who running load range e tires?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MachoTaco10, Oct 23, 2010.
  1. Oct 24, 2010 at 5:19 PM
    Cummins
    Cummins Well-Known Member
    Robert
    Winchester, Ky
    05 Tacoma SR5 TRD
    This is my first Tacoma always had 3/4 or bigger. Still run e rated on my cummins but didn't know about Tacoma. It does make sense though they will be tougher and going out through the fields and woods that will come in handy.
  2. Oct 24, 2010 at 5:36 PM
    wvmountaintop
    wvmountaintop Well-Known Member
    Dennis
    Hampshire County, WV
    2010 Tacoma 4 Door LB Sport
    Weather Tech Floor Mats, Anytime Fog Light Mod, Belt Chime Mod, Extra D-Rings under Bed Bolt, ARE MX Topper, Bed Rug
    The E range tires are quite a bit heavier than the C range, IIRC they are about 10 lbs more per tire. It's a trade off... E range tougher and more puncture resistant but will eat more gas and ride a bit rougher, C range not as tough but smoother ride and burn less gas... IMO If you off road or often drive where you might damage a tire then maybe go E range but if you spend most your time on the pavement go with C range... I love my Duratrac 265/70/17 E range but you can feel the weight of them on rough roads. I run mine about 40 psi.
  3. Oct 24, 2010 at 8:55 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    Duratracs "C"
    34psi front, 24 psi rear
    Perfect ride and handling.
    yes i got these pressures from doing the chalk test.
    It does make sence, our rear ends are so light.
  4. Oct 24, 2010 at 10:43 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    my trail grapplers are at 35 psi
  5. Nov 18, 2010 at 7:49 AM
    nvrenuf
    nvrenuf Whatever
    Saint Johns, FL
    '22 TRD Pro Taco; 6MT
    Shopping for new tires. I'm running a front leveling kit and rear spacer, so I think 265/70R17... Really looking at the Toyo Open Country A/T.
    <LI nodeIndex="1">Toyo Open Country All Terrain <LI nodeIndex="2">265/70R17, Toyo Open Country All Terrain<LI nodeIndex="3">Speed Rated = (S) up to 112 mph<LI nodeIndex="4">Max Load = 2535<LI nodeIndex="5">Tread Depth = 13/32<LI nodeIndex="6">Overall Diameter = 31.7""
    -or-
    <LI nodeIndex="1">Toyo Open Country All Terrain <LI nodeIndex="2">265/70R17, Toyo Open Country All Terrain<LI nodeIndex="3">Load Range = E<LI nodeIndex="4">Max Load = 3195<LI nodeIndex="5">Tread Depth = 16/32<LI nodeIndex="6">Overall Diameter = 31.6"
    Any Seggestions...?
  6. Nov 23, 2010 at 6:09 AM
    nvrenuf
    nvrenuf Whatever
    Saint Johns, FL
    bump. seggestions...?
  7. Nov 23, 2010 at 10:50 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I can't understand your first post . Are those your 2 choices of tires ?:confused:
  8. Nov 29, 2010 at 8:48 AM
    nvrenuf
    nvrenuf Whatever
    Saint Johns, FL
    Yea. I tried to copy and past the table from the website and this is how it showed up...
    Really, the debate is between the Load Range 'E' or not. But I called the dealer (4wheelParts.com) and he doesn't seem to think I would need them.
    I think I'm going with the 265/65/18 and the Dick Cepek Torque wheels...
  9. Nov 29, 2010 at 10:57 AM
    kramer2k
    kramer2k Well-Known Member
    Jacksonville, FL
    08 DC PreRunner TRD OR
    +1
    I also have Terra Grapplers load range E, and I shoot for 32 PSI. No complaints on ride quality here.
  10. Dec 11, 2010 at 9:59 AM
    matthew5olson
    matthew5olson Well-Known Member
    matthew
    pittsburgh, PA
    04 ext cab 3.4L 5spd 4x4 sr5
    K&N cold air intake, doug thorley headers, rear sensor simulator, flowmaster 40 series, magnecor plug wires, Royal Purple synthetic gear lube, airaid throttle body spacer, Hyperground system, flex-a-lite elec fan.
    btw in answer to some previous posts. The ride is a little stiff. Less sidewall flex. I have filled the bed completely full with gravel several times. its nice not to have to worry about a tire blowing out with that much weight.
    maybe not more mileage out of the tire so much as them not wearing out as quick. less wear and tear on the sidewall. i've seen people break cords in their p rated tires from loading them down often or to much.
    another not. i have never gotten a flat with any of my e rated tires
  11. Dec 11, 2010 at 10:02 AM
    matthew5olson
    matthew
    pittsburgh, PA
    I forgot to air up one day after wheeling though. I was running about 15 psi. It felt like a caddy to me.
  12. Jul 2, 2011 at 5:14 AM
    Tacoma Joe
    Tacoma Joe Member
    Joe
    Maryland
    09 Prerunner
    Total Chaos
    I just checked mine the other day and they had 32 psi in them. I took them up to 60 now and it doesnt ride too bad. I'm lifted anyway so not really a smooth ride anyhow. Thought 30's was too low for them
  13. Jul 2, 2011 at 9:14 AM
    extremachn1
    extremachn1 I am an asshole, deal with it!
    Turd Furgison
    Tucson, AZ
    BAD ASS SUPERCHARGED BEAST
    TRD S/C, TRD quick shifter, AFE CAI, Magnaflow cat back exhaust, Fox racing shocks, TC UCA, All-pro expo leafs, Bestop soft top, Wet Okole black seat covers, Scan gauge II.
    I run 40-45 PSI on my E rated 285's and they ride just fine. No harsh ride or anything. In fact for around town my BFG at 45psi get great gas milage.
  14. Jul 2, 2011 at 9:32 AM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    I am running a similar tire. Its a 10 ply tire that can be aired up to 90 psi if you are hauling a heavy trailer. I run them at 35 psi and have been very happy with them. They are 4 yrs old and the wear on them is very minimal.(This is on my work truck,so basically its a daily driver with high mileage) Mine are a Goodyear brand tire. The only reason I got them is b/c they were such a good deal at the time. I would actually get them again.
