakes until I got to a safe place to stop & replace the brake cylinder. Replaced brake fluid & rear drum cylinder before selling the pickup & the current owner says the brakes work great. The reason the brake cylinder started leaking was because the emergency/parking brake cable stuck causing the rear drum/cylinder to get hot. Fixed the emergency/parking brakes before selling the pickup, too.
  9. Sep 3, 2012 at 5:28 PM
    gnfreak
    gnfreak Active Member
    keith
    Normal, IL
    old Tekonsha Voyager hooked up in base 2007 4x4 tacoma w/o tow package. had to wire about everything. glad the towing bible exists.
  10. Sep 6, 2012 at 8:09 AM
    J Gibson
    J Gibson Well-Known Member
    J
    Knoxville, TN
    '12 DblCab,shrt bed,4wd,TRD Sport, tow pkg, mgntc grey
    katzkin leather, chrome toyota step bars, chrome sr5 grill, advent overhead DVD player, cargo extender, bed mat, husky liners, impulse digital brake controller, avs bugflectorII, tinted windows, Firestone ride-rite air bags, UWS slimline aluminum toolbox, ScangaugeII, ProEFX tow mirrors, ImMrYo rearview mirror lift bracket, Salex glove box and console organizers, Tundra / Sequoia wheels, 265/70 r17 Michelin MS2 tires, LED map lights, drivers seat extended and raised, ram ball tech deck installed.
    I have an Impulse Digital Controller. I love it. You can get the plug and play kit for use with the factory towing package. Installs easily, can be mounted anywhere in any direction, (does not have to be level and facing forward like some).
  11. Sep 6, 2012 at 7:01 PM
    Redneck92
    Concord, NC
    How does it do as compared to a non time delay controller?
  12. Sep 7, 2012 at 2:31 AM
    maxpower29
    Jordan
    Nova Scotia, Canada
    I just got mine installed yesterday and its small and out of the way. I'm pretty happy with it. I should be towing my camper for the first time tomorrow so I should know how it feels
  13. Sep 7, 2012 at 5:27 AM
    J Gibson
    J
    Knoxville, TN
    I really couldn't say. I have had two different controllers and both have operated basically the same way. This Impulse has a ton of adjustment which is digitally displayed. Getting it adjusted correctly is critical, but simple. Only when I did not have it set right did I experience either the grabbiness that slid the tires like was described above, or sluggish braking. With it set right I really think my total stopping distance is hardly affected.
  14. Sep 9, 2012 at 5:19 AM
    maxpower29
    Jordan
    Nova Scotia, Canada
    So I used it and ya it does make a difference. I had to set the thing at first and without the brakes up enough you could feel the weight for sure, and the camper was only 1600lbs or so. Its set nice and works great. Easier then I thought
