Who says they don’t make plug n play remote starters for 3rd gen manual Tacoma’s? They do now!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by N2DesignsInc, Dec 9, 2018.
  1. Dec 14, 2018 at 12:46 AM
    N2DesignsInc
    N2DesignsInc [OP] --------------------------- N2 Designs, Inc. Vendor
    Los Angeles, CA
    2018 that identifies itself as a 2021
    Mods: Is this still a Tacoma?
    Thanks...but what are the risks? I am confused here...Not sure what I am missing because I don’t think I’m down playing anything if there are no risks, unless I am truly missing something, please let me know. I welcome feedback! Thanks!
    jmneill likes this.
  2. Dec 14, 2018 at 12:59 AM
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    Sure. 4 guys in my immediate area at work drive standards. Just asked them if they leave it out of gear with just the handbrake. 4 for 4 said no and its a dumb idea if you can avoid it.
    Quick search on thread here. Whether it's "frozen" or "loose".
    https://www.tacomaworld.com/search/7289960/?q=E-brake&t=post&o=date&c[title_only]=1
    Relying on the handbrake alone do anything more than a slight incline Just isn't something I would personally do.
    Like I said though, the addition of chock blocks is a different story. Or just don't use the starter on a hill. Still a cool product though.
  3. Dec 14, 2018 at 8:50 AM
    PsiBlast
    PsiBlast Well-Known Member
    Connecticut
    Question - In the demo videos I've seen, the person is hitting the lock button 3 times with a pause in between. Is that necessary to pause between presses, or can you press it three times fast in succession?
  4. Dec 14, 2018 at 11:09 AM
    Goochwarmer
    Goochwarmer Well-Known Member
    2017 Tacoma TRD Off Road MT
    Sure, but if you do a search here for folks asking if they have had their trucks move while parked on a slight incline in gear, you will note that several have had the issue. The compression is low enough that leaving the truck without the handbrake in first/reverse gear it posses the possibility of it moving...so it's not really leaving it in gear it's the handbrake that is doing the work, and in a year and a half of temps and snow/rain/sleet I haven't had a lockup. I get what you saying and at first it sounded like horsepucks but were not driving a 1988 subaru or 1974 dodge ram anymore where there were 4 or 5 gears and higher compression, mostly this is attributed to EPA standards and therefor 6 or more gears with lower compression.
    jmneill likes this.
  5. Dec 14, 2018 at 11:42 AM
    Big tall dave
    Big tall dave Well-Known Member
    Elora, Ontario, Canada
    2018 Tacoma TRD OR DCLB
    Yep, from my experience, it’s the rarely used parking brake cables that freeze up when they get water/moisture in them. Sometimes reaching underneath and giving them a good shake will free them up. If not, a hair dryer or heat gun in the lowest hanging points will usually release them. I use my parking brake everyday and have always washed my trucks regularly in the winter and have never had a problem.
    Looks like a great product and i’ll bet they’re gonna sell a ton of the them
    N2DesignsInc[OP] likes this.
  6. Dec 14, 2018 at 11:55 AM
    cascadetaco
    cascadetaco Toyota Addict
    central oregon
    2017 SR 4cyl 4x4 5speed
    Freezing isn't going to be an issue in Alaska...everything is always frozen there! Here where it gets above freezing during the day it is a problem. Stuff freezes up solid at night when temps drop!
    Skydvrr and Goochwarmer[QUOTED] like this.
  7. Dec 14, 2018 at 7:03 PM
    Halena Molokai
    Halena Molokai Well-Known Member
    Black 2016 TRD DCSB OR 4x4 MT6
    BFG KO2 265/70/17 Moto Metal 17x 9 -12mm ToyTec Boss 2.0 lift Kit Wet Okole, Ceramic tint 35% Bakflip F1 Flowmaster Exhaust Single in /Dual out with 3"stainless tips DashMat Covercraft Custom windshield shade Tilt Alarm Weatherbeater Mats Diode Dynamic LED upgrade to interior OEM Bed Mat OEM 5" Chrome Side Steps
    Old School Again lol, cut the rear emergency cable and away we go. In my garage or driveway I can see it working for me and I may consider this optoin. I guess for safety and theft purposes that's where the old school comes in to play, leaving it in gear to make it harder to tow or roll. But I applaud your efforts because it gives MT's the option. Keep up the good work $.02
  8. Dec 15, 2018 at 4:04 PM
    N2DesignsInc
    Los Angeles, CA
    He’s only doing it slow so you can see it; demo video. Do it as fast as you can as long as you get 3 lock chirps back to back. Heck, I press it 4, 5, 6 times fast just to make sure there are 3 successions in there somewhere...no pause needed but it can’t be so fast that you skip an audible “locking chirp”. It’s as fast as your vehicle can process the press of the button. So press it as many times as you want if you want to go fast.
  9. Dec 15, 2018 at 4:11 PM
    N2DesignsInc
    Los Angeles, CA
    Thanks!!!
    But question, couldn’t they pop it into first to crank start it down a hill? All it takes is breaking the window, crawling in and lowering the e-brake manually? Why would they tow or roll a manual transmission without ever going into the vehicle? I would think if it’s gear, they would rather take it out of gear than cut a line? I’m not sure if modern manuals will still crank/start when rolled and popped into first but I know cars in 90s could be...
  10. Dec 15, 2018 at 4:18 PM
    N2DesignsInc
    Los Angeles, CA
    Then I can only respond with use it when you’re not always on a hill or in the summer time if you live in that type of terrain, city folks don’t typically experience this the majority of the time so they can sacrifice not using it the few times they’re on a hill and still want to keep it in gear. With that said, if I’m not on a hill, I personally don’t leave it in gear (only use e-brake) because if someone backs into you or rams your parked car, your transmission won’t be at risk of damage. Only manuals have that luxury of avoiding the transmission strain during that type of scenario. Just my opinion but thanks for the kind words to all. It’s already a hit, wanted to share the news with the world because a lot of MT drivers have been requesting this with no attention from any company or product offering at all. It’s there for those who want it!
    https://www.n2designsinc.com/shop
    Halena Molokai likes this.
  11. Dec 15, 2018 at 4:20 PM
    SCJeffro
    SCJeffro @Voodoo_Blu_Taco
    2021 Voodoo Blue TRD Sport
    Awesome!! I will be in touch when I find a truck!!!
  12. Dec 15, 2018 at 6:49 PM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Re: frozen e-brakes.
    I had a habit of pulling my e-brake ~90-95% rather than the full pull. This left me just a little bit of margin for a good tug to break loose a stuck cable. That was on one particular car that had a habit of freezing. Can’t speak to anything in the past 20 years though. :)
    Goochwarmer likes this.
  13. Jan 8, 2019 at 12:41 AM
    N2DesignsInc
    Los Angeles, CA
    Thanks guys this has been a big hit thanks to people like yourselves!
    So much so that we created a plug n play kit for NON HKEY NON Push to start 3rd gens! This kit GIVES you a FOB for your base Tacoma’s so you don’t have to walk up to the door to unlock or lock anymore, you now have a power door lock FOB, as well as remote engine start/stop from a half mile away on the same FOB, and the ability to turn your hazards on or off from this FOB. The FOB has an audible two way sound and LED indicator to notify you if your button presses made it to the vehicle or not so your don’t have to worry wondering! You get two FOBs with this kit and you can also add the smart phone app module to it at anytime to do all this from anywhere in the world including GPS locate! NOW NO 3rd gen has been left behind from the remote start market! 100% Plug n Play! I felt it would be an injustice not to announce it here since not most people browse the classifieds on here, so with that said, I won’t get into details as the mods have been very kind to me and this is not a for sale thread, this is a public announcement post because we all live our Tacoma’s, it’s not fair that some mods are only trim applicable. We did the MT lots last month and they were a hit because no one catered to that small group either. Talk about Tacoma enthusiasts, that’s me. If you have an idea you’d like to PM me about to control anything on your vehicle via phone app, message me, I love challenges and innovating! Current projects I’m working on are independent power tailgate control (pop n lock sold separately), and a collaboration with a very well respected vendor here @mattgecko via remote start phone app. He sells bed and hood lights, were teaming up to sell a pre or post purchase/install interface so that you can use your remote start app to also turn lights on and off on your vehicle via the press of a button on the remote start app. Stay tuned and thanks for the support! This forum is one heck of a great family and resource, we’re going to give back in many awesome ways!
  14. Feb 4, 2019 at 1:57 PM
    3rd_gen_trd_taco
    3rd_gen_trd_taco Active Member
    Dan
    Bump for Jimmy. Another successful 6MT 3rd Gen with N2 remote start. Great company to work with. Had some issues with my alarm going off when remote starting and Jimmy took care of me right away. Buy it...you won’t be disappointed.
  15. Feb 4, 2019 at 3:10 PM
    #35
    WOTaco
    WOTaco Well-Known Member
    NY near the old capital
    2016 MGM DCSB TRD OR MT
    @N2DesignsInc
    Hi, Forgive my possible ignorance but....if the tpms will still function with the wire clipped, what exactly is that wire originally for?
  16. Feb 4, 2019 at 11:14 PM
    #36
    N2DesignsInc
    Los Angeles, CA
    It's not being clipped indefinitely. It's being clipped, then each open end (now that you have two ends) go to my 2-wire connector which then plugs into the remote starter, so we can bypass it during remote start then the contact is whole again post remote start as if it were "never clipped". It’s a must to start the vehicle. All remote starters on HKEY require this, not just mine.
    *edit - great question @WOTaco
    WOTaco[QUOTED] likes this.
  17. Jan 9, 2020 at 8:50 PM
    #37
    CdnSldr
    CdnSldr ______________
    Canada Eh!
    @N2DesignsInc Great looking product. Even better that the cell phone module will work in Canada.
    I do have a question about the setting sequence. How does opening/closing the rear door effect the arming of the remote start module, say to grab groceries or let the dogs out? i.e. a sequence of> neutral, park brake, foot off brake,ignition off, open drivers door, close drivers door, open rear door, close rear door, lock vehicle? Is it still armed? If not that would probably cause me not to purchase.
    Thanks!
  18. Jan 10, 2020 at 3:16 AM
    #38
    N2DesignsInc
    Los Angeles, CA
    When the last door is closed, it sets it. If the only door to open then close first is drivers door, then if you do open any other door, it has voided ready mode and must be done again. One way to avoid this is to open the drivers door, leave it open, then open the rear door, then shut drivers door, or leave driver's door open until everyone exits...bottom line, the last door to close sets the vehicle in a state of "remote start-ready". If it did not, then the whole point of ensuring safety really is pointless and doing all the steps preceding it would be a waste of time.
    The point is that we ensure that if a vehicle door is opened after it has been set to ready mode, then we assume that the e-brake might have been put down, the shifter bumped (intentionally put, or accidentally) into gear and so on. We watch the door opening because thats the only thing that always has power when the car is off. The E-brake signal and shifter position do not relay status when the vehicle is off, so there is no way to tell if it's state has or hasn't changed. I hope this makes sense and helps you understand why it is what it is. At the end of the day, safety and the health of your transmission/engine come first. Most folks embrace this notion at the end of the day...especially when there are no other solutions on the market for this vehicle and transmission combination. We were the first, and still remain the only ones.
    CdnSldr[QUOTED] and Jpalafox like this.
  19. Jan 10, 2020 at 4:43 AM
    #39
    NevadaNick
    NevadaNick Well-Known Member
    2017 Access Cab 4wd 4cyl MT
    Your link for shopping goes to a page that needs a login. Whats the cost ?
  20. Jan 10, 2020 at 5:04 AM
    #40
    H6G
    H6G Well-Known Member
    Far from home...
    ‘18 Blk. Pro/ ‘17 GT350
    '22 Pro suspension/ Custom Deaver springs/ ECGS and...
