Who makes aluminum sliders?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rujack, Jan 26, 2019.
  1. Jan 26, 2019 at 3:49 PM
    #41
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    ... They're pretty close for " real world " uses..
    EatSleepTacos likes this.
  2. Jan 26, 2019 at 3:54 PM
    #42
    DrFunker
    DrFunker Well-Known Member
  3. Jan 26, 2019 at 3:58 PM
    #43
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Yes. I know what they are. Not that it matters for this discussion.
    Idk why you are taking exception to everything I’m saying. At one point I’m pretty sure they were using .065”. It’s doesnt appear they are now. Either way, there still is no benefit to building rock sliders from 4130. You can believe what you want.
    m603holden likes this.
  4. Jan 26, 2019 at 4:09 PM
    #44
    Therotechnically
    Therotechnically Member
    CCC
    They never used .065" lol. I'm just tired of reading all your posts defending your choice to use DOM and slamming the use of 4130. I believe what is tried and proven not what your calculator says. Like I said I've been fabricating this kind of stuff for a long time and have first hand knowledge of both materials characteristics. Point is 4130 is stronger and more expensive, that sir is a fact. You don't think it is worth it and that is an opinion.
  5. Jan 26, 2019 at 4:11 PM
    #45
    -40
    -40 Well-Known Member
    North Dakota
    01 DC Camburg LT & 17 OR OME BP-51
    1 st Gen TRD Supercharger. URD 7th Inj. Camburg 4x4 LT Kit. Tundra Brakes. 3rd Gen just get’n started, OME BP51 Dakar HD, Camburg UCA & various armor.
  6. Jan 26, 2019 at 4:16 PM
    #46
    -40
    North Dakota
  7. Jan 26, 2019 at 4:20 PM
    #47
    jowybyo
    Joe
    Baltimore, MD
    Ok man. Like I said, believe what you want.
    synaps3, m603holden and Stocklocker like this.
  8. Jan 26, 2019 at 4:24 PM
    #48
    Therotechnically
    CCC
    Good attempt. Personally I think they should have used something more consistent for damage than the rock, as it seems it hit in different places for the the different sliders. Also they don't offer a fair comparison of square to round tube sliders since they are different diameters, so of course a larger square tube will hold up better than a smaller round tube. It does a good job of showing how not to mount to the frame too. Probably why the comments are disabled.
  9. Jan 26, 2019 at 4:27 PM
    #49
    Therotechnically
    CCC
    I'll hit up Jeff Geiser at Geiser Bros and let him know he is a fool for building his Trophy Trucks from 4130.
  10. Jan 26, 2019 at 4:28 PM
    #50
    jowybyo
    Joe
    Baltimore, MD
    Nah. Different application. Makes sense for a roll cage. The design benefits from 4130 advantages.
    JKU3000 likes this.
  11. Jan 26, 2019 at 4:28 PM
    #51
    Pella
    Pella Well-Known Member
    Pella
    209
    SSMDCSBORFTMFW
    I’ve read a lot on the DOM tubing before I went with my sliders, not much on 4130. Why do you say 4130 is superior?
  12. Jan 26, 2019 at 4:30 PM
    #52
    -40
    North Dakota
    I just wanted to add something to the conversation. Since I’m not a engineer and know nothing about metal. I did however purchase my sliders used from NASA. The are made of titanium, taken off the lunar rover prototype. At least that’s what the craigslist ad said.
    Meaty, loastad, rollin904 and 2 others like this.
  13. Jan 26, 2019 at 4:31 PM
    #53
    Therotechnically
    CCC
    And so do sliders.
  14. Jan 26, 2019 at 4:39 PM
    #54
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    No. The engine can hack the sliders w/ ease. This just doesn't make sense. And for whoever said they want to pay 2000 for alum. slider because they don't rust is crazy. My sliders see salt year around and they don't rust. And if they did..for 2000 I can by 3-4 sets of them.
  15. Jan 26, 2019 at 4:39 PM
    #55
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
  16. Jan 26, 2019 at 4:43 PM
    #56
    m603holden
    Marteeen
    New England
    Btw a vnotch and % yeild is way more relevant than tensile here, in regards to both 4130 and aluminum.
    salmonmigration and synaps3 like this.
  17. Jan 26, 2019 at 4:49 PM
    #57
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    Interesting discussion from an engineering, cost effectiveness outlook.
    One has to wonder under what circumstance sliders from DOM would fail and 4130 would not, with everything else being equal. After all, that would be the reasoning for using 4130, would it not? Then, what is the cost ratio of the two? If I'm getting a 3% increase in performance at a 200% increase in cost, I fail to see the point, but if I get a 25% increase at 100% cost, I can see the advantage. What's the cost/benefit breakdown on the 4130?
    GHOST SHIP, loastad and rollin904 like this.
  18. Jan 26, 2019 at 4:57 PM
    #58
    Therotechnically
    CCC
    It's not a 3% percent increase though. That simply quoting the spec he loves to throw out there.
    4130 will take rock hits better and for longer, less likely to dent or get rack rash, and is less likely to deflect allowing the slider to contact the cab.
  19. Jan 26, 2019 at 4:59 PM
    #59
    kodiakisland
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    OK, so what is the %? I was just throwing those numbers out there as an example of cost/benefit analysis. We've all seen many pictures of DOM sliders after wrecks that took a lot of punishment. What's the real cost/benefit ratio to 4130? Better isn't always better. I want to pay for real world advantage, not theory. Same OD, same gauge, same design, what's my real world increase in strength?
    mu.n8ball likes this.
  20. Jan 26, 2019 at 5:05 PM
    #60
    Therotechnically
    CCC
    It's not that simple if you want to compare slider A made from DOM and slider B made from 4130. 2 different designs, different mounting ect. I'm simply saying if you want to build the best slider, then 4130 would be my material choice any day. Cabs are not cheap, Tacomas are not cheap. I look at it as protecting an investment.
