Who likes Raptors?
Discussion in 'Off-Topic Discussion' started by Delmarva, Jan 6, 2010.
  1. Jan 6, 2010 at 3:59 PM
    Delmarva
    Delmarva [OP] Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
  2. Jan 6, 2010 at 4:00 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
  3. Jan 6, 2010 at 4:00 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
  4. Jan 6, 2010 at 4:00 PM
    Packman73
    Packman73 ^^^^ 3%er ^^^^
    The free state of Arizona
    2007 TRD Off Road
    Bilstein 5100's (front set @ .85"), OME 885's, chris4x4 anti-Taco-lean spacer on driver's side, Total Chaos UCAs, Rear Leaf Spring TSB, Toytec AALs, Black FJ TT Wheels, BFG 285/75R 16 AT Tires, TRD Exhaust, Viper Alarm, Fog Light Mod, De-badged, Blue LED Dome Light, EZ Clamped Tailgate, Wet Okoles, Satoshi Grill, 5% Tint, Engine Tick Fix, Black Rear Bumper, Black Center Valence, Exhaust Cut At Axle, Thanks for all the help chris4x4!
    Me. The truck and the dinosaur.
  5. Jan 6, 2010 at 4:00 PM
    Delmarva
    Tucson, AZ
  6. Jan 6, 2010 at 4:01 PM
    Delmarva
    Tucson, AZ
    raptor
  7. Jan 6, 2010 at 4:04 PM
    vtragweed
    vtragweed Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
    afe pro-dry s filter, LCE headers, painted black steelies,color matched grill surround, URD short shifter, UWS black tool box
  8. Jan 6, 2010 at 4:17 PM
    Silver 10
    Silver 10 Well-Known Member
    Joe
    Valparaiso, Indiana
    10 SR5 DBL Cab 4x4
    Nitto Terra Grapplers, Leer XL100 cap , Cabelas Bug shield , Tinted windows, Bed Mat, Husky Floor Liners front and rear, seat belt mod, Rear TSB, K&N Air filter
    I do its phenominal
  9. Jan 7, 2010 at 3:51 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    Eminem is my favorite raptor! :)
  10. Jan 7, 2010 at 4:06 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    My GPS is not sure where this is headed............:confused:
  11. Jan 7, 2010 at 4:11 AM
    Delmarva
    Tucson, AZ
    South....
    :laugh:
  12. Jan 7, 2010 at 4:52 AM
    neontrail
    neontrail ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
    How can you NOT like it... :cool:
    Lockheed F/A-22 Raptor
    The F/A-22 is destined to replace the F-15 and become the next-generation fighter of the USAF. Together with the competing F-23 it is one of the first fighter designs optimised for stealth. In addition, it was designed to "supercruise", i.e. fly at supersonic speeds without afterburner. The F/A-22 has a relatively conventional appearance, with twin tails and flat fuselage sides. The engines have two-dimensional thrust vectoring nozzles. To conserve a low radar cross-section, the armament is carried in internal weapons bays. First operational F-22 made it's debut in December 2005. Plans for a naval version, intended to replace the F-14, with extensive changes to make the aircraft suitable for carrier use, have been shelved.
    First look/first kill in all environments- A combination of improved sensor capability , improved situational awareness, and improved weapons provides first-kill opportunity against the threat. The F-22 possesses a sophisticated sensor suite that allow the pilot to track, identify, and shoot the threat before it detects the F-22. Significant effort is being placed on cockpit design and avionics fusion to improve the pilot's situational awareness. Advanced avionic technologies allow the F-22 sensors to gather, integrate, and display essential information in the most useful format to the pilot.
    Reduced observables- Advances in low-observable technologies provide significantly improve survivability and lethality against air-to-air and surface-to-air threats. The F-22's combination of reduced observability and supercruise accentuate the advantage of surprise in a tactical environment.
    Supersonic persistence- The F-22 engines produce more thrust than any current fighter engine, especially in the military (non-afterburner) power. This characteristic allows the F-22 to efficiently cruise at supersonic airspeeds without using afterburner (supercruise). This capability greatly expands the F-22's operating envelope in both speed and range over current fighters which must use afterburner to operate at supersonic speeds.
    Increased maneuverability- The F-22 has been extensively designed, tested, and refined aerodynamically during the Demonstration/Validation (DEM/VAL) process and coupled with high-maneuver capability. The sophisticated F-22 aerodesign and high thrust-to-weight provides the capability to outmaneuver all current and projected threat aircraft.
    Improved combat radius on internal fuel- To ensure the F-22 provides air superiority for deep-interdiction aircraft, it operates at medium and high altitude at ranges superior to current generation air-superiority aircraft.
    Improved reliability and maintainability- To ensure operational flexibility, the F-22 has better reliability and maintainability than any military fighter in history. Increased F-22 reliability and maintainability pays off in less manpower required to fix the aircraft and consequently less aircraft required to support a deployed squadron. Additionally, reduced maintenance support provides the benefit of reduced life cycle cost and the ability to operate more efficiently from prepared of dispersed operating locations. The F-22 exceeds current fighter sortie surge rates with a reduced support structure.
    Increased lethality and survivability- The above characteristics provide a synergistic effect that ensures F-22 lethality against an advanced air threat. The combination of reduced observability and supercruise drastically shrinks surface-to-air engagement envelopes and minimizes threat capabilities to engage and shoot the F-22.
    Air-to-surface capability- The F-22 has a secondary role to attack surface targets. The aircraft will be capable of carrying 2 x 1,000 pound Joint Direct Attack Munitions (JDAMs) internally and will use on-board avionics for navigation and weapons delivery support.
  13. Jan 7, 2010 at 4:54 AM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
  14. Jan 7, 2010 at 5:07 AM
    OU812
    OU812 ban the term murdered out
    danusa
    Kilroy was here
    13 DblCab LB 4X4
    Nothing yet, brand new!
    I'm with Geoff on this one. F-22 FTW
    ( The Tomcat was the best looking jet of all time )
  15. Jan 7, 2010 at 5:17 AM
    Afwrestler1986
    Johnstown, NY
    Says the Navy guy. LOL.
    F-14's were pretty awesome. F-22's are neat. But I am more of a classic type guy myself. I really liked the F-4 and the F-111.
  16. Jan 7, 2010 at 5:30 AM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Me too, P51 and P38's :thumsup:
    :threadjacked:
  17. Jan 7, 2010 at 5:49 AM
    yotarob2005
    yotarob2005 Kiss My IFS
    Rob
    Bryan , Tx
    05 D-cab trd sport long bed
    Front Bilstien 5100's Set @ 1.75", rear 5100's & TSB springs, Flowmaster, TRD seat covers, Toyota All weather floor mats, 265/70-17 Michelin LTX AT2's, some Debadgeding, BHLM, led bed lights, 886 back up lights, fog lights anytime mod, Extra d-rings, Toyota bed mat, sockmoney TRD decals, Kenwood 890DNX, Firestone ride-rite air bags, 2 car seats.
    Yamaha Raptor FTW
