whole house humidifier 24v question? help
Discussion in 'Garage / Workshop' started by Airun, Dec 30, 2012.
  1. Dec 30, 2012 at 5:05 PM
    Airun
    Airun [OP] Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
    OK gurus of HVAC if you're out there. I've gone round and round with this and have had 2 different hvac guys fail. I need 24v to switch humi on WITH furnace (obvious to me but not the DB that did our new system), and can't figure out how to get it off furnace board. can I just use the same terminals on my t stat that run furnace?
    edit: ok my t stat wires get 24v when the blower is off. WTH?
  2. Jan 7, 2013 at 5:33 PM
    Tacobilly
    Tacobilly New Member
    Bill
    Next to TJ
    4x4 TRD
    None.....YET!
    One wire to the "C" or Common, the other wire to the "W" on the furnace control board.
  3. Jan 7, 2013 at 6:18 PM
    section m
    section m Well-Known Member
    Rapid City
    09 TRD Off Road SR5
    I would use a 120/24 volt transformer. I would hook up the 120 side to the eac terminal on the board and then run the 24 volt side thru a humidistat and then to the solenoid valve. This way the transformer is only energized when the blower comes on.
