Who makes high quality aftermarket brake pads and rotors?
Discussion in 'General Tacoma Talk' started by Plasmech, Sep 13, 2025 at 7:54 AM.
  1. Sep 13, 2025 at 7:54 AM
    Plasmech
    Plasmech [OP] Well-Known Member
    2009 SR5 V6 Access Cab TRD Off-Road
    Does anyone make an aftermarket pad and rotor that's better than OEM?
    The last time I did pads and rotors on my 2009 Tacoma, they were noisy, and the rotors warped within two years. I drive like an old man. My driving style is VERY conservative.
    I've lost faith in OEM Toyota pads and rotors.
    Who makes a good, high-quality, aftermarket "daily driver" set?
    Thanks.
    HondaGM likes this.
  2. Sep 13, 2025 at 8:03 AM
    Clearwater Bill
    Billy
    Largo Florida
    Were the pads properly bedded when all that was replaced?
    Old man street driving doesn't create enough heat to cause cast iron rotors to warp.
    They can have pad material build up that make them pulsate, especially under light braking, and the term warp gets thrown around. This is often due to improper bedding. Often they can be cleaned, bedded, and be fine.
    Additionally, make sure your rear brakes are clean, appropriate points lubed, and properly adjusted to allow them to work well. This reduces load on the fronts. Many people are careless and have a very low braking contribution from the rears
    soundman98, HondaGM and Inyo_man like this.
  3. Sep 13, 2025 at 8:15 AM
    Bishop84
    Bishop84 Well-Known Member
    100% I have yet to see better pads than OEM, it sounds like your pads were embeded into the rotors causing a pulsation. Agree with Bill. Service rear brakes and use quality parts is all you can do.
    Akebono is my only alternative brand I'd suggest for pads. As for rotors, I rarely see issues with OEM, but we can always attribute issues to any aftermarket.
    But if you really want heres my suggestions.
    https://www.rockauto.com/en/moreinfo.php?pk=10613032&cc=1442967&pt=1896&jsn=725
    https://www.rockauto.com/en/moreinfo.php?pk=419895&cc=1442967&pt=1684&jsn=668
    HondaGM likes this.
  4. Sep 13, 2025 at 8:18 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    OEM is semi-metallic. Try ceramic pads from the OEM supplier, Advics AD0976. I run that part number on both of my Toyotas.
    https://www.rockauto.com/en/moreinfo.php?pk=1874706&cc=1431544&pt=1684
    For rotors I use Raybestos R-300 slotted. The slots keep the pads clean, avoiding deposit transfer (and the accompanying noise/vibration). The slots aid in water evacuation driving out of water crossings off road.
    https://www.rockauto.com/en/moreinfo.php?pk=2768666&cc=1431544&pt=1896
    HondaGM likes this.
  5. Sep 13, 2025 at 8:25 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    My first set of front brakes on my 2009 was around 130k..still no vibration just worn pads
