who runs wheel locks?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoTuesday1, Apr 9, 2020.
  1. Apr 9, 2020 at 10:22 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    you can hammer on a socket one size smaller and blast them right off lol
    Skyway likes this.
  2. Apr 9, 2020 at 10:55 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Myth Busters endorse wheel locks
  3. Apr 9, 2020 at 12:57 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    A couple of years ago there was a rash of wheel thefts in the neighboring city. All that wheel locks did was get the car owner a broken window to get the lock out of the glove box. And if the lock wasn’t there, a ransacked car.
    Hikerbox and Skyway like this.
  4. Apr 9, 2020 at 1:07 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    No wheel locks for me,more trouble than they are worth.
    Skyway and Muddinfun like this.
  5. May 16, 2020 at 4:49 PM
    TacoTuesday1
    TacoTuesday1 [OP] Well-Known Member
    SD CA
    Got quoted $34 for OEM lock kit.
    Going to shop around to see if it's cheaper anywhere else,
    or cheaper aftermarket with the same function.
    I was expecting it to be $20
    Would not be convenient running late to work in the morning if the truck is found sitting on bricks.
    I think the OEM options are 00276-00900 and 00276-00901
    Not sure what the difference is
  6. May 16, 2020 at 4:57 PM
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    I'd bet some overzealous individual just hammered them down with an impact gun the last time they were put on. They have torque specs for lug nuts for a reason.
  7. May 16, 2020 at 5:59 PM
    TacoTuesday1
    SD CA
    Common at shops.
    Some lock keys are also sturdier than others.
    IDK if threads can seize. If yes, probably less likely if a vehicle gets tire rotations every 5k or however often.
  8. May 16, 2020 at 6:06 PM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    Definitely. I run two separate sets of locks from two reputable manufacturers, all of my lugnuts are locks!
  9. May 18, 2020 at 8:20 AM
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    I have McGard- I don't know the PN but IIRC I bought them on Ebay. I've not had any issues with them, but they're generally useless now as other have said. With a battery impact and a "turbo socket" a thief will get your wheels in a minute each, locks or not, if he wants them.
  10. May 18, 2020 at 8:25 AM
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    I put on the Toyota ones shortly after I bought my X-Runner. I think those were the only 18" wheels on any Toyota at the time, and I didn't want them to disappear.
  11. May 18, 2020 at 8:26 AM
    Hikerbox
    Hikerbox Well-Known Member
    2015 SR5 Access Cab
    I connected the inverter to a motion sensor that only activates when the car is shaken with the engine off. The inverter sends voltage to the wheels so if the thief connects to ground they get a nice zap.
    j/k but that would be cool
