Whole driver side going in an out?
Discussion in 'Audio & Video' started by Dgoode9, Sep 30, 2019.
  1. Sep 30, 2019 at 6:23 AM
    Dgoode9
    Dgoode9 [OP] Well-Known Member
    Columbus, OH
    2009 TRD Sport
    I’ve searched and could only find post regarding aftermarket speakers. Just started today, front and back driver speakers cut out.
    If I go over a good bump or a hard turn, they’ll cut in but go right back out. I’m using a Bluetooth transmitter, but after turning it to just radios and unplugging the transmitter, same thing happens. Maybe a bad plug? Any ideas are awesome. Thanks!
  2. Sep 30, 2019 at 7:26 AM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    If I was guessing, I’d say the radio has something internal going on.
    Here’s why I think that
    One common cause of speakers cutting in and out is a short. A speaker wire somewhere in the truck is touching metal it shouldn’t be touching.
    I don’t think it is this because Toyota radios typically shut off ALL the speakers when this happens.
    Some other possibilities would be the wiring connector going into each speaker in the door, but it’s unlikely that both doors would be doing it at the same time over the same bumps.
    Then there’s the connectors behind the radio. Highly unlikely that it’s these either, because the front speakers are in one plug (along with the main radio power) and the rear speakers are in a separate plug. Toyota connectors make very solid connections so the likelihood of both connectors coming undone just enough for a front and rear speaker to quit but everything else to keep working is going to be nearly impossible.
    All that to say, I think it’s the radio.
    Dgoode9[OP] likes this.
  3. Sep 30, 2019 at 9:18 AM
    Dgoode9
    Columbus, OH
    2009 TRD Sport
    Thank you for the response. Is there anyway to check that other than with another head unit? Everything iS OEM, if that helps. Thanks again.
  4. Sep 30, 2019 at 9:37 AM
    destin_meeks
    Destin
    Tuscaloosa, AL
    not really unfortunately. You could pull the radio out and test it on the bench, but you wouldn't be able to replicate the bumps and stuff that cause the issue.
    Or find someone with a 2nd gen tacoma and ask to throw your radio in there and see if it replicates in their truck
  5. Sep 30, 2019 at 9:48 AM
    Dgoode9
    Columbus, OH
    2009 TRD Sport
    So just try and replace the head unit and see if that fixes it?
  6. Sep 30, 2019 at 9:52 AM
    destin_meeks
    Destin
    Tuscaloosa, AL
    Yeah that’s probably your best bet. There just aren’t enough troubleshooting options to link it to anything else.
    That being said, no guarantees a new radio will fix it because we don’t 100% know what the actual problem is (but if I was a gambling man, my money would be on the radio dying)
  7. Sep 30, 2019 at 9:53 AM
    Dgoode9
    Columbus, OH
    2009 TRD Sport
    The head unit going bad could really cause the whole one side to act up??
  8. Sep 30, 2019 at 9:57 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Does anyone have a wiring diagram? It could be that there is a loose connector somewhere along the path that is shared by the speakers on each side. For example, the door speakers in my truck go through a connector under the kick panel in the foot wells.
  9. Sep 30, 2019 at 10:01 AM
    destin_meeks
    Destin
    Tuscaloosa, AL
    yeah, the radio has 4 amplifier channels in it, and those amps could be going bad, or there is a loose connection or a broken solder joint somewhere inside. lot's of stuff going on in there
    also, is this the JBL or non-JBL system?
  10. Sep 30, 2019 at 10:02 AM
    Dgoode9
    Columbus, OH
    2009 TRD Sport
    Non JBL
  11. Sep 30, 2019 at 10:03 AM
    destin_meeks
    Destin
    Tuscaloosa, AL
    Ok just making sure.
    that's actually a good thought. I pulled the diagram and unfortunately those wires aren't in any share connectors.
  12. Sep 30, 2019 at 10:06 AM
    Dgoode9
    Columbus, OH
    2009 TRD Sport
    So?
  13. Sep 30, 2019 at 10:13 AM
    destin_meeks
    Destin
    Tuscaloosa, AL
    still sticking with replace the radio
    0xDEADBEEF likes this.
  14. Sep 30, 2019 at 10:32 AM
    Dgoode9
    Columbus, OH
    2009 TRD Sport
    Damnit lol
  15. Sep 30, 2019 at 10:35 AM
    0xDEADBEEF
    Time to bust out the magnifying glass and look at some joints.
  16. Sep 30, 2019 at 10:35 AM
    destin_meeks
    Destin
    Tuscaloosa, AL
    but hey, at least you'll get built-in bluetooth and some of the newer features, plus more power output.
  17. Sep 30, 2019 at 1:11 PM
    Dgoode9
    Columbus, OH
    2009 TRD Sport
    Are the newer (2012-2015) touchscreen ones pretty much plug and play?
