Who makes these d-ring shackles???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by veet skeet, Dec 2, 2011.
  1. Dec 2, 2011 at 9:33 PM
    veet skeet
    veet skeet [OP] Well-Known Member
    Cali
    14 4Runner Trail Edition MGM
    Bilstein 5100s, 17' Method NV Race Wheels, Goodyear Duratrac 265/70/17, Demello Sliders, Xenon/LEDs All Around, Dark Window Tint, Gobi Roof Rack (In the Mail), JL Audio Subs, Alpine Speakers and Amps
    I just got an all pro rear bumper (the truck below is not mine) and wanted to get d ring shackles like these, the two tone look except black shackles with a red or white accent color. What d ring shackles are these and where do I get them?
  2. Dec 2, 2011 at 9:35 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    I think sierra expeditions and trail duty have them
    Maybe all-pro or trail gear too?
  3. Dec 2, 2011 at 9:35 PM
    JimBeam
    JB
    2015 Tundra
    i've never found them that size at lowes...just FYI
  4. Dec 2, 2011 at 9:36 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Logging supplier
  5. Dec 2, 2011 at 9:38 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
  6. Dec 2, 2011 at 9:41 PM
    JimBeam
    JB
    2015 Tundra
  7. Dec 2, 2011 at 9:46 PM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    This.
    Or a rigging supply company (wire rope, chain, etc) or go to a 4x4 store and pay more ;)
    Edit:
    No, it's not a D-Ring.
    It's a clevis, sometimes they are erroneously called shackles.
    But it is a clevis and probably a 3/4".
    They are usually described by their pin diameter.
    We use those a lot in heavy construction and recently we used these :
    http://www.rtlglobalinc.com/servlet/the-259/3-fdsh-4"--dsh--4-3-fdsh-4/Detail
    (don't know this company, just using the pic)
    They're nice because they don't bind like a normal clevis. The pin can spin freely.
    When rigging with a normal clevis you always go finger-tight with the pin and then back out about 1/8 of a turn.
    If you don't, the pin might tighten up where you need a wrench to open it. Rigging is about safety and also about speed....expensive crane time.
    Edit:
    If they're a permanent fixture on a rig, it doesn't matter if they bind, in fact a keeper wire can be threaded through the hole in the pin.
  8. Dec 2, 2011 at 9:47 PM
    JimBeam
    JB
    2015 Tundra
    Back when I bought mine...i got a 2 pack of 3/4 from Trail Duty for $15.00
    Something like a 7T WLL
  9. Dec 2, 2011 at 9:48 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    4wheelparts
  10. Dec 2, 2011 at 9:49 PM
    veet skeet
    Cali
    Do you know how well those isolators protect against the banging on the bumper? And do you just sand the d ring down and then rattle can a couple of coats on it , cuz I wanna make it black.
    Also, I want to get something on the inside of the hole where the d ring mounts to so that the paint in there doesnt get all scratched up, any suggestions?
  11. Dec 3, 2011 at 9:44 AM
    jflan
    Vancouver, WA
    They should help some but the pin might still make noise.
    Note that with the rig in your pic, the clevis loop hangs below the bumper.
    No, it's galvanized and needs to be "etched" first.
    Painters have forever had trouble with galvanized steel. I've seen them prep (etch) it with vinegar and then use an approved paint.
    This guy found a product in a rattle can that worked :
    Many brush-on paints exist to cover galvanized steel, but spray paints appear to be non-existent. After much research, I finally found the solution. Acryllic latex will adhere to galvanized steel with minimal surface preparation. Therefore, the solution is Krylon’s H2O Latex spray paint. It is an acrylic latex that will not chemically react with the galvanized surface. [Krylon is one of the companies that does not include a warning against using their regular spray paints on galvanized steel. Don’t be fooled. All of their alkyd-based spray paints cannot be used on galvanized steel. And, I don’t think they realize that they have the only spray paint that can be applied to galvanized steel.] The spray paint costs about the same as any other spray paint and since it is a latex paint, it is more environmentally friendly. It is difficult to find in stores. I found it at Ace Hardware, but you can also find it from online retailers. This spray paint is less viscous (more watery or runny) than the average spray paint, so use multiple light coats to prevent the paint from running and pooling on your project (I learned this the hard way). DO NOT try to cover it in one coat. The paint dries in about 15 minutes, however, the paint will not fully cure for about 7 days. Also, do not use the Krylon H2O Latex primer. It is alkyd-based (so technically, not a latex spray paint) and will not adhere, just like any other spray paint.
    Any movement of the clevis pin will wipe out any paint you put in there.
    Book it.
  12. Dec 3, 2011 at 12:37 PM
    jsutter
    jsutter Well-Known Member
    Jim
    Southeast Ohio
    08 Reg. Cab 4cyl 2wd
    cruise and intermittent wipers
    If you have a bumper like that you should not worry about scratched paint on the shackles.
  13. Dec 3, 2011 at 12:49 PM
    NewMexiTaco
    NewMexiTaco Abron Cabron
    Abraham
    Santa Fe, NM
    2007 4x4 DC LB TRD Sport
    Weathertech mats; Wet Okole seat covers; Kobalt Lowpro truck box,(sitting in the shed) Snugtop Hi-liner camper shell; AFE Pro Dry air filter, Tailgate Hoseclamp mod; 5100s all around, Light Racing UCAs, OME 885 coils, OME Dakar Leafs, CB Drop, Driveline spacer. Epoxy Satoshi; Redline Hood Struts. 4x Mil Spec. bed D rings; Brute Force Fab custom DCLB Hybrid Sliders, ARB w/ Warn M8000 wench, Diff Breather mod, Alpine Deck w/ ipod cable. Iphone ziptie to rearview mirror 4wd-cam mod!
