Who's done the valvebody upgrade?
Discussion in 'Performance and Tuning' started by 68vert, Jan 22, 2016.
  1. Jan 22, 2016 at 12:25 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
  2. Jan 22, 2016 at 12:25 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    I asked around on xru a couple yrs ago and got ipt reccomended
  3. Jan 22, 2016 at 12:28 PM
    thewarriordinghy
    thewarriordinghy General Lee's Titan
    Ben
    Georgia
    2017 Nissan Titan 4x4
    Temporarily Stock
    It may be bc my truck is N/A. They pointed to it may be OK with low power, but it seems high power it may blow? How expensive is the other one?
  4. Jan 22, 2016 at 12:30 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
  5. Jan 22, 2016 at 12:31 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    I forgot Gadget had a level 10 worked trans many moons ago. Maybe thats who suggested them?
  6. Jan 22, 2016 at 12:38 PM
    68vert
    68vert [OP] Well-Known Member
    AZ
    DCSB 4X
    thewarriordinghy likes this.
  7. Jan 22, 2016 at 12:52 PM
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    It's on the calling all transmission issues thread. I was throwing my problem in there... I just need a cheap DIY solution, if I even need one
  8. Jan 22, 2016 at 12:58 PM
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    Valve body upgrade is supposedly the fix according to them, they say the slipping from 4th to 5th is normal.
  9. Jan 22, 2016 at 12:59 PM
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
  10. Jan 22, 2016 at 1:02 PM
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    They said level ten is DIY? What's the difference in IPT and level ten install
  11. Jan 22, 2016 at 1:11 PM
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    Then what is the difference in the kit?
  12. Jan 22, 2016 at 1:18 PM
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    how hard is the install? I got a jumpsuit so I can bathe in fluids from working on shit lol...
    Biscuits likes this.
  13. Jan 22, 2016 at 1:19 PM
    68vert
    AZ
    DCSB 4X
    watch the video. looks easy. My worry is breaking one of the connectors or forgetting what goes where even with pics etc
  14. Jan 22, 2016 at 1:21 PM
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    My. Buddy is the district manager of jiffy lube, so I could slip him some cash and we could do it...
  15. Jan 22, 2016 at 1:27 PM
    #35
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    We put my manifold spacer on... He restores cars and builds motors on the side... He knows his stuff.
  16. Jan 22, 2016 at 1:43 PM
    #36
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    He's restored a Chevy truck, an old beetle, a corolla, all within the past 3 years in his spare time.
  17. Jan 23, 2016 at 11:13 AM
    #37
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    @iniazy did this DIY with Level 10 components.
    http://www.xr-underground.com/forum/showthread.php?t=56514
    The main point here, is that if you have an auto transmission, added weight, added power, or both, this upgrade will undeniably prolong and save your transmission. Whether IPT does it for you, or you do it yourself.
    The OEM shifting has smooth engagement with lots of slipping. Driving with the valve body upgrade is firmer. Not neck breaking, or intolerable. Unless you're a sissy. Protect the trans, or be a sissy....
    Justus, StAndrew and nfs257 like this.
  18. Jan 23, 2016 at 12:20 PM
    #38
    ThomasMore66
    At 45k miles. The 4-5 thing is getting annoying. I only notice the hang there. On full mash, my 2-3 shift runs to the rev limiter before shifting. That's a new development.
  19. Jan 23, 2016 at 12:30 PM
    #39
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    I have the whole tranny, valve body, and torque converter from Level 10 and have had ZERO issues. Granted there is only about 30,000 miles on them.
    Rock Lobster likes this.
  20. Jan 23, 2016 at 12:41 PM
    #40
    ThomasMore66
    What did that run you?
