Who knows about the performance chips? Are they worth it?
Discussion in 'Performance and Tuning' started by 06tacoV6, Feb 11, 2012.
  1. Feb 11, 2012 at 6:54 PM
    06tacoV6
    06tacoV6 [OP] Member
    Oregon
    2006 access cab taco v6
    Fujita cold air intake, 2 1/2 inch leveling kit, 2 inch add a leaf, flowmaster super 40 muffler
    I currently have a cold air intake and flow master exhaust but still want a little more power and MPG's out of my 2006 V6 taco. Does any one out there have a performance chip on? Does it help along with the other mods? Im currently getting at best 19 mpg hwy.
  2. Feb 11, 2012 at 6:56 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Save your money, there aren't any chips that will help you out. Also, depending on the type of cold air intake you have, you might have actually lost power. The OEM intake is a cold air intake and very few of the aftermarket ones do anything except make the truck louder.
  3. Feb 11, 2012 at 6:57 PM
    2011BlackTaco
    2011BlackTaco Well-Known Member
    Josh
    Tennessee
    11 Prerunner
    6 inch Pro Comp lift kit, 18" XD Monster rims, 285/65/18 Nitto Trail Grapplers, Smittybilt black step bars
    that is a very debatable topic i personally have never seen any major improvements in gas trucks by adding a chip. usually its approx 1 mpg increase at best and maybe 10 hp and torque increase at high rmp's. id say not worth it just buy a supercharger and go big or go home !! they are way more worth the money. just my two cents
  4. Feb 11, 2012 at 7:03 PM
    06tacoV6
    Oregon
    Does your supercharger get you better mpg? which one do you have?
  5. Feb 11, 2012 at 7:03 PM
    06tacoV6
    Oregon
    Also what kind of Power increase are we talking?
  6. Feb 11, 2012 at 7:05 PM
    06tacoV6
    Oregon
    I disagree with you pugga. The stock air intake is garbage. I feel a definite increase in power with my intake.
  7. Feb 11, 2012 at 7:13 PM
    2011BlackTaco
    Josh
    Tennessee
    11 Prerunner
    These are stats from Toyota
    Increase your passing power and towing capacity with the TRD intercooled supercharger system kit for your Tacoma’s 4.0L V6 engine. Featuring an air-to-liquid intercooler that increases torque and horsepower from idle to redline, the system produces 304 hp @ 5,400 rpm and 334 lb.-ft. torque @ 3,600 rpm (from 236 hp @ 5,200 rpm and 266 lb.-ft. @ 4,000 rpm. You can also count on immediate throttle response, along with substantial increases to towing capacity and acceleration. The system uses a strong, compact one-piece plenum/manifold that integrates Eaton roots-type rotating components, Gen 5 rotor pack and the heat exchanger core for the intercooler. All hardware needed for a “factory installed” appearance is included in the kit. And, because the supercharger features self-contained lubrication, there’s no maintenance required on the supercharger or system components. The TRD Supercharger and/or TRD Cold Air Intake are to be sold as a dealer installed or over-the-counter option, after the retail sale of the vehicle the Supercharger and/or Cold Air Intake may not be sold to the customer at the same time as the new vehicle and may not be financed together with the new vehicle.
    Your not going to get mpg increase along with torque and horsepower, its usually torque and horsepower only or mpg only or a very small increase in all three. There arent may mpg increases that are noticeable, its usually just very small increases. The pay off isnt usually worth it for mpg, just keep your foot out of it and run fully synthetic oil.
  8. Feb 11, 2012 at 7:16 PM
    2011BlackTaco
    Josh
    Tennessee
    11 Prerunner
    that also can be an argued, may people say that the way the truck comes is the best mpg you can get even with the stock air filter. On the 4 cylinder models there is a secondary filter that, when removed shows mpg improvements. You can remove the filter on the 6 cylinder also but it doesnt show as good of results
  9. Feb 11, 2012 at 7:23 PM
    06tacoV6
    Oregon
    thanks for the info black taco. I don't think I need the supercharger although I would like it, its just to much to spend for me right now. I do drive it pretty easy but still am not impressed with the mpg. I think toyota could have done a better job designing their motor but on the other hand it does have plenty of power right off the lot.
  10. Feb 11, 2012 at 7:25 PM
    2011BlackTaco
    Josh
    Tennessee
    11 Prerunner
    no problem man there is tons of info here at TW that can explain almost all questions that you might have. the supercharger is def a huge chunk of money i havent been able to pull the trigger on one yet either but im pretty happy with the power i have for now. i average 17.9 on a typical week and im running a 6 inch lift with 33's
  11. Feb 11, 2012 at 7:26 PM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    The dyno say different.
  12. Feb 11, 2012 at 7:28 PM
    BenWA
    BenWA Well-Known Member
    Boston burbs
    '06 Double Cab TRD Off Road 4X4
    OP: You have a 2006... how many miles? Have you always had lousy MPGs or have they declined over time? Have you serviced the MAF, throttle body, air filter, catalytic converter, 02 sensor, plugs, etc lately? Cleaning the gunk out of these things if they haven't been serviced in a while can increase your mpg significantly.
  13. Feb 11, 2012 at 7:31 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    You can remove all filters and restrictions, and be lucky to gain 1 hp with the stock engine. A CAI will benefit Tacos with the TRD supercharger, however.
  14. Feb 11, 2012 at 8:05 PM
    t4daddy
    North Alabama
    But just listen to it, it's gotta be making more power...
  15. Feb 11, 2012 at 8:14 PM
    Rashnu
    Rashnu Well-Known Member
    '16 T4R TEP
    Stock
    It doesn't? :confused:
  16. Feb 11, 2012 at 8:34 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    These CAI's only draw in warmer air when the vehicle is not moving, and so does stock. When you're rolling 30+ mph the CAI will draw in the same temp air as stock. As for performance gains, I don't have a dyno and won't put my truck on one after watching U tube vids of dynos gone bad. Between how much a CAI cost and whatever gains there actually is, I think the cost may out weigh the gains.
    As for the OP, if ya want better mileage and better performance, do as previously said and clean your MAF, and TB. Run some FI cleaner in your gas tank, Do the sea foam in your engine, check your spark plugs, and so on. Basically do maintinence that a regular person wouldn't normally do. There are other things that cause drag on your truck, like the power steering. When's the last time you bled your PS? Should, in actuality be done evry 45k-60k miles. There are so many preventative maintinences that get over looked that affect performance and gas mileage. If you want a super increase, save your $ for that super charger.
  17. Feb 11, 2012 at 8:36 PM
    Rashnu
    '16 T4R TEP
    Stock
    Oh how I've missed your comments Christian!
  18. Feb 11, 2012 at 8:49 PM
    JStradaXR
    JStradaXR Well-Known Member
    Chuy
    Ontario CALI
    06 X Rated
    Everything but boost =[
    You could use the URD maf cal or the new urd ucon...
  19. Feb 12, 2012 at 1:30 AM
    06tacoV6
    Oregon
    My intake makes no difference in sound. and no its not the one in your pic. thanks for your useless input.
  20. Feb 12, 2012 at 1:33 AM
    06tacoV6
    Oregon
    You must get on here just to try to make yourself sound smart and important. Keep running that cluttered mess toyota put on your intake if that's what makes you happy.
