Who uses wheel locks? Recommendations?
Discussion in 'Wheels & Tires' started by D44boy, Aug 5, 2012.
  1. Aug 5, 2012 at 9:45 AM
    D44boy
    D44boy [OP] Well-Known Member
    Kaneohe, hawaii
    2011 prerunner double cab
    Was looking to get a set of wheel locks. How many guys use em? Im referring to the keyed lugnuts. Are the factory ones good enough? Or should i look at getting an aftermarket one like gorilla? Thx in advance
  2. Aug 5, 2012 at 9:50 AM
    4x4Taco2012
    4x4Taco2012 Well-Known Member
    Tim
    Huntingdon Valley, PA
    2022 DCSB Limited 4x4
    TRD lift, TRD SEMA wheels, TRD skid plate, TRD Pro fog lights, TRD Heritage Grill, OEM bed cover, LT275/70/17 Falken Wildpeak AT3Ws, OEM bed lights, OEM all weather floor mats, OEM door skid plates, OEM mud guards, OEM bed mat, Black lug nuts
    I have the keyed lockers from Toyota on my '07 4Runner and '12 Taco and haven't had any problems.
  3. Aug 5, 2012 at 9:51 AM
    jandrews
    '09 FourDubDee TRD OR
    They're all pretty much the same - they might slow a thief down for 30 seconds while he gets his extractor socket, but that's about it.
    What you DO need to do is get the shitty Toyota OEM lugnuts off that truck before they strip out and leave you with a flat tire stuck on your vehicle.
    Just as susceptible, just at a different socket size.
    What I like about the Gorilla lugs is at least they don't fall apart with use like the OEM.
  4. Aug 5, 2012 at 10:13 AM
    D44boy
    Kaneohe, hawaii
    Thanks for info guys. Didnt know about the stripping problem with oem too.
  5. Aug 5, 2012 at 10:27 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Sears sells a very effective $50 Craftsman "Lug Out" socket set that bites into the outside diameter of wheel locks. It works similar in principle to the bolt extractor wolfpack_5150 mentioned, but this one is actually specially designed to bite through the lock's chrome plating.
    http://www.sears.com/craftsman-3-pc-flip-socket-set-with-red/p-00947392000P?prdNo=1&blockNo=1&blockType=G1
    Gorilla sells wheel locks PN 61631 with a spinning sleeve that resists the extractor sockets. Note these have a conical seat, so don't fit Tacoma OEM alloys.
  6. Aug 5, 2012 at 10:38 AM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    i don't even bother with wheel locks, i'm on the trail ofton enough and only imagine how much it would suck if i lost or misplaced the wheel lock key while trying to perform a trail side repair or to swap out a flat tire :cookiemonster:
  7. Aug 5, 2012 at 10:39 AM
    extremachn1
    extremachn1 I am an asshole, deal with it!
    Turd Furgison
    Tucson, AZ
    BAD ASS SUPERCHARGED BEAST
    TRD S/C, TRD quick shifter, AFE CAI, Magnaflow cat back exhaust, Fox racing shocks, TC UCA, All-pro expo leafs, Bestop soft top, Wet Okole black seat covers, Scan gauge II.
    I use one of these on my aftermarket Method Race wheels to keep people away.
  8. Aug 5, 2012 at 10:55 AM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    i don’t bother with them at all. they are not all that hard to get off. so it’s not stopping anyone from steeling them. would hate to get a flat and lose the key and not be able to take the tire off and put spare on.
  9. Aug 5, 2012 at 11:10 AM
    jandrews
    Conical seat works with most OEM alloys. My wheels haven't fallen off yet :D
  10. Aug 5, 2012 at 12:24 PM
    KenLyns
    Belly of the Beast
    Huh? Pretty sure the counterbore on the OEM alloy lug hole has a flat bottom. That's why the OEM lugnuts have a washer. Unless the Tundra alloys are different?
  11. Aug 5, 2012 at 12:40 PM
    CRU
    CRU Well-Known Member
    Seminole Cnty, FL
    07 SSM TuRD Sport DCLB
    20" Enkei WT4 wrapped in Bridgestone Dueler A/T Revo 3 265/50, Steel braided brake lines, Pioneer AVH-X5500BHS deck w/JBL GTO cones, OEM Smoked headlights, OEM LED tails, Clazzio seat covers, aFe Pro-Dry S air filter, Fumoto oil valve, Grillcraft MX grille w/Land Cruiser "TOYOTA" emblem, Redline QuickLIFT hood struts, Leather TRD shift knob, 13" shorty antenna
    If someone wants your wheels bad enough, they'll get them. I have a gorilla lock set just to deter opportunist and punk thieves in the neighborhood. Good quality. Can't complain.
  12. Aug 5, 2012 at 1:21 PM
    DevL
    DevL Well-Known Member
    Who wants to steal a $150 wheel with a gawdam 50 pound tire on it? Wheel thieves go for expensive wheels with low profile tires they ca get at with a low profile floor jack.
  13. Aug 5, 2012 at 1:24 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    +1
    This isn't 1968 anymore when wheel theft was a big business in the ghetto.
    I've had a lot of stereos stolen and a lot of vandalism. Never had a wheel stolen.
  14. Aug 5, 2012 at 1:25 PM
    TeamSarcasm
    TeamSarcasm Flawless Escalation to the Ludicrous
    The better coast
    People will steal anything, my friend had a EMPTY plastic 5$ container in his truck an someone broke the window and took it.
    To a thief, 150$ is 150$, especially if it will sell.
  15. Aug 5, 2012 at 1:30 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    You knew it was empty, but the thief didn't unless it was open and obviously empty.
    Wheels? It's too much risk to try and get all four off without someone passing by and noticing. One, you look like you're changing a flat.
    Once you get beyond that, people will call the cops in a heartbeat anywhere but gangland when it's obvious you're removing wheels and leaving the car on the ground or on blocks.
    Thieves will go for the quick "smash and grab" where they might score electronics or might get skunked, but there's little risk to popping a window and grabbing anything available.
  16. Aug 5, 2012 at 1:32 PM
    KenLyns
    Belly of the Beast
    $150 wheel x 4, with tires, can fetch good money on Craigslist. Hell, there have been a couple of reports on TW of spare tires getting stolen.
  17. Aug 5, 2012 at 1:37 PM
    TeamSarcasm
    The better coast
    Yeah it was an emtpy box with the top off, see-through and everything. Fresno, CA pretty shitty in some areas. When I graduate I am definitely looking for a job somewhere nicer :D
  18. Aug 5, 2012 at 1:38 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Oh.
    Fresno.
    I took my ex wife to Fresno and left her in the car with the door unlocked because I knew someone would steal her.
  19. Aug 5, 2012 at 1:50 PM
    jandrews
    Long as the conical seat is larger than the bore hole and centered in the lug nut, it'll still work fine...
    You'll notice all the lug nuts Wheeler's Offroad sells for 2gen Tacomas are conical seat...
  20. Aug 5, 2012 at 2:03 PM
    KenLyns
    Belly of the Beast
    "CHROME Lug Nuts for Factory Alloy Wheels"
    "CHROME Lug Lock Set for Factory Alloy Wheels (4 locks w/ key):
    15.95 Flange style nut with integrated washer, these are for your factory alloy wheels only. 12mmx1.5"
    Weezeemule likes this.
