Who tows with a manual transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hookedontronics, Jan 28, 2010.
  1. Jan 28, 2010 at 5:47 AM
    hookedontronics
    hookedontronics [OP] Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    I finally test drove a few tacomas last night. Drove an auto and put 10miles on it and i was instantly bored, drove the manual and really liked it. I only plan on towing two nights a week for about an hour or so each way. Just wondering how you guys feel about it. I realize it's not a big deal, but an auto still makes towing a little easier. Just want to get some input from the guys who drive manual and occasionally tow.
    thanks
  2. Jan 28, 2010 at 5:50 AM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    I have towed a lot of heavy loads up and down mountains, long distance and sometimes non stop. The manual tranny works fine. Just becareful not to burn a clutch starting off on a good hill.
    What are you planning on towing?
  3. Jan 28, 2010 at 6:27 AM
    hookedontronics
    Jake
    Glenville, NY
    just a two place drive-in, drive-out trailer for the quads and snowmobiles. double axle
  4. Jan 28, 2010 at 6:30 AM
    Afwrestler1986
    Johnstown, NY
    You are golden. Don't even worry about it man.
  5. Jan 28, 2010 at 6:42 AM
    tanktodd
    tanktodd Well-Known Member
    Todd
    back on the right side of the bay, Ala
    08 Prerunner w/TRD Sport Pkg
    Limo tint in back w/ 20% on doors. Removed all badges. Stereo headunit, all new door speakers, 2 amps, and 10' sub...so far Black bullbar MotoMetals and 285/70/17 Duratracs. 3" OME springs in front and aal in back with tsb springs Black UWS tool box 5100's all around Plasti-dipped evo front end Fog light anytime mod OEM steps (for sale) HID fogs 55w 3000k HID heads 35 w 6000k "Cool white" dome & map lights
    I've towed an explorer on a fairly heavy trailer with no problems. Probably 6000-7000 lbs and the tacoma held it's own fine with manual trans.
  6. Jan 28, 2010 at 8:07 AM
    TBAGRR
    TBAGRR Well-Known Member
    Md
    07 4x4 sport
    Trd intake Doug Thorley long tubes URD short shifter Eibach front springs Tsb rear leafs
    I have prob towed with it 15-20 times, always a car on a double axle diamond plate car trailer! Loads weighing prob 3000-5000lbs and never had a prob, i really like how it tows, it takes a few times getting use to taking off, but i like it a lot!!!!!
  7. Jan 28, 2010 at 8:43 AM
    Demoncleaner
    Demoncleaner Well-Known Member
    Upstate NY
    05 Dcab 6spd 4x4 TRD Sport w/Tow
    TRD exhaust Homemade bed mat & bed extender, front Drings, Short clutch throw, Summer: Stock 17's Winter: Blizzaks on 16' black steelies
    Been towing my single place and my buddy's two place snowmobile trailer for 5 years. 6spd's shorter first and last gear compared to an auto, so loses mpg unloaded, but is perfect for towing. You can still use 6th most times and get reasonable mpg on the hwy w/ your typical <2000 lb trailer.
  8. Jan 28, 2010 at 9:03 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    I have towed a small 5X10 single axle utility trailer, towed cars on 3 different occassions with my buddy's 17' featherlite car trailer (no trailer brakes wired up just left plenty of stopping room) I would say around 4,500-5,000 lbs total weight, and I tow my seadoo which weighs practically nothing.
    The good thing you don't have to worry about driving a manual is there is no torque converter to build up heat and burn out, only a clutch disc that costs a few hundred bucks.
    With the really short first gear and a heavy load its actually really easy to get going and you dont have to slip the clutch much. I would even say you slip the clutch even less than driving with no trailer.
  9. Jan 28, 2010 at 10:26 AM
    thinkingman
    thinkingman Well-Known Member
    redmond WA
    2006 dbl cab 4wd 6sp
    Foglights are for fog, not oncoming traffic!
    Agreed with above...towing with a manual, given you know how to properly operate a clutch, is better than with an automatic.
    I towed a 21' Skidoo from Seattle to Lk Roosevelt in July, two mountain passes, approx 4k lbs, no problems other than flat tire on boat trailer, which the truck handled very well.
    99 degrees with the AC on, climb from Vantage to Snoqualmie Pass, no heat issues, 55mph in 5 gear.
  10. Jan 28, 2010 at 10:36 AM
    skulltacoma
    skulltacoma Make more better!
    BEN
    Calgary, AB, Canada
    2009 toyota tacoma trd modified
    CAI, dynomax turbo exhaust system,tinted windows medium on the fronts to match the backs, hid kit hi and low beam, pop and lock tailgate, painted calipers red with caliper paint, put 2.25' leveling kit in front and a 1" block in the rear. its now level and rides WAY better (readylift)>way nicer than the revtek my buddy has i think its garbage imo<, hurst "T" shifter, 18 x 10 american racing (can't remember the name) chrome rims with badass 5 inch lip :), 12 inch rockford fosgate punch with rockford fosgate 600 watt amp, bushwacker fender flares (cheaper than replacing the one i wrecked lol) ,kc light bar with kc lights, toyota aluminum stamped skid plate, and a skull front license plate. More mods to come, thinking a 6 inch lift and arb bumper etc etc.
    I have a access cab with a 6 speed and i know damn well it was well over weight but i pulled a outlander 800 quad in the bed, a tandam trailer with a full size ford with 35 inch boggers on it and gear with bbq and propane tanks and a dirtbike on the back :d it was heavy but i was able to still do 100 up the hills and 120 on the straights its way better to be able to pick your gear than guess with the auto... And well i wouldn't tow that again... But it was just one of those days.... and it was pretty hot out as well with the ac on and all i have to say is i like the cold air intake it helps with the fuel and torque when towing :D
    ( im canadain so the 100 and 120 thats kph not miles in miles its like 100= about 60 and 120 is about 70 mph )
  11. Jan 28, 2010 at 10:54 AM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    access cab, 6spd, pulled a double cab long bed taco about 800 miles through every condition possible. NO problems. I prefer it because you have the choice on gearing vs the auto which most people dont down shift with them.
  12. Jan 28, 2010 at 11:07 AM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    Check my gallery. :D towed a full size Ford, lumina, blazer, and a ranger all on U-Haul auto transports. Trucks probably pushed 6000lbs or more. Manual did fine.100 miles each time, 14mpg.
  13. Jan 28, 2010 at 7:42 PM
    trdtacoman31
    trdtacoman31 Well-Known Member
    Raleigh, NC
    2011 Titan Pro4x CC
    It's good to hear that the manual's are good for towing, and from how it sounds the clutches seem to hold up well also.
    To all TW users who read this thread: Anybody had any clutch problems associated with towing?
    BTW, Good thread- I was thinking of doing a poll about clutch problems to see how many people have had issues. I've read where some people have talked about premature clutch failures on 2nd gens.
  14. Jan 28, 2010 at 7:52 PM
    JeffRock
    JeffRock Well-Known Member
    Capital region, NY
    09 Tacoma accesscab 4x4 SR5 2.7L
    Toyota all weather floor mats. Mag light that clunks around in the jack compartment. Dog hair. Dog drool on the windows.
    I pull my pop up fine! But I only have a four banger.
    Which dealer did you go to? My friend was looking at Lia. Said they aren't budging on their prices.
  15. Jan 28, 2010 at 8:03 PM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    I tow all kinds of shit with my 6 speed. Works great for towing, just watch the clutch when starting on a hill.
  16. Jan 28, 2010 at 9:08 PM
    RZRob
    RZRob Well-Known Member
    Robert
    Anaheim Hills
    Wow, I don't think anyone can top Relentless Taco, but I've hauled my 3 rail moto trail with a couple bikes up the Cajon Pass and almost forgot the trailer was even there. For some reason my flat four connector needed a gender-swapper, but I'm a bit suspicious of the trailer connector more than the truck's.
    RZ Rob
  17. Jan 28, 2010 at 9:43 PM
    RelentlessFab
    Eric
    Yes it still is, and I can say I've towed over limit a tad on occasion for short distance and it still did fine IMO. Dont want to do it too often though(insurance and liability are the main reasons for me). The backhoe in the above pic is 6500lbs by itself, then figure in the trailer.
  18. Jan 29, 2010 at 4:49 AM
    piercedtiger
    Jon
    Southern Tier, NY
    Ok, so apparently I lied.... Not in my gallery.
    Apparently my rear axle shifted back a couple inches at some point, so I'm wondering if that's why it sagged so much. I haven't towed anything since the dealership noticed that, replaced the snapped centering bolts, and re-aligned the rear axle. It does seem to ride and handle bumps better tho! :D
  19. Jan 29, 2010 at 6:15 AM
    macgyver
    Brad
    Canton, GA
    Thats quite a bit of weight towing those trucks. Those uhaul trailers are pretty heavy themselves. If I were you, I would have backed the truck onto the trailer to distribute the weight better and take some weight off of the tongue. That would center the majority of the weight over the tailers axles but still give you enough weight on the tongue for stability.
  20. Jan 29, 2010 at 6:29 AM
    hookedontronics
    Jake
    Glenville, NY
    Also been looking at lia, and that's probally where i'm going to buy as well. Msrp on the truck is 31,025 and i was told they could do 28,900. I'm waiting to sell my wrx right now so i didn't go after a better price but i think they would probably go down a little off that as well
