Who owns a generator?
Discussion in 'Garage / Workshop' started by Zombie Runner, Sep 30, 2011.
  1. Sep 30, 2011 at 10:55 AM
    jester156
    jester156 Well-Known Member
    Cumberland, RI
    2021 GMC Sierra AT4. 3.0l Duramax
    ^^ that there was some quality reading^^
  2. Sep 30, 2011 at 11:09 AM
    Cypherian
    Cypherian Well-Known Member
    Mid Atlantic Region
    I do try to help :}
  3. Sep 30, 2011 at 11:09 AM
    Zombie Runner
    Zombie Runner [OP] Are these black helicopters for me?
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    x2 thanks for that post! that was some great info.
  4. Sep 30, 2011 at 11:15 AM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    Yeah, you pretty much gave all the info needed for a good choice.
    Also as far as the EU3000 honda generators they usually go for about $1000 used, thats what I paid for mine.
  5. Sep 30, 2011 at 11:19 AM
    judd94
    judd94 Well-Known Member
    Ponchatoula, LA
    17 4Runner TRD Off Road Premium
    Mods in Progress
    down here on the gulf coast we have a little experience with generators.
    most people usually do the last minute deal and buy one with the storm is about to hit then sell it in off season. the biggest problem with that is most wives and some guys cannot manually hook it up to house and shutoff main power supply to house and get the generator started. also, standing in line for hours for some gasoline sucks ass. most people are reactive and not proactive and they are fine with this setup until they actually have to do it and freak out because it can be a lot to keep up with.
    some people just go ahead and waste an ton of money on a 15k standby generator. while they are really nice and convenient you will never get your money back. the only people that benefit from these are those who lose power on a regular basis. those things will go through a huge amount of fuel in a few days and doesn't help you in the long run.
    after thinking hard about the options and fuel supplies after a storm the best option around here seems to be to get an 8k standby generator since it consumes so much less fuel than the larger ones. if you have natural gas you can have that hooked up and always have an endless supply. and if the gas lines are compromised after a really bad storm you keep a 100lb propane tank on standby which will last you a few days til the gas lines are fixed. its like having a small generator but its tied in and doesn't require the wifey to try and get it started and hooked up.
    another thing to consider is that a generator uses more fuel at full load as opposed to half load. usually a 5-7k will take roughly 5 gallons in 10-12 hrs. if you run it 24hrs a day, you need at least 10 gallons a day. thats a lot of gas. gas will be limited and thats the type of fuel most people will require. hope this helps
  6. Sep 30, 2011 at 11:21 AM
    davestaco
    davestaco TW's number one gear whore
    David
    Schofield Barracks
    00' tacoma xtra cab trd v6 4x4
    I got a titan industrial 5500 watt generator.....needs work though
  7. Sep 30, 2011 at 11:31 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    We do have gas lines for our house and thats what we use for our stove and hot water heater.
    I already have two 5 gallon gas cans and a few small ones. I would add two or three more 5 gallon cans to storage if I go the gasoline route.
    Also I had thought about building a small genorator "house" out of plywood to keep the genny in when in use in the back yard to help muffle some of the sound. just keep on end of it open to push it in and out of on the side and to vent.
  8. Sep 30, 2011 at 11:46 AM
    Cypherian
    Mid Atlantic Region
    The "Dog house style generator cover" works very well as for venting you can get the foundation type vents 6x24 or 8x24 and mount one lower one upper two per side only need to do three sides size the cover size is based on what the manual tells you for clearances. Then you can put a door on the end to make it completely invisible. Judd is correct about the gas and diesel most folks don't think ahead and I did not account for that. Having exp blizzards, ice storms, huricanes, Squirrels ( jumped into a transformer substation station) took the entire area down for 4 days etc. I have learned the hard way to be prepared.
    Cypher
  9. Sep 30, 2011 at 7:42 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    Last year we were having power surges BC of all the extreme cold weather and snow (not typical for this area but its happend two years in a row now) and my kid was around 8 months old last winter. When the power went out I was pretty worried about keeping him warm. Luckly the power came back on 45 mins later but people on the other side of town were not so luck, 6-8 hours with no power.
    I'd rather have it and not need it then the other way around. Kinda like car insurance and we never even think twice about not having that!
  10. Sep 30, 2011 at 7:48 PM
    Toyota Tacoma
    Toyota Tacoma Well-Known Member
    Brady
    Kelowna, bc
    dbl cab long box
    Suspension: -Bilistien 5100's all around -Add a leaf -Firestone ride rite air bags Performance: -K&N cold air -Borla cat back Stereo: -Pioneer AVH-X2500BT head unit -Kenwood 1400 shallow mount 12'' sub in custom box -Alpine 1100 amp -Alpine 400 4 channel -4 energy component 6.5's Wheels/tires: -17x9 with 4.5 backspacing XD hoss rims with 33'' bfTreadwright gaurd dogs and spidertrax spacers Looks: -Satoshi grille made by myself -Hood, front bumper, grille, roof, tailgate and rear bumper plasti-dipped. -BHLM -eyelids -matted out tailights -Tacoma bed mat Small mods : -Trailer 7 pin replaced and moved into bumper beside licence plate -Removed mud flaps -Repainted frame/lower a-arms, skid and rear diff/housing with por15 -Led bulbs -Interior lights replaced with blue led's -Beep on lock added
    I bought a kipor ig2000 watt generator and never looked back.
    Iv had if for about 2 years and not a single issue. It starts first pull every time and runs almost anything i throw at it.
    Its very fuel efficient, lightweight, Strong plastic case and very easy to do maintenance on.
    It cost me about 600 bucks. (cad)
    I was a bit skeptical at first (being a Chinese brand) but then i read the reviews and was sold, Plus you cant beat the price.
  11. Sep 30, 2011 at 7:57 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    the one i have is propane powered. and we use it in the winter a lot
  12. Sep 30, 2011 at 7:58 PM
    HUNT
    HUNT Well-Known Member
    Tommy
    Wildwood Ga
    2003 Double cab 4x4
    Bilstein 5100 set @ 0, OME 881,Wheelers 5-leaf, OME NitroCharger Sport shocks, 4-RUNNER LIMITED WHEELS, Duratracs, 265/75/16
    My 5500-Watt Briggs does great.Just had a 6 circuit transfer switch installed ,and love it ,no more drop cords to deal with.I keep my generator in my garage which is about 90ft from my house.so the sound is not bad and it stays dry.(my generator would not run in the rain,kept sucking warter up in the air filter).Now when the power goes out all I have to do is run my #10-4 100ft. drop cord from my garage to the house and I'm up and running in less than 5 min.
  13. Sep 30, 2011 at 8:01 PM
    RCBS
    RCBS Well-Known Member
    Harden your bark, there are storms on the horizon.
    http://www.mayberrys.com/honda/generator/html/requirements.htm
    I work in a shop that repairs generators. Go with Honda, Kubota, or Yamaha if reliability is important. Hondas will last decades if treated properly. We are a dealer, and the only time they come in for repair is when they've been abused or neglected.
    There are many cheap generators out there these days. They will sometimes do the job, and sometimes not. If the voltage regulator or rectifier dies, good luck finding parts to repair. If buying a generator for emergency purposes, don't skimp.
    Best advice I can give is to keep the carburetor dry during storage. It's not at all hard to turn off the gas and drain the float bowl when putting away. If you are dead set on storing the unit with fuel in it, it needs to be ran once a month at least. (just drain the freakin gas)
    Over 50% of all the repairs we do on all types of power equipment are fuel/carburetor related. I am not a fan of fuel stabilizers. Keep fresh fuel around. Remeber, your truck always has fresh fuel if you find youself in a dire situation.
    Also, you can always "backfeed" power through a 30 amp plug by connecting to a generator. Just be sure and turn off the main so you aren't backfeeding to the transformer...this is important as to not kill a lineman who thinks the line is "cold".
  14. Sep 30, 2011 at 8:05 PM
    Sampson90
    Sampson90 Well-Known Member
    Maryland
    2005 DC LB
  15. Sep 30, 2011 at 8:05 PM
    #35
    Saskquatch11
    Saskquatch11 TRUCK YEAH
    if you plan on using a generator for emergency backup for your furnace, a few lights, fridge, etc you will need to have those circuits fed from a sub panel. you will also need a transfer switch (some transfer switches are also load centres/panels).
  16. Sep 30, 2011 at 8:09 PM
    #36
    Saskquatch11
    yes that does work, however it is potentially hazardous and illegal (illegal here, not familiar with american codes).
  17. Sep 30, 2011 at 8:15 PM
    #37
    RCBS
    Agreed. But it will keep the heat on in an emergency.
  18. Sep 30, 2011 at 8:17 PM
    #38
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    X2
    Great way to barbeque your local ulility linemen if you don't isolate your house from the grid
  19. Sep 30, 2011 at 8:23 PM
    #39
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
    x3. whenever the power goes out during storms i always flip it off from the line when i use it, then turn on the main breaker in the house and crank it up. then reverse those steps to check if the powers back on.
  20. Sep 30, 2011 at 8:23 PM
    #40
    RCBS
    Yes, shutting down the main is absolutely necessary for safety reasons. Let me clarify "emergency". Emergency - We are going to freeze to death and grandma's breathing machine needs power, NOT: Emergency - Dammit, I'm missing the Canucks game!
