Who takes pride in their yard?
Discussion in 'Off-Topic Discussion' started by RearViewMirror, Jun 5, 2014.
  1. Jun 10, 2014 at 7:48 AM
    #81
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    I mow 2 acres in about hour and thirty minutes with my Gravely Pro-turn 152. I could do it quicker but the back yard is so rough I can't run the Gravely wide open.
  2. Jun 10, 2014 at 8:15 AM
    #82
    krap22
    krap22 Well-Known Member
    i'm at about 90 min. to do a 1/2 acre with a toro self pace. I may look at upgrading to a bigger mower, but with a 15 yr old who can mow as well, i'm good with what I have. :cool:
  3. Jun 10, 2014 at 8:27 AM
    #83
    RearViewMirror
    RearViewMirror [OP] Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    Regular residential lot from edging, mowing, and blowing everything off takes me about an hour and 10 mins.
  4. Jun 10, 2014 at 8:59 AM
    #84
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I have about 1/3 acre, just mowing takes about 50 minutes. Edging takes another 20 or so, then I have the roses and garden to tend to, dog poop to collect, etc. I spend about 90 minutes to 2 hours.
  5. Jun 10, 2014 at 9:15 AM
    #85
    ace96
    Western KY
    It helps to have one of these
    It was a lot of $$$ but it has been well worth the investment. I was using a Troybilt POS zero turn. I cut the time in half with the Gravely.
  6. Jun 10, 2014 at 9:45 AM
    #86
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    30 minutes, maybe. 20 if the GF edges while I mow. :D
    Weeding, on the other hand...That takes quite a bit longer.:mad:
  7. Jun 10, 2014 at 1:45 PM
    #87
    yotarob2005
    yotarob2005 Kiss My IFS
    Rob
    Bryan , Tx
    05 D-cab trd sport long bed
    Front Bilstien 5100's Set @ 1.75", rear 5100's & TSB springs, Flowmaster, TRD seat covers, Toyota All weather floor mats, 265/70-17 Michelin LTX AT2's, some Debadgeding, BHLM, led bed lights, 886 back up lights, fog lights anytime mod, Extra d-rings, Toyota bed mat, sockmoney TRD decals, Kenwood 890DNX, Firestone ride-rite air bags, 2 car seats.
    I recently found & downloaded the Scott's fertilizer app. You input you zip code, what type of grass you have, what condition your lawn is currently in and how nice of a lawn you are trying to have and it builds you an annual program telling you what Scott's products to use and when. Then you set reminders / alarms so that you never miss a treatment. I think it's a pretty cool app.
  8. Jun 10, 2014 at 3:08 PM
    #88
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    I have seen that, but generally people will overfeed and use too many unnecessary chemicals. Using a mulching mower, mowing at the right height (and often enough to avoid adding stress), and proper irrigation can decrease the need for so many chemicals.
    Texas A&M used to have some good evapotranspiration rate info, which is what I used. Knowing your water application rate and how much your soil will absorb in a given amount of time will help you determine how to program your irrigation system. You can measure your application rate using rain gauges in different spots of the yard, and see how much time it takes for water to start pooling or running off. When I was in TX, (north of Austin), I could only run a station for 10 minutes before water started pooling. In the heat of the summer, I would run 2 rounds at 10 minutes per station 3 times per week to get the proper amount to soak in. That is the key thing people miss -- you can't just run each station longer, you have to give it time to soak in.
    I would fertilize twice a year using the plain Scotts lawn food at about half the recommended application rate, and I never had to spray for weeds.
    Here in the midwest we have those crappy rotating heads that take forever to put down any water, so I run pretty long station times. I miss my TX yard.
  9. Jun 10, 2014 at 9:05 PM
    #89
    RearViewMirror
    Craig Christ
    Completely agree with that. Most of the nitrogen and nutrients come from the grass clippings themselves. Like you, I've got the gear driven heads so it takes longer to water a specific spot in my yard. There is a fine line between over watering and waiting until it's just slightly too late to water where I live. I use a tuna can as a gauge to let me know how much water I've put down in a given area. In July and August when the temps top out over 100 most every day then generally you're just keeping the grass alive. Nothing beats rain water and city water lacks any of the minerals that assist the grass with what it needs. I tend to do 3 fertilization's per year and like you mentioned.... If your grass is thick enough the need for chemicals goes way down as far as weeds are concerned as the grass chokes them out.
  10. Jun 11, 2014 at 5:00 AM
    #90
    megillet
    megillet Resident Badass
    Mark
    Atlanta, GA
    2010 4x4 TRD Sport DCSB MGM 6sp
    I started using that app this year as this is out first home where I'm responsible for the yard work. Initially, my yard was more weeds that grass. Following the suggestions of this app along with a couple additional weed control spray applications, my yard went from the worst on the block to one of the top ten. I'll post pictures later.
  11. Jun 11, 2014 at 5:52 AM
    #91
    yotarob2005
    Rob
    Bryan , Tx
    I agree with you both about the app over doing it a bit with the recommendations, after all it was created to help Scott's sell fertilizer. I was already using Scott's products & like that it will remind you when to fertilize and with what product. I entered that my yard was already in good condition (true story) and that my goal was to maintain that & the program it gave me was for 3 total treatments throughout the year. However just to see what it would do I input that my yard was in the worst condition possible and that I wanted the best yard on the block and it wanted to schedule 6 treatments for the year. I deleted that entry. lol
    I already use a mulching mower for the nitrogen / nutrients and have it at the highest setting to try and promote stronger / deeper roots but when it comes to the science behind watering I still have a lot to learn.
  12. Jun 11, 2014 at 5:58 AM
    #92
    guitarjamman
    guitarjamman Well-Known Member
    Zach
    Northeast
    2019 Ram 2500
    I am trying to have a nice lawn as we just bought our first house last July. The backyard is in OK shape (I overseeded in the fall and fertilized in march), greened right up but still have a few trouble spots. Dog piss is giving me a few brown spots. The front yard is a wreck and needs to rebuilt. Too much shade and moss is taking over.
    My plan is to aerate in the fall, overseed the front yard and fertilize before winter sets in. Try to fertilize again next spring and hope to salvage it. I made the fatal mistake of pushing all the snow off the deck into the same spot all winter long and am left with a completely dead strip of lawn. Will definitely disperse the large piles this winter and keep the weight down right near the deck.
    Oh, and on a final note, fuck poison ivy. I can't seem to keep it under control - I have sprayed the hell out of it but it just keeps showing up.
    Lawn showing piss marks and area that piled up snow killed off (reseeded already)
    Crappy front lawn showing many bald areas. Hopefully some lime to take care of the moss, an aeration, and overseed can bring it back to life.
    Poison Ivy vine that I hacked off to kill the upper portion taking over a tree. Applied roundup to the cut vine in an effort to kill the root system.
  13. Jun 11, 2014 at 6:48 AM
    #93
    RearViewMirror
    Craig Christ
    You might want to aerate in July. That is usually when I have mine done as that is when my lawn starts needing more water. It also helps remove some of the thatch which helps the root system of the grass.
  14. Jun 11, 2014 at 6:50 AM
    #94
    RearViewMirror
    Craig Christ
    Scott makes quality fertilizer. That is the only fertilizer that I use in fact. It sounds as if you are doing it correctly also.
  15. Jun 11, 2014 at 9:30 AM
    #95
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    ET = Evapotranspiration Rate (this varies based on time of year and location in the world, your local agriculture board or universities should publish this for your area)
    Kc = Crop Coefficient (based on what you are growing, also varies duing the year)
    EFF = Irrigation system efficiency (using 85% is probably close enough)
    ET x Kc / EFF = how much water you need to put down
    Then you have to determine how much water your system puts down and how fast your soil absorbs it. Once you know all that, you can program your sprinkler system or time your watering properly.
    I just put together a spreadsheet based on monthly rates and adjusted my cycles on a monthly basis. Yes, I am slightly OCD.
    More info: http://texaset.tamu.edu/growers.php
    Kc values for turfgrasses: http://www.irrigationtoolbox.com/ReferenceDocuments/TechnicalPapers/IA/2008/2127translated.pdf
    The more you know . . .
  16. Jun 11, 2014 at 9:40 AM
    #96
    Noelie84
    Noel
    Wales, Maine
  17. Jun 11, 2014 at 9:46 AM
    #97
    yotarob2005
    Rob
    Bryan , Tx
    Thank you very much for this information! I will get to work on this.
  18. Jun 11, 2014 at 9:59 AM
    #98
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    This should make it easier for you and matches about what I had for central TX:
    http://www.riversideirrigation.com/watering.html
    I could only go 10 minutes at a time before the soil was saturated, not a full 15-20 minutes per station. You may have more sandy soil there, mine was mostly clay. I would go 2 rounds at 10 minutes each. Then just add a day or turn a day off depending on time of year. Don't water every day!
  19. Jun 11, 2014 at 10:26 AM
    #99
    jharkin
    jharkin Well-Known Member
    Jeremy
    Massachusetts
    14 DCSB TRD OR
    12volt/20amp bed outlet access tonneau
    I try to keep the lawn looking reasonably green and at least a majority actual grass without watering and as little pesticides/herbicides as possible. I dont like the idea of exposing my kids to the chemicals not to mention they all run off into our water supply. And sprinklers are a no-no because our town aquifers are so depleted due to overuse (from people attempting to make their lawns like a golf course :( ) we are in permanent water ban.
    We use natural/organic slow release fertilizers 1-2 times a year as needed, spot treat the worst of the weeds when necessary, mulch mow, dethatch when needed every few years and overseeding of thin spots annually to keep it up. I have used pesticides like grub killer when we had an obvious grub problem but prefer not to apply them "just because". Every few years Ill send a soil sample to the local university to find out if I need to add lime or adjust hte fertilizer mix. Overall the lawn does quite well but there are some spots that could use a topdressing of compost or aeration to help dead spots.
    We do put a LOT of effort into my wife's flower and vegetable beds and spent a lot on landscaping and outdoor entertainment/play equipment to make the yard an actual useful extension of the living space, not just an ornament.
    Back yard (overdue to be mowed)
    Wife'svegetable garden before it all started to sprout. We've had salad every day for two weeks form just these tiny beds.
    Front yard in April after we replanted the front border. The dead spots in the lawn have since grown in and that tree is a flowering dogwood that turns bright pink in May
  20. Jun 11, 2014 at 12:28 PM
    #100
    RearViewMirror
    Craig Christ
    I love that house and yard. It reminds me of a house that belongs in Great Britain for some reason.
