Who makes aluminum sliders?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rujack, Jan 26, 2019.
  1. Jan 31, 2019 at 9:50 AM
    #101
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    I think the above two quotes provide the most actually useful information in the thread.
    Spoonman[QUOTED] likes this.
  2. Jan 31, 2019 at 9:51 AM
    #102
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    Maybe I wasnt clear.
    I really hate to see 'calling somebody out' when providing just an unreferenced spreadsheet. Just a really big fan of verifiable data.
    I don't believe that Modulus of 28E6 is correct as typical or average of any carbon steel (stainless and some other exotics, yes), I would say that listing that value as proof is incorrect (noting, it is not given that low in your other provided source of data). It certainly is a possible minimum value range, but not something that I think is fair to call average.
    (Note I am a typical user of 4130 on almost everything I ever touch if it isnt aluminum, but I saw that unreferenced value and knew something was wrong definitely wrong there)
  3. Jan 31, 2019 at 10:10 AM
    #103
    SDHQ OFFROAD
    SDHQ OFFROAD Cuz Stock Sucks!
    SALES
    Gilbert AZ
    I'd think this quote would be a good fit...
    With the difference in strength, stiffness, and hardness when compared to DOM, and only about a $53.20 increase in total cost for chromoly, it is obvious to us at SDHQ which material is better suited for the strongest bolt on design available.
    boston23 and GHOST SHIP[QUOTED] like this.
  4. Jan 31, 2019 at 10:11 AM
    #104
    SDHQ OFFROAD
    SALES
    Gilbert AZ
    We don't, and we weren't trying to sell any, just providing correct information about our product since it was brought up multiple times by a vendor.
  5. Jan 31, 2019 at 10:27 AM
    #105
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    You are just rambling about uncorrelated information... You have to define the sliders purpose of build and design. Yes we all know AISI 4130 has a higher ultimate strength vs AISI 1026 in fact 37% higher but you NEVER design anything to Failure because the material will yield. When you design using material allowables you use Yield which 4130 is only 4.5% stronger so is 4.5% in strength worth the 150% in cost? Yes 4130 is used for roll cages because of the higher ultimate strength and because they are designed for complete failure situation where material yielding doesn't matter. You would never reuse the cage again. Sliders are not used for complete failure situations and are not designed to take on full impacts to the side... Sliders are to protect your body panels landing or push against rocks, trees and etc. So when designing sliders you are worried about deflection into your truck panels. When you look at the equation for cantilever beams the only values that mater are Modulus of Elasticity which are THE SAME 29,700 KSI and moment of Inertia "Geometry". So if you use the sliders as intended than 4310 and 1026 are exactly the same beside material cost and skilled labor $$$ with no added benefits. But if you want to use your sliders for ramming protection then I suggest you reinforce your double C channel frames because that would fail before any welds and/or members fails. So I agree with @Mobtown Offroad there is no added benefits for weight saving since both material have the same density of 0.284 lb/in^3 so therefore you would just be wasting your $.
  6. Jan 31, 2019 at 10:29 AM
    #106
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    As an engineer, this is my favorite quote from this thread.
    I think Mobtown and SDHQ should have a slider show down. Both fab up a set of your sliders, mount them to a frame and load them to failure. See who's slider holds up to the heaviest load. Then compare the weight savings and cost savings.
  7. Jan 31, 2019 at 10:30 AM
    #107
    SDHQ OFFROAD
    SALES
    Gilbert AZ
    We don't offer DOM sliders, the $53.20 price difference is what the upgrade from DOM to 4130 was in our cost of material.
    If you are comparing a different companies slider to ours, there is much more than just the material to compare..
    The SDHQ Built Rock Sliders are CAD designed, employ unique mounting solutions tailored specifically for each application. We utilize the best materials for the strongest bolt on design available, our Rock Sliders are built in house for a precise fit and finish, allowing us to utilize mounting solutions that do not require any cutting, welding or drilling for installation. Using this unique mounting design with 3/16” thick gusseted steel mounting plates, the SDHQ Built Rock Sliders support the entirety of the slider. We chose to use 4130 .120” wall chromoly tubing over DOM tubing for strength, rigidity, and hardness.
    As stated, ours are not cheap, but hands down they are 100% the strongest, lightest, fully bolt on sliders on the market.
  8. Jan 31, 2019 at 10:35 AM
    #108
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    The problem with "real world" testing is consistency. It works when you have a large enough sample size and enough time, but we don't have time for that... we want instant gratification!
  9. Jan 31, 2019 at 10:53 AM
    #109
    Wrecked
    Wrecked Well-Known Member
    Castle Rock, Colorado
    2018 Tacoma DCSB Off-Road
    *ARB Summit Bumper *Warn Zeon S10 Platinum *Kings adjustable front and rear *Safari snorkel *17" Fuel Vectors *285-17r17 BFGoodrich KM3 *Rigid Industries ditch lights and a 30" bar *Custom grille *Spod *Cobra handheld CB *Yaesu FTM-400XDR, PulseLarsen NMO2/70B, NMO mag mount *Snugtop Rebel Topper
    I think everyone in here needs a hug.
  10. Feb 1, 2019 at 8:14 AM
    #110
    mutilatedjak
    mutilatedjak n00b waffle
    WA
    11 DC SB TRD Sport 6spd
    BP-51s, Dakar leafs, ARB bumper, 4xinnovations rear HC, 3x trail camera, pure android, lightforce 170s, Dick Cepek 255 85s extreme terrain.
    Whats the strength loss from the weld heat @SDHQ OFFROAD ? The 4130 spec you listed is for the normalized spec, (I typically work with the 180ksi heat treated flavor).
  11. Feb 1, 2019 at 8:58 AM
    #111
    BigWhiteTRD
    Ted
    Only speaking to heat affected zone (HAZ), not talking any about post weld stress relief or heat treatment, or stress or allowables in the weld itself...
    Per MMPDS-01, table 8.2.2.1.1(b) and (c), HAZ strength is not too bad compared to the original N material... (keeping in mind that the original N heat treat is an open air quench, so generally the weld cooling open air quench isnt too severe an impact, plus the adjacent material usually tends to quench the weld HAZ somewhat compared to the original heat treatment in my experience).
    Keep in mind that in my experience the actual receiving inspections for 4130 N generally shows significantly greater than Ftu =90 or 95 ksi from the mill, but there is a great deal of variation in general lot to lot, which keeps A and B basis values down low if you ever try to calculate them...
    Tapered joints and gussets have higher allowables in the HAZ (as well as much preferred fatigue properties.)
    As you certainly already know, rod selection is critical... but that is a whole nother discussion.
    (more specific data is given in Bruhn Table C4.5 or ANC-5, predecessor to Mil-Hdbk-5)
    mutilatedjak[QUOTED] and Boghog1 like this.
