Whos the right person
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Thebuilder, Feb 3, 2015.
  1. Feb 3, 2015 at 8:42 PM
    Thebuilder
    Thebuilder [OP] New Member
    13 PreRunner SR5
    Hello everyone!
    I went to about 2 different off road shops and they both told me something different.. I have a 13 prerunner with the trd sport wheels. What i really wanted to do is just new shocks and somehow have a little more payload capability. 1st shop said they will add something to the rear that will add a 1" and give me 500 pounds but i would need new shocks all around. He did tell the ride will be slightly harsher. 2nd shop told me yes with no payload on the back it will be very bumpy. If i do add that thing in the rear Also bilstein 5100 shocks they both recommended. Who is right????:)
    Also second shop just recommended to just put bilstein5100 and il be happy.. I dont want a lift and he said i can keep the same height. Sorry guys i wish i could tell you what they were goin to do but i am very clueless when it comes with car parts. But i do remember him saying 40$ :)
    Thanksss People!!!
  2. Feb 3, 2015 at 8:49 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    1st shop wanted to put in an AAL. It will make the rear a little stiffer and a little higher. I'm not one of the shock gurus here, so they can tell you the specs on the 5100s.
    If all you want is a better ride and to be able to load your truck without bottoming out, most popular answer is probably 5100s and airbags.
    Generally speaking, shocks absorb oscillations and springs support weight. So, using that, shop 1 would be correct to get better load handling and better shocks. However, you will get lift.
    With shop 2 (just replacing shocks), you will have a better unloaded ride but you won't get the additional capacity before sagging/bottoming out.
    Just remember, whatever you put on, your overall max capacity won't increase. Just the characteristics of how your truck handles loads. Meaning that you can add all the stuff you want, it still won't be able to match an F350. Sorry, some people just mis-think these things.
    Welcome BTW.
  3. Feb 4, 2015 at 5:03 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    If you want no lift but more payload, look into airbags as stated above. Other options to increase payload will involve adding a leaf or leaf pack, which will give you a lift and a stiffer ride unloaded.
  4. Feb 4, 2015 at 5:12 AM
    Clearwater Bill
    Billy
    Largo Florida
    Part of the problem is you may not have adequately defined your goals.......
    I have no idea why you think you need new shocks on a '13. All I really understand is that you want some more payload.
    Payload is a spring issue. When you go messing with stiffer springs, that does generally require different shocks to properly control the spring.
    Actually both shops told you about the same answer, just in different ways. What you wrote above for both of them are both true, not contradictory.
    I have no clue what the $40 is about. That amount wouldn't scratch the surface of any of that, either in parts or labor.
    So, with the idea of no lift and keeping ride quality, and interest in upping the payload (assuming its for occasional hauling, not regular loads), I say keep your stock shocks (until they need replacing due to wear) and add a set of airbags. You can air the bags up and down as needed for load adjustment.
  5. Feb 4, 2015 at 5:51 AM
    Wiggins
    Wiggins Well-Known Member
    Jacksonville
    14 MGM DCSB 4x4 TRD OR
    TRD Sport Hood, ICON 3" Lift - 700lb coils, Total Chaos UCAs 5% Tinted Windows Crystal Front Window Film 2.5 resi shocks front and rear, dakar leaf packs Wheelers Bump Stops All-Pro Offroad APEX Front Plate Bumper, PIAA Fog Lights, PIAA Fog Lights, Black Line-X All-Pro Offroad Skid Plates, Black Line-X All-Pro Offroad APEX Rear Plate Bumper, Side Armor for Plate, Hidden Receiver Hitch, Black All-Pro Offroad APEX Sliders,Line-X All-Pro Offroad APEX Pack Rack, Black Line-X, 16" height ScanTool 427201 OBDLink LX Bluetooth Hankook Dynapro ATM 285/75/16 Vision Manx 16"x8" rims, 4.5" Backspacing Warn M8000-s Winch, Factor55 Flatlink, Factor55 1" Hawse Fairlead RIGID Industries Ditch Lights Tractor Supply Bed Box 260amp H.O. Alternator Big 3 Cable Replacement NorthStar AGM34 battery Pelfreybilt Battery Cage Plefreybilt Fuse Plate BlueSea fuse block Kenwood TS-B2000 Short Wave Radio, Remote face, Pack Rack Mounted Antenna Uniden Bearcat CB Cab Mount Chop (BAMF Inserts) TODO: ARB Air System ARB Rear Air Locker w/ 4.88 gears ARB Front Air Locker w/ 4.88 gears HID Retrofit Headlights Rigid Industries RDS-Series 54" Midnight Edition LED Rigid Industries R2-46 Combo Round Light (x2)
    Listen to this guy.
