Who's done the valvebody upgrade?
Discussion in 'Performance and Tuning' started by 68vert, Jan 22, 2016.
  1. Jan 23, 2016 at 12:49 PM
    #41
    gearcruncher
    Canadain bumper technician
  2. Jan 23, 2016 at 1:05 PM
    #42
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    Just over $5k
  3. Jan 23, 2016 at 2:10 PM
    #43
    ThomasMore66
    Dallas/Fort Worth & Durango
    That was my guess. What else got upgraded besides the valve body?
  4. Jan 23, 2016 at 2:42 PM
    #44
    thewarriordinghy
    thewarriordinghy General Lee's Titan
    Ben
    Georgia
    2017 Nissan Titan 4x4
    Temporarily Stock
    So you ARE a fan of level 10?
  5. Jan 23, 2016 at 2:49 PM
    #45
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Probably had the Torque converter stall speed adjusted and upgraded clutches in the trans. Even with the shift kit, the Toyota clutches (and Honda's) are soft to make the shifts "luxury". VB is a good upgrade but as you build power, you need more.
  6. Jan 23, 2016 at 2:59 PM
    #46
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I have no personal experience with either. I have close friends whom have done business with IPT, and know of others who have used Level 10.
  7. Jan 23, 2016 at 3:03 PM
    #47
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    Well you know my mods, level 10 would be good enough right?
  8. Jan 23, 2016 at 3:18 PM
    #48
    nfs257
    DFW
    She gone
    Heat treated cryo shafts and pump and anything else they offered lol all the disks and clutch packs. Everything. Lol
    Justus likes this.
  9. Jan 23, 2016 at 3:26 PM
    #49
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    If I had the motor first.... They do make a good 4speed....
  10. Jan 24, 2016 at 5:34 AM
    #50
    WOODEX M.E.
    WOODEX M.E. Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    I just had that happen for the 2nd or 3rd time the other day. I think i finally installed a little too much power with the headers that day. I also had 5 people in the vehicle and was acclerating onto an on ramp.
    Biscuits and thewarriordinghy like this.
  11. Jan 24, 2016 at 7:10 AM
    #51
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    That's a whole lot of bad right there. Shift kit would fix it.
    thewarriordinghy likes this.
