Who's skeered of their hi-lift thread.
Discussion in 'Off-Roading & Trails' started by Matic, Jul 13, 2011.
  1. Jul 25, 2011 at 5:49 AM
    #41
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig...
    had to use mine again wheeling this weekend. i tore two valve stems right off on rocks within abotu 10 minutes of each other. pluggend them up real quick and hauled ass back to camp before they went flat. camp was on a hill, so to safely lift the truck, we used a come-along and a tree saver to tie the roof rack to a tree. as the hi-lift went up, wetightened the come-along as needed so the truck didn't fall downhill off the jack. a little nerveracking, but because the correct precautions were taken, we knew it was safe.
  2. Jul 25, 2011 at 9:36 AM
    #42
    tacomarotto
    tacomarotto "Change is inevitable, but growth is optional."
    Jon
    Jacksonville
    Audi S3
  3. Jul 25, 2011 at 9:42 AM
    #43
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    i'll check with some of the guys there to see if they took any since i was working on it. we waited to do it until one of the guys with a powertank got back, since we had to unseat both tires to fix it. while it was safe for a quick fix, i didn't want the truck sitting on a hi-lift, tied to a tree for an hour and a half.
  4. Jul 25, 2011 at 9:48 AM
    #44
    tacomarotto
    Jon
    Jacksonville
    Audi S3
    hahaha sounds like a heck of a mess out on the trail
  5. Jul 25, 2011 at 9:48 AM
    #45
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    You need to lube the hell out of the jack before use and ensure it's regularly lubed. Once lubed, that jack will go up and down no probs.
  6. Jul 25, 2011 at 9:58 AM
    #46
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    luckily i got back to camp ok, but unseating the tire was fun. had to run over the rim/tire with a 7000 lb land rover. backup plan was to use another hi-lift as a clamp to get it off. i still have to get to the tire shop though because the inner end up the tire pressure sensor is just bouncing around in my tire. made for a shakey steering wheel on the ride home :eek:
  7. Jul 25, 2011 at 4:23 PM
    #47
    Matic
    Matic [OP] The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    I got myself into a similiar situation when I was wheeling alone in danial boone state forest in corbin, ky. Everything worked out ok using the hi lift as a come along. I have a shackle and plate that fits the opposite end of the hi lift but the only thing that was really sketch was using the "foot" of the hi lift to wrap the end of the strap for winching.
    I was at an odd angle and it looked as if the strap was going to come off at any time.
    I have since purchased a warn m8000 and used it twice so far.
    I enjoy wheeling alone so I want to make sure that I can get out of situations or atleast have the equipment to know with a little rigging and some time, I can recover myself.
  8. Jul 25, 2011 at 6:34 PM
    #48
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sold: 33's,armor,crawler,dents, ect. 2020 Gladiator
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    I have a love hate relationship with my jack. I bring a can of wd40 and spray it down every time i use it. Still hates to go down.
  9. Jul 25, 2011 at 6:52 PM
    #49
    theghost
    theghost Well-Known Member
    white
    maybe you guys should consider reading the directions that are included with a REAL Highlift.
    Educate yourself before you need to use it, Common sense. Then you wont end up slamming it through walls or smashing your door, or dropping the truck. Ill get you all started....
    http://www.youtube.com/watch?v=HJ7fgW5QNl4
    http://www.bb4wa.com/articles/hilift_jack.html
    good luck
    And for those of you that are buying the junk "Farmers Jack" from HF and calling it a Highhift, lol. Theres a reason yours bent Colinb17...
  10. Jul 25, 2011 at 7:08 PM
    #50
    Catcrazed
    Catcrazed Love is Dogs and Toyotas
    Bryan
    Central Oregon
    3rd Gen Flatbed 3.4
    91 Flatbed, 4.88's, ARBs, SAS, 3.4 Swap, 35s, M8000, lots lights, Aux tank, Protech
    I was letting my older farm jack junk down and for some reason the handle had extreme pressure on like 3 pump it stripped outta my hand bam almost broke my nose hit me on the side rite by my eye. Sorry no pics.
  11. Jul 25, 2011 at 7:13 PM
    #51
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    they can all bend when weight unexpectedly shifts in the wrong way. friend i went wheeling with this past weekend has a real hi lift hanging in his garage that looks like a "c". it's a matter of if the foot slips or not when the jack falls. if it slips, your jack is usually fine. if the foot is planted firmly enough, it can bend any jack.
    i bent mine back before the trip this weekend and it handled great, without bending again, but i'm going to get a new one for the truck and keep the old one with the trailer.
    Edit: i can't speak for the HF ones as i've only used Hi-lifts, and the ones northern tool sells. i believe the northern ones are made by Torin (big red)
  12. Jul 25, 2011 at 7:49 PM
    #52
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    nice tip with teh old tire. i'll have to do that or build a base like the wab fab.
  13. Jul 25, 2011 at 8:14 PM
    #53
    dan0
    dan0 Well-Known Member
    swamplands of sc
    Sold 2011 Prerunner Doublecab 4cyl auto
    so if i understand this correctly you cant use a hi lift on a stock taco
    ya need aftermarket bumpers and or sliders
    then ya worry about it falling?
    hmm
  14. Jul 25, 2011 at 8:20 PM
    #54
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    on a stock truck you can use it on the hitch (you need to secure the back from swaying side to side or it will fall). or you can get the wheel mate, which attaches to your wheel, which is actually pretty stable, but in order to change a tire that way you will need a jack stand or some good improvising.
  15. Jul 25, 2011 at 8:40 PM
    #55
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    If you have to ask...
    I grew up with Hilifts just being a part of wheeling. When used properly it's one of the most versatile and important tools to have when wheeling. It's the difference between the time effort it takes to bust it out and use it vs. a wasted miserable day of being stuck/stranded. Especially out in the desert, all the winches and offroad tires won't do you a bit of good in some situations that the Hilift makes easy to get out of if you're solo.
    It can be used to lift the vehicle, shift the vehicle over a few feet in the same spot, come-along, jaws of life, swap a spare, pull out fenceposts/signs, lever stumps out, etc. True, a stock Tacoma's body/bumpers make it very difficult to use properly (most newer vehicles) and you're left taking chances with the hitch (if you have one) or using the wheel hooks, but if you wheel regularly you'll want armor anyway, which conviniently works perfect with a Hilift. Hell, I installed sliders more for using my Hilift on than rock protection.
  16. Jul 25, 2011 at 9:09 PM
    #56
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    fyi a highlift will NOT hold up a school bus without bending like a paper clip
  17. Jul 25, 2011 at 9:10 PM
    #57
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    hahaha, tried this have we?
  18. Jul 25, 2011 at 9:22 PM
    #58
    fireturk41
    Kevin
    High Point, NC
    280k miles
  19. Jul 25, 2011 at 9:24 PM
    #59
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    ditch my fail lift a long time ago
  20. Jul 25, 2011 at 9:41 PM
    #60
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    i'm going to start carrying one of those as well, but most of the time i'm in a spot that one of those won't work :(
