who running load range e tires?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MachoTaco10, Oct 23, 2010.
  1. Oct 23, 2010 at 4:01 PM
    MachoTaco10
    MachoTaco10 [OP] Well-Known Member
    Nick
    New Hampshire
    2010 Tacoma TRD Sport
    Hey guys, I am running load range E duratracs. Great tire, tougher than nails(literally) load range E is generall a 10 ply tire.
    My only complaint is that the tires are soo damn stiff and lead to a teeth chattering ride on any rough road. Load range E tires are definitely overkill for something as a light as a Tacoma even when loaded down to the max. Load range E tires are found on uparmored HMMV's, and f-350's and shit.
    I bought these because they were only 500 on craigslist and were basically brand new with only 500-600 miles on them.
    I am currently running them at 40 psi although then can handle up to 80 psi max.
    My question is who is running load range e's and what psi do you recommend. I know less psi will make the ride a little less firm but I also do not what to cause any pre-mature wear. thanks.
  2. Oct 23, 2010 at 4:21 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Start at 30 PSI and go up from there. Do the chaulk test to make sure they're not wearing unevenly (draw a chaulk line across the tire and go for a drive. If it wears out the center only, there's too much pressure in them, etc). Basically, like you mentioned, you bought tires that are overkill for your truck so you're kind of stuck with the consequences, sorry man.
  3. Oct 23, 2010 at 4:27 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    I set my BFG AT's between 30-32psi.
  4. Oct 23, 2010 at 4:47 PM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    HP60/14 bolt, Atlas 5.0.
    40's fine.
  5. Oct 23, 2010 at 4:53 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    mine are load E terra grapplers 32-35 PSI are in mine
  6. Oct 23, 2010 at 5:23 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I have E-rated Hankook Dynapro MT's , I run them at 35 PSI .
  7. Oct 23, 2010 at 5:40 PM
    Special_K
    Special_K o_o
    Eddie
    Alexandria, VA
    2019 Tacoma Cav Blue
    I've got the BFG KM2s load range E running them at 36. I was asking around since the tires can run at a higher psi but was told to go with the vehicle rating for psi vice running the psi rating on the tire. Rides nice
  8. Oct 23, 2010 at 5:55 PM
    Lunercrab
    Lunercrab Well-Known Member
    Beth
    Lehigh Valley area, PA
    2019 off road cement
    I have mine around 40 and the ride doesn't bother me so much. I was in the same boat as u my goodyears are e range but I got a deal too good to pass up at the time I bought them as well.
  9. Oct 23, 2010 at 6:41 PM
    Vidman
    Vidman Protected by Sig
    Rick
    central Mass
    2024 Trailhunter
    Not Enough
    I am running toyo open country mts with 28 lbs in the rear and 30 in the front. did the chaulk line and are wearing even. when my grizzly is in the bed i,ll bump the rears up to around 38 lbs
  10. Oct 23, 2010 at 6:45 PM
    Bsly862
    Bsly862 Well-Known Member
    Nate
    Denver, CO
    08 Off Road
    3in lift
    Im running my E Duratracs at 33...
    To me they dont seem rough at all, i love them
  11. Oct 23, 2010 at 8:01 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I just got rid of the stock Rugged Trails and went with 265/75/16 BFG A/T in the load range E. What a differance! They ride a bit rougher but not the bone jarring I read about. I think alot has to do with the psi in these tires. The truck feels more solid...doesn't feel like it is leaning in corners anymore. I took them up to 40 psi today and did the chalk test. The front wore even but the back still had chalk on the outside edges. I'll try 38 psi tomorrow and see how it looks.
  12. Oct 23, 2010 at 8:07 PM
    ycart1201
    ycart1201 Well-Known Member
    Nathan
    Oregon
    2016 DC TRD Sport 4x4 - My build is underway
    Current Project: 2016 DC TRD Sport 4x4
    bfg km2's at 36psi...
  13. Oct 23, 2010 at 9:59 PM
    scottri
    scottri Well-Known Member
    Scott
    Tigard Oregon
    '10 Sport DC TRD Sport PreRunner
    Cover King Seat Covers, WeatherTech Liners, PopNLock, storage bin locks, N-Fab Step bars, and G4 Elite Tonneau cover.
    I used to run E rated tires on my old Ranger, only because I got sick and tired of having flats repaired on shitty tires. They wore like iron, kind of a harsh ride but they were awesome for durablitly.
  14. Oct 23, 2010 at 10:12 PM
    matthew5olson
    matthew5olson Well-Known Member
    matthew
    pittsburgh, PA
    04 ext cab 3.4L 5spd 4x4 sr5
    K&N cold air intake, doug thorley headers, rear sensor simulator, flowmaster 40 series, magnecor plug wires, Royal Purple synthetic gear lube, airaid throttle body spacer, Hyperground system, flex-a-lite elec fan.
    32 for normal driving. then air them up if you doing some hauling.
    personally I run them at 80 all the time. you get more life out of them too
  15. Oct 23, 2010 at 10:16 PM
    OZ-T
    Peter North
    British Columbia
    Wow , buckboard wagon ride anyone ?
    That isn't too harsh a ride for you ?
  16. Oct 23, 2010 at 10:38 PM
    OffroadToy
    I don't see how you could get more life out of them and even tread wear by running 80 psi...please elaborate.:confused:
  17. Oct 23, 2010 at 11:02 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    As soon as you run non-factory recommended tires then you can run non-factory psi. A 10ply tire can go up to 80psi but I don't even run that in the 3/4ton with a load... Low 30's are what you should be shooting for.
  18. Oct 24, 2010 at 2:29 PM
    MachoTaco10
    Nick
    New Hampshire
    cool looks like ill keep them right about where I am running them. thanks
  19. Oct 24, 2010 at 4:27 PM
    Cummins
    Cummins Well-Known Member
    Robert
    Winchester, Ky
    05 Tacoma SR5 TRD
    I am in the market for tires and after reading thus site looks like Goodyear duratracs. I am all stock so going with 265/75/16 should I go with E or C rating???? I don't haul anything besides some hunting gear and farm stuff.
    Thanks,
    Robert
    tacolover406 likes this.
  20. Oct 24, 2010 at 5:08 PM
    Razorecko
    Razorecko Well-Known Member
    '09 Pyrite DCLB TRD Supercharged
    I have a lift and run load e duratracs at 32psi. I rather not have to screw around changing a flat on a lifted truck in the winter on the highway. My load e tires have been through hell and back and no nail could puncture them. Think runflats =)
    jjgandarillas likes this.
