Who is using REDLINE gear oils for their differentials????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Eesh, May 23, 2010.
  1. May 23, 2010 at 1:55 PM
    Eesh
    Eesh [OP] Well-Known Member
    Regina, Sask., Canada
    trd Sport
    What specific kind of redline gear oil and how much ???
    Did you have to add LSD additive??
  2. May 23, 2010 at 9:07 PM
    Gerry Pope
    Gerry Pope Well-Known Member
    San Diego
    07 4X4 PreRunner
    I used Redline 75W90 in both diffs.. It comes with the LSD additive.
    Some have said they had chattering with the Redline but I have had no trouble.. I put MT90 in my tranny and it smoothed out the 1-2 shift.
    Good Stuff IMHO
    Gerry
    Frnt-n-Rear Diffs: Redline 75W90
    Frnt..1.5qt Rear 2qts
    TransferCase: 1.1 qts 75W90
    Tranny: 2 qts RedlineMT90
  3. May 23, 2010 at 9:08 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    i use redline in the rear diff and in my tranny. been very happy so far!
    i think its 3 qrts for the tranny....well my 4 banger manual took 3 idk about the v6 tranny.
  4. May 24, 2010 at 7:58 AM
    JD2
    JD2 Member
    Western Washington
    05 TRD Sport Double Cab
    I have Redline 75W90 for LSD's in my front and rear differentials and transfer case. No problems or chatter with my rear LSD, and I didn't have to add any additional friction modifier. Great stuff, and I'll be using it again when it is time to change out the differential and transfer case fluid again.
  5. May 24, 2010 at 9:25 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
    there are two formulas. one for LSD, one without. you have to read the bottle. i use it. cant tell the diff, but mentally, i'm happy.
  6. May 24, 2010 at 2:00 PM
    Eesh
    trd Sport
    Did you use the exact same stuff for the Front Diff and Transfer Case that you did with the Rear diff??
  7. May 24, 2010 at 2:28 PM
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    So NOOB question. The LSD is only on the sport correct. The SR5 4*4 uses an open differential?
  8. May 24, 2010 at 2:29 PM
    RainDodger
    RainDodger YGWYPF
    Great Northwest
    '09 Black, TRD Sport
    None yet! It's new!
    '09 TRD Sport:
    Red Line 75W-90 in front and rear diffs
    Red Line MT-90 in the 6 sp trans and the transfer case.
    ** Red Line recommendations
    No problems.
    (edit: I specifically asked Red Line about the transfer case and they said they recommended the same in the transfer case as the transmission, especially since they are attached to each other. Any transfer between the two due to a bad seal, etc. won't matter. I do not think there's any problem running the 75W-90 in the transfer case either, however.)
  9. May 24, 2010 at 2:39 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I just swapped out my front diff and transfer case with Redline 75W-90 GL-5 all synthetic gear oil just the other morning. I was going to use it for my rear diff but kept getting positive and negative feedback about using synthetics for the rear so I went with about 3qts. of Valvoline 80W-90 gear oil with 4oz. of the Redline friction modifier. So far no problems or chattering sounds from the rear.:rolleyes:
  10. May 24, 2010 at 3:18 PM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    Gear Oil according to the maintenance manual is 75w-85, which redline specifically says it is for use in toyota diff's. Not sure it matters....jus sayin'
  11. May 24, 2010 at 3:32 PM
    NAAC3TACO
    NAAC3TACO Well-Known Member
    Sparks, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Toyo A30 tires, Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts.
    I've heard great things about the MT90 and plan on using it in my 5 speed when the time comes. I hadn't thought of using it in my T-Case, but it makes sense. Good info.
  12. May 24, 2010 at 3:37 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Well whoever swaps out there LSD diff oil with the Redline all synthetic, please let us all know what the outcome is.:eek: Hell I might just swap mine out with the Redline just to see for myself!!!:confused: I still have 3qts. left over in my garage!!!
  13. May 24, 2010 at 4:08 PM
    Airun
    Airun Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
    Muncy, my sr5 07 4x4 does have LSD rear. Obvious sticker to right of check plug that says LSD fluid only. Just ordered some Redline today and gonna do a temp comparison dino vs synth
  14. May 24, 2010 at 5:52 PM
    wlmuncy
    William
    Knoxville, TN
    OK thanks Airun.
  15. May 24, 2010 at 10:16 PM
    2_wheels
    2_wheels Well-Known Member
    Coeur d'Alene, ID
    06 Tacoma TRD Sport 4x4 dbl cab
    does anyone know what the service interval is on transfer cases and tranny? I've got 75k and just wondering if I should do it now. thanks!
  16. May 25, 2010 at 7:19 AM
    JD2
    JD2 Member
    Western Washington
    Eesh,
    Yes I used the same Redline 75W-90 GL-5 all synthetic gear oil for LSD's in both differentials and the transfer case. It meets the GL-5 rating, and Redline said that it would not be a problem to use the LSD in the transfer case.
    So far after 20,000 miles I haven't had any problems at all.......
  17. May 25, 2010 at 7:26 AM
    RainDodger
    RainDodger YGWYPF
    Great Northwest
    None yet! It's new!
    2 things - uood8 said the manual says to use 75W-85. He's correct, but the 75W-90 is fine too, according to Red Line. I asked them that a few months ago.... and JD2, Red Line also told me the 75W-90 is ok in the transfer case, as you know already. They only said that if the tranny has MT-90 in it, they'd probably run MT-90 in the transfer case as well, since they're attached to each other. No problem either way.
    I've been running Red Line stuff in everything for upwards of 10 years. All kinds of vehicles, from Porsches to tractors and generators, 2 Tacomas and an FJ Cruiser. No problems.
  18. May 25, 2010 at 7:29 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Finally, someone that has used Redline.;) This is good to know. I will probably go with the Redline all synthetic in my rear diff next time around.:rolleyes:
  19. May 25, 2010 at 7:50 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Not necessarily.
    You could get the LSD (mechanical) as an option on other trucks. In 09 - they stopped putting the mechanical LSD's in and ALL the trucks got the AUTO LSD (which uses the brakes and not the diff)
  20. Jul 6, 2010 at 10:33 PM
    Eesh
    trd Sport
    BUMP... And also when are you suppose to change the Automatic Transmission Fluid and what kind of Redline do you use for it??? I'm taking it that the Mt-90 is for Manual transmissions?
