Who knows about the performance chips? Are they worth it?
Discussion in 'Performance and Tuning' started by 06tacoV6, Feb 11, 2012.
  1. Feb 12, 2012 at 3:39 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    OP, take off your flowmaster, get your stock airbox back and use a drop in filter.
    then run URD's MAF Calibrator.
    bout all you can do besides add boost. Chips are crap.
    as are buttdynos.
  2. Feb 12, 2012 at 3:49 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    I've never even heard of those :notsure:
  3. Feb 12, 2012 at 3:54 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    ah. I hadn't even seen those posts
    :wave:
  4. Feb 12, 2012 at 7:55 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Less restriction by better filter media. However, just like the K&N, lots of heat soak. Trade is not in favor of Awesomely labled "HAI". :D
  5. Feb 12, 2012 at 9:42 AM
    Rashnu
    Rashnu Well-Known Member
    '16 T4R TEP
    Stock
    I'm pretty sure every aftermarket intake makes a difference in the sounds of your aftermarket exhaust. Wolfpack was asking if the "cai" pictured was yours and proceeded on commenting on the "cai". If it's not the one pictured post up a pic of it and give some info on it. Doesn't sound like too many people here have heard of yours.
    Say what you will of the OEM intake, but it is pretty good as is. Maybe you should think about dropping the OEM one back in and going with a better filter, say an AFE Pro Dry-S filter. I've run the volant and the first gen TRD cai and both have delivered on sound, but have failed to deliver on any "noticeable gains"
    Judging from how long wolfpack has been a member on here, one can deduct that he's not just getting on here to make himself sound smart. If you proceed to continue bashing people who are trying to help, you will see less and less people attempt to answer any of your questions.
  6. Feb 12, 2012 at 9:56 AM
    2011BlackTaco
    2011BlackTaco Well-Known Member
    Josh
    Tennessee
    11 Prerunner
    6 inch Pro Comp lift kit, 18" XD Monster rims, 285/65/18 Nitto Trail Grapplers, Smittybilt black step bars
    Haha oh the constant joys and laugh from the threads that get off on this topic. I wish i had a dime for ever thread about more noise = more power hahaha but you gotta give the OP some slack im sure alot of us were like that before reading around on here. the sellers make you think that their product is the best.
  7. Feb 12, 2012 at 10:17 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Here is the problem with the word "CHIP". People have a vague idea of what that really is. Due to mean reasons. Word of mouth, video games, and "performance chips" that were for a earlier model of electronically controlled vehichle.
    These days, you are now in the realm of: Reflashes, hand held programmers, "piggy-back" ECUs (inline intercepting ECUs), and Stand-alone ECUs. (Add more if I missed any)
    Our ECUs have EPROM. You can write it, but not re-write it. There are no hand held porgrammers, such as BullyDog, to be able to tune the ECU because of that fact. So we are left with wire in units, or units that have factory style plugs to make them Plug N Play. That, as of now, only applies to '05-'08 ECUs. '09+, have to still be wired into, until plugs are available to market. UniChip has them, and URD is working on making their own.
    So there you have it. Available for Wire-In. Many. I will list a few: AEM, ProEFI, Motech, URD MAF/MAP Cals, Map-ECU2 or 3 (mainly 3 now), APR X-1 ( no longer in production but still some are available), URD UCON.
    EDIT***:
    Are they worth it? Vague at best. Depends on what you are trying to do with you engine, performance wise. How much control you need, the quality of the tuning device. As you go higher on the totem pole of things you want, the price goes up as well.
    My ProEFI with custom made plug n play extension harness, 5 bar MAP sensor, 150 PSI fuel pressure sensor, AFR sensor, and tuning cord, was $3200.
    Was it worth it???? For the control, and power, and plan of my build, Hands down yes. For you, most likely not. You have to find something equatable to your needs.
  8. Feb 12, 2012 at 10:45 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    A supercharged 4.0L will get better mileage if you can keep your foot out of it. Just cruising down the road, they will do better on fuel but you have to run premium grade. You will never save enough on fuel to offset the initial cost of the supercharger though so buying one just for that reason is a terrible investment. URD (Underdog Racing Development) and TRD both make superchargers the for Tacoma.
    Yep, based on all the other responses, I must be horribly wrong... :rolleyes:
    As others have said, most of the aftermarket cold air intakes are less effective than the stock intake. To call the stock intake junk is incredibly ignorant and misinformed. To add insult to injury, your Flowmaster isn't doing anything for you either... Spend some time reading through the performance and tuning section on here and you'll get a lot of good ideas and proven results (not butt dynos and stated gains based on noise level).
  9. Feb 12, 2012 at 3:42 PM
    Eagledynasty
    Eagledynasty The White Knight
    AJ
    Worcester, MassHole
    09 Super White DoubleCab Off-Road
    2009 SWDC O/R. Check Build!
    Some brilliant info right there. Straight from Mass haha. Glad Mikes source of information is so close haha:D
