Who runs "E" load rated tires?
Discussion in '1st Gen. Tacomas (1995-2004)' started by jathomas437, Nov 24, 2013.
  1. Nov 24, 2013 at 2:17 PM
    jathomas437
    jathomas437 [OP] Well-Known Member
    Angleton, TX
    1999 Tacoma SR5 Xtracab V6 4x4
    Opinions on running these tires on a Tacoma 4x4 with OME lift.
  2. Nov 24, 2013 at 3:09 PM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    what type of use/surfaces do your tires generally see? Are you a mall crawler, wknd offroader, or hardcore rock crawler?
    I run a set of Treadwright Wardens on load "D" BFG AT casings. I drive 90% on pavement but have put these tires to the test many times w/ jagged rocks, sticks, ledges etc and the sidewalls were more than stout enough to take it. They air down well and can handle a full load of firewood or a pallet of tile any day. That said, they are heavy as hell (53lbs! ea) and "E" tires would be even worse. I'm sure that a "C" or "P" rated tire would suffice but I wanted a little more confidence as ventured offroad.
    I think the consensus is that for how light our trucks are, and w/ our limited payload/towing capacity load range "E" tires are overkill.
  3. Nov 24, 2013 at 3:09 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I do
  4. Nov 24, 2013 at 3:19 PM
    jathomas437
    Angleton, TX
    Mostly commuting back and forth to work, and the occasional recreation off-roading. I agree, Es are overkill. I'd much prefer a D load range. But I've been looking around for tires, and just want an abundance to choose from. The more sizes and load ranges I take out of the equation, the less choices I have to choose from. Thanks for the reply.
  5. Nov 24, 2013 at 3:26 PM
    bzzr2
    bzzr2 Well-Known Member
    i run e rated, the added resistance to punctures is worth the bit of extra weight and the rougher ride as some consider it. my last cheapo goodyears rode ok, my newer dick cepeks ride great.
  6. Nov 24, 2013 at 3:27 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    I'm running E rated MT/R's...no complaints other than MPG loss but #whatever
  7. Nov 24, 2013 at 3:28 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    I'm running E BFG A/T KO's, i'd rather have a heavier duty tire and lose a MPG or 2.
  8. Nov 24, 2013 at 3:31 PM
    HBtaco02
    HBtaco02 Well-Known Member
    Allen
    Huntington Beach
    02 4wd SR5 TRD
    ARB Front Locker grey wire mod Camburg UCA's Extended Kings All-Pro expo's 10" Bilstien Brute Force Hybrid front bumper Smitty XRC8
    I run E rated. I don't see it as overkill. When I am off road in the middle of nowhere I like that I have a stronger ture.
  9. Nov 24, 2013 at 3:38 PM
    VeeSix
    VeeSix Yotahead, Deadhead.
    Tennessee, USA
    2011 Tacoma 4x4
    2018 Tacoma - gone 2003 Tacoma - gone 1983 FJ60 - gone 1988 BJ73 - gone 1992 FJ80 - eternal
    Same here. BFG AT/KO's. They ride hard, but I don't really care. When I go to 235/85/16's next year, I'm sure I'll still be in an E rated tire - most in that size are E rated. They're overkill, for sure, on a little truck.
    Correct me if I'm wrong - the E rating mainly means the sidewall is going to be thicker and stiffer, right? Thus the harsher ride?
  10. Nov 24, 2013 at 3:39 PM
    802Tacoma
    802Tacoma Well-Known Member
    E rated Cooper AT/3 235/85/16. No complaints.
  11. Nov 24, 2013 at 4:05 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    E rated cooper Discoverers. I've had them in some sharp rocks that I did not intend to be in and they held up just fine. I like them a lot :notsure: When I upgrade I'll probably stick with E rated.
  12. Nov 24, 2013 at 4:11 PM
    PCTaco
    PCTaco 36 hour Build
    Adam
    New Columbia, PA
    '18 Access Cab TRD Offroad RIP '13
    Working on it
    E rated Grabbers here.
    I lost almost 3 MPG off the stock rugged fails.
    Edit: I'm lost and in the wrong forum section, oops!
  13. Nov 24, 2013 at 4:23 PM
    elclem21
    elclem21 Quebeker
    Clément
    Alberta, Canada
    2009 Tacoma TRD DCLB
    OME 885x front, TC UCAs, OME Dakars rear, 4.30 gears, Eaton Detroit Truetrac (rear diff), HomerTaco Raptor Style satoshi grill
  14. Nov 24, 2013 at 4:24 PM
    Redfox1
    Redfox1 'Stralia! Riding Roo's and wrangling koalas
    Conner
    Santa Paula, CA and SLO
    09 Prerunner Sport TRD
    Browning Floor Mats, 275/70/17 BFG All-Terrain T/A's, Procomp 7089 wheels,Rear Spring TSB, Bilstein 5100's, LED roof light, seatbelt chime disabled, CB, UWS Toolbox,
    I run E rated tires. I like them the only issue I've had is airing down.
  15. Nov 24, 2013 at 5:21 PM
    jdkilroy
    jdkilroy Well-Known Member
    Jon
    Southern NH
    '02 4x4 SR5 Access Cab
    I run them on all my trucks. The Tundra and 4Runner because I have to be able to tow a fully loaded two-horse trailer. The Taco has E rated DuraTracs in 235/85/16. I like I can run around at 45 PSI to get a bump in mileage. Running the skinnier tire reduces the weight of the E tires a bit.
    I have had no trouble airing down to 12 ~ 15 PSI on either the Taco or the 4Runner. That's usually plenty low for the stuff I do.
  16. Nov 24, 2013 at 5:24 PM
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
    Toyo AT IIs in 10 ply on my truck. Both my spares are 10ply too.
  17. Nov 24, 2013 at 5:35 PM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    Running BFG AT's E (2nd gen) They are surprisingly smooth. I think I'll try the duratracs next though
  18. Nov 24, 2013 at 5:37 PM
    LAoffroadin
    LAoffroadin BURY ME WITH MY TACO!!
    Joshua
    Northwest
    2012 offroad 4x4
    ICON stage 5 coilers w/ ICON ucas, dakar leaf pack with Fox rears, k&n cai, LED cab light, raceline 16 inch wheels , toyo m/t 33",painted front yota emblem gloss white, retrofit headlights with mirrimoto 3 " lenses running the 6k headlights. Bhlm, bestopper, wet okole seat covers (max 4), weather tech mats,winch with piaa fogs. All pro apex front bumper. Sliders etc
    i have a set of toyo mud terrains rated e!
  19. Nov 24, 2013 at 5:48 PM
    jdkilroy
    Jon
    Southern NH
    The DuraTracs construction was changed last year and they weigh significantly less than the older construction. They replaced some of the steel with kevlar I believe. It resulted in a slightly lower cost as well.
  20. Nov 24, 2013 at 5:51 PM
    LAoffroadin
    Joshua
    Northwest
    2012 offroad 4x4
    OK IMO from what ive seen... the dura tracs are a good tire (compared to others) however i think its worth it to buy the ToYO open country mud terrains instead. they are just a stronger tire, last longer according to TWO different les schwabbs, do wayyy better in the MUD/SNOW, same amount of road noise. however they are a heavier tire, but i mean cmon... if your offroading.. does the weight of the tire matter THAT much to where it blances out all the pros? what yall think?
