Who wants to help an idiot with wiring?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 44-16 Taco, Jan 31, 2025.
  1. Jan 31, 2025 at 1:41 PM
    44-16 Taco
    44-16 Taco [OP] Do I look like a guy with a plan?
    KMS
    2017 SuperWhite DCORSB
    So yeah. Rigid ditch lights were wired to a ch4x4 switch and I pulled them apart to wire in an illumination harness and I didn't pay attention to my old wiring setup. Not my proudest moment.
    So the harness clips in to the cargo lights and runs to the bottom two wires on the switch, the ground and illumination. The switch lights up with rest of interior like it should. Here's where the fun starts.
    So I have the power/ground and the red/black from my lights sorted. I know green goes to positive and top red in switch goes to lights. I have tried all the combos that make sense to me and none seem to work.
    So, who wants to help an idiot with wiring?
  2. Jan 31, 2025 at 2:26 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    I'm an idiot with wiring/electrical as well but maybe together, we can make some good guesses!
  3. Jan 31, 2025 at 2:29 PM
    44-16 Taco
    KMS
    :fistbump:
    Phlogiston[QUOTED] likes this.
  4. Jan 31, 2025 at 2:47 PM
    shaggy135
    shaggy135 Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    So the Green goes to the 12V power with a fuse.
    Red next to that goes to the relay.
    Red after that goes to the illumination.
    Black to ground.
    44-16 Taco[OP] likes this.
  5. Jan 31, 2025 at 2:52 PM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Like this?
  6. Jan 31, 2025 at 2:54 PM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    I went more like this, so the light on the switch only comes on with the switch..Left the illumination alone.
  7. Jan 31, 2025 at 2:59 PM
    44-16 Taco
    KMS
    I had found those but my problem is I'm only working with the top two wires (green/red power/equip) due to the harness used. So I'm struggling with the wiring of the lights (red/black) to the red equip wire as I know the green goes to power. Also assuming I don't need a ground now because the black is grounded into the cargo light harness?
  8. Jan 31, 2025 at 3:18 PM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Where's the relay.
    Where are your switches getting power from?
    Battery goes to a fused relay.
    Switch and lights connect to relay.
  9. Jan 31, 2025 at 3:25 PM
    shaggy135
    The green stays with power and the red next to it goes to the equipment relay, next red should go to red in the harness and black to the black in the harness. If that doesn't work, then put the black to a real ground.
  10. Jan 31, 2025 at 3:27 PM
    44-16 Taco
    KMS
    There was never a relay on the setup as it was a low draw being two small pods. Just a fuse on the positive battery line. Everything worked fine but the switch was constantly lit up so i bought a harness from caliraised that plugs into the cargo light and splits off to the switch. Black and red are run to there. It leaves me with the green for power and the red for lights from switch and the positive/ground for power and black/red from lights to connect up
  11. Jan 31, 2025 at 3:52 PM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Someone can pipe in where I'm off.:D
    All black go together.
    Red from lights go the switch and I don't know what you do with green....to truck acc for illumination?
    You might have the wrong switch for what you're trying to do.
    If you want to use that switch, you might have to jump some wires, for your use case but I don't know which ones.
  12. Jan 31, 2025 at 4:39 PM
    44-16 Taco
    KMS
    So I'm probably not articulating this well because as I said, I'm kind of an idiot when it comes to 12v wiring.
    So 3 and 4 are tied back in the harness to make the switch light up along with the rest of the lights on the interior. I'm certainly no expert but I'm pretty sure it is the proper harness designed for this specific usage.
    It leaves me with wires 1 and 2 for the power and lights. I have the red to positive on battery, which should go to green or 1. I'm left with the black from ground and red/black from the lights themselves and I've tried red to 2 no lights.
    I had wired this up like 3 years ago and lights worked fine but the switch was always illuminated so I bought this harness to fix that. As is the switch lights up as it should with truck lights I just can't figure out how I had the lights wired up before.
  13. Jan 31, 2025 at 4:58 PM
    shaggy135
    So there is a red from the battery and a black from ground? What is going to the lights?
    How about:
    Green (1) to the battery.
    Red (2) to the positive for lights.
    Red (3) to the illumination - pos harness.
    Black (4) to ground, negative for the lights, and neg harness.
    You should really look into using a relay too.
    bkhlrTaco's likes this.
  14. Jan 31, 2025 at 5:01 PM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    This is why I gave up on the illumination part. haha.
    My switch light only comes on if the switch is on.
  15. Jan 31, 2025 at 5:04 PM
    shaggy135
    I have mild OCD, ha. If its meant to light up, I light them up. I just rewired my seat heaters and had to figure out how to dim the switches. Damn things have 6 wires, with 2 being "grounds." Had to split them up and figure out which was for dimming. I guessed correctly on the first try. Thanks Toyota for not doing dimming the normal way....
    bkhlrTaco's[QUOTED] likes this.
  16. Jan 31, 2025 at 5:05 PM
    fathomblue
    fathomblue I used to be disgusted; now I'm just amused.
    Richard
    Eastern Kansas
    Cavalry Blue 2019 DCSB SR5 4x4
    It sounds like you have the switch illumination hooked up correctly. In your picture the wires I circled are the leads to the lights right? If so, hook the green wire on the switch to the battery or wherever you're taking power from, then the red wire from switch to red wire on lights. The black wires from the lights then go to chassis ground.
    The black wire on the switch just grounds the switch illumination, not your ditch lights.
    Edit: And yeah, I think you really should be using a relay.
  17. Jan 31, 2025 at 5:06 PM
    shaggy135
    That's the missing piece.
  18. Jan 31, 2025 at 6:36 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    OMG, I read everyone of these, sounds like an Abbott & Costello script.
  19. Jan 31, 2025 at 6:39 PM
    Willy Lump Lump
    Willy Lump Lump Well-Known Member
    21’ dcsbmt
    This and that
    2 reds to the red reds, green to the black and is there two switches? Wait wait wait. Let’s start over.
    44-16 Taco[OP] and bkhlrTaco's like this.
  20. Feb 1, 2025 at 5:23 AM
    44-16 Taco
    KMS
    Thanks for the explanation, I am going to give this a shot. To add a relay, would it go on the hot/ground after the fuse or before? Does it matter? Is a generic 12v relay ok to use?
