Who uses a torque wrench for spark plugs?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TnShooter, Jul 19, 2021.
  1. Jul 19, 2021 at 8:51 PM
    Waasheem
    Waasheem
    2007 xrunner
    Torque wrench on spark plugs, never have.
    For the ones that are stubborn to remove, makes a skwaak noise, feels like you’re ripping the threads out, a couple tricks. Do it with the engine completely cool. Blow the spark plug area with an air blow gun to get any dirt out that likes to collect down in there. Crack it loose, maybe 1/2 to 1 turn out. Prepare your plug socket, extension and a T handle. Squirt some wd40 on the threads, tighten in, loosen out, repeat in and out, it’ll begin to feel like the wd40 is working down the threads. From there, sometimes it’ll spin out easy with the t handle. Sometimes it’ll feel free until you begin to loosen it out. Sometimes it just wants to skwaak all the way. Depending on how bad it is, you may need to repeat spraying it, then do a kinda back and forth tighten it in. In 1/3, out 1/4, repeat until it’s bottomed. Then the same bringing it out, out 1/3 in 1/4, repeat. Sometimes you’ll find a sweet spot where it feels free. Squirt again, work it in and out. Sometimes it’s really stubborn and the t handle doesn’t provide enough leverage to move it and you have to use a ratchet. If you do destroy the plug hole threads, it’s not the end of the world. There’s thread repair kits, KD makes a nice kit, just follow the instructions. If you’re not comfortable doing it, find someone who is.
    Anti seize is my friend. I’m a bit anal and like to scrub every fastener with wd40 then put it in with anti seize, unless lock tight is required, on my vehicles that is. When on the clock, everyone just wants it fast and cheap, not good.
    knayrb and R0dzilla75 like this.
  2. Jul 19, 2021 at 8:58 PM
    Bishop84
    Bishop84 Well-Known Member
    Every day, 15ft/lbs for the 5/8's and 13ft/lbs 14mm plugs.
    I do it so I remember, I do so many plugs professionally that I need the audible click to remember that I did the row.
    I've over tightened a few plugs, and most have been on tacoma 1GR in a hurry, the 15ft lbs just feels right and matches the washer crush that you need.
    That said I've never torqued a coil pack lol.
    b_r_o and TnShooter[OP] like this.
  3. Jul 19, 2021 at 9:08 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    In my 51 years working on engines I have never used a torque wrench for spark plugs or drain plugs. I also have never stripped out a spark plug or drain plug, lucky or not I think I have the hang of it by now.
    How the saying goes: I'd rather be lucky than good.
    Oh Crap! :eek:
    I just jinxed myself. Next time I do plugs I'll strip one for sure damn it.:mad:
  4. Jul 19, 2021 at 9:17 PM
    TacoTuesday1
    FL
    professionals develop hand feel
    it is easier for an amateur who does not have professional experience, to have a tool do that for them
    do you have a TQFR100C easily stored at torque
    or a cheap alternative that requires twisting a knob, doing a dance, jumping a backflip, and playing half an hour of chess each use to waste time setting it
    torque wrenches are for critical components like headbolts, a rare repair that is easy to set it up
    hold on I have to get a torque wrench to open this doorknob
    100 bolts on the car, let me spend 5 years operating them with a torque wrench
    let me listen to an automotive manufacturing engineer's made up torque spec instead of my own hand feel, from the same guy who designed a truck with problems and bolts elsewhere that loosen on their own due to his design parameters
    heard a story about some dumb guy once let's call him Bob "My experienced buddy Bob doesn't like Glocks because to remove the slide you have to pull the trigger and he shot his hand"
    12TRDTacoma likes this.
  5. Jul 19, 2021 at 9:20 PM
    Poncate
    Poncate Well-Known Member
    PNW
    04 DCSB 4x4
    Never did on cast heads. The torque is so low on these I use it to not over torque them
  6. Jul 19, 2021 at 9:31 PM
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    I've never owned a vehicle I needed to change plugs in...
    I took a Jeep Cherokee to 196K after buying it with 40K, and pretty sure the plugs were original equipment. I pretty much go by the old saying, :If it ain't broke, don't fix it."
    I've run a lot of cars a lot of miles, and sold all of them running fine on the plugs I bought them with.
    Most of the people I know that are religious about maintenance seem to have more problems with their vehicles than I do. I just don't seem to break vehicles. (knock on wood)
    In fact it's kind of gotten to be an interesting experiment, to see how little maintenance I can get away with. I've got a lawn mower I bought in '06 and have only changed oil in it twice. I just can't kill the damn thing.
  7. Jul 19, 2021 at 9:33 PM
    TacoTuesday1
    FL
    on some vehicles plugs take 20min to change
    both the car company and spark plug company say to change it at a certain mileage
    it is a few dollars
  8. Jul 19, 2021 at 9:33 PM
    Waasheem
    Waasheem
    2007 xrunner
    I’ve noticed Toyota puts a torque value for everything in the service manuals. it must confuse some into thinking I gotta get the torque wench for everything.
    Yeah lucky, most of the time my 6th sense will say DUCK. Most of the time, then I bonked my forehead hard enough to end up with two black eyes.
    I’ve never shot myself in the hand with my glock.
  9. Jul 19, 2021 at 9:33 PM
    Eastkat808
    Eastkat808 Well-Known Member
    Esket
    2012 DCLB 4x4 sr5
    bilstein 5100 cranked up
    I just make the sound with my mouth (click!) then I know it’s torqued
  10. Jul 19, 2021 at 9:35 PM
    TacoTuesday1
    FL
    probably because every automaker already has that information making it not difficult
    factories doing mass production have different kinds of tools that have torque values already preset into the machine for tightening certain bolts and it can be calculated by things like thread dimensions
    to remove the human factor from the equation and make it repeatable/the same all across the board for every car made
    they can't have a new guy at the factory undertighten everything causing 300 bolts to fall loose on a vehicle when it hits the road
    easy to pull the $5k tool hanging from the ceiling the car company provided to press a button and tighten a bolt, potentially even logging record into the system that it has been tightened
    on an engine sitting on the ground
    Not easy to work on that same engine 10k miles later when it's shoved under a cab body on a frame, with no room to put a torque wrench
    Like why did they put the UCA bolt facing forward and not backwards
    probably installed with the cab off
    Island Cruiser likes this.
  11. Jul 19, 2021 at 9:46 PM
    Travlr
    Middle'a Utah
    Sure... and any time or dollars spent unnecessarily is money down the toilet.
    I once had a car with 15K on it, and the power steering pump began to leak. It was repaired under warranty. The shop recommended the serpentine belt be changed, "Because it had cracks", and I refused. I sold the car years later with just under a 100K on it and the belt still had cracks.
  12. Jul 19, 2021 at 9:48 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    I do not
    TnShooter[QUOTED][OP] likes this.
  13. Jul 19, 2021 at 10:33 PM
    JeffBoyardee
    JeffBoyardee Well-Known Member
    Jeff
    Seminole, FL
    2011 TRD Off-Road Tacoma DCSB
    I do the same. I've got a wire wheel on a bench grinder in my work bench. Just about all the bolts get the wire, then anti-seize. Everything but spark plugs.
    Something to add to the spark plug thread repair, I've always caked the tool with thick grease. That way the grease holds the chips, and they don't fall in your cylinder.
  14. Jul 19, 2021 at 10:42 PM
    TacoTuesday1
    FL
    serp belts are usually due up to 100k
    seen one snap, either the belt or idler pulley
    driver lost hydraulic steering on the highway and got towed
  15. Jul 19, 2021 at 10:57 PM
    #35
    TnShooter
    TnShooter [OP] The TacomaWorld Stray
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    What happened when it was over torqued?
    Crack the plug?
  16. Jul 19, 2021 at 11:26 PM
    #36
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Nope. Go. till you feel the crush washer stop then just a hair more. Never had a problem
    12TRDTacoma and TnShooter[OP] like this.
  17. Jul 19, 2021 at 11:47 PM
    #37
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Only virgins use torque wrenches.
    dpele and TnShooter[OP] like this.
  18. Jul 19, 2021 at 11:49 PM
    #38
    Empty_Lord
    Dan
    I use mine for internal engine work or hub nuts.
    but everything else gets the German spec!
    Jimmyh and 12TRDTacoma[QUOTED] like this.
  19. Jul 19, 2021 at 11:58 PM
    #39
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Agreed. I reserve the use of torque wrenches on critical engine internal components alone. The rest gets German Torque Spec: Guttentite
    With saying that, the only reason I talk so much mess about them is because Toyota has made it some sort of religious practice to assign everything a torque spec. Torque wrenches do have their place in the automotive industry, but Toyota (and GMs) overusage of them makes me hate them. Realistically speaking though. I think the acknowledgement is there during the development and production of these FSMs that backyard mechanics and brand new scrub "techs" working in their dealer wide networks will be wrenching on these trucks, so I think it is more of a "cover our ass, minimize warranty repairs due to the idiocy factor" more than anything.
  20. Jul 20, 2021 at 6:10 AM
    #40
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Sometimes
    Hardscrabble likes this.
